Hoods And Grille
yeah it should, make sure to check your lights as well, but it is just the front clip........
Here is some info that could prove useful:
Document ID# 444417
2005 Chevrolet Chevy C Silverado - 2WD
Fastener Tightening Specifications
Application
Specification
Metric
English
Air Inlet Grille Panel Screws
2 N·m
18 lb in
Battery Tray Bolts
9 N·m
80 lb in
Cab Mount Bolts
75 N·m
55 lb ft
Cable Handle Nut
11 N·m
97 lb in
Condenser Mounting Bolts
9 N·m
80 lb in
Diagonal Brace Bolts
25 N·m
18 lb ft
Fender Bolts
25 N·m
18 lb ft
Fender to Cowl Support Brace Bolts
9 N·m
80 lb in
Fender to Door Hinge Bolts
25 N·m
18 lb ft
Fender to Radiator Support Bolts
25 N·m
18 lb ft
Fender to Upper Cowl Bracket Bolts
25 N·m
18 lb ft
Ground Strap Nut
9 N·m
80 lb in
Headlamp Housing Screws
9 N·m
80 lb in
Hinge to Fender Bracket Bolt
25 N·m
18 lb ft
Hood Hinge Bolts
25 N·m
18 lb ft
Hood Latch Bolts
9 N·m
80 lb in
Hood Spring Bolts
25 N·m
18 lb ft
Link Assembly Bolts
25 N·m
18 lb ft
Lower Fender Bolts
25 N·m
18 lb ft
Pickup Box to Frame Rail Bolts
70 N·m
52 lb ft
Pivot Bolt
25 N·m
18 lb ft
Radiator Support to Frame Mounting Nut
70 N·m
52 lb ft
Upper Radiator Support Bolts
9 N·m
80 lb in
Washer Reservoir Bolt
9 N·m
80 lb in
Wheelhouse Panel Bracket Bolts
9 N·m
80 lb in
Wheelhouse Panel Bracket Nuts
25 N·m
18 lb ft
Wheelhouse Panel to Dash Panel Bolt
9 N·m
80 lb in
Document ID# 444417
Fastener_Tightening_Specifications.doc
hmmm...was just curious... someoneput a small dent in my hood and I was thihnking about throwng in the newer style grille and hood.
ouch........
yeah, its been there for a year now. 450 bucks to have it fixed. Its not hardly noticable but i am picky.... just a tad smaller than a golf ball and its in the crease where it rounds to the front just above the grill.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
