Warning From Pakistan
Nytemare
WARNING FROM PAKISTAN
This morning, from a cave somewhere in Pakistan , Taliban Minister of
Migration, Mohammed Omar, warned the United States and Canada that if
military action against Iraq continues, Taliban authorities will cut off
America's and Canada's supply of convenience store managers.
And if this action does not yield sufficient results, cab drivers will
be next, followed by Bell and Rogers customer service reps.
it's getting ugly folks
:tumbleweed: LOL. Don't forget about Dish Network customer service people.
(In heavy foreign accent) "Hello, my is William..Khumar. Thank for choosing Dish Network, how can help you today?"
"Your name is really William?"
"Yes sir"
"Ok..well your installation guy must have forgotten about the other 2 TV's in the house..."
And dont forget the support line for Linksys . Dont they realize its hard as hell to understand someone that cant hardly speak english???? WTF everywhere you call it seems some *edited* is answering the phone trying to help you.
Watch the racist comments here please- Frank
Guest chevydeerhunter
:D LOL. Don't forget about Dish Network customer service people.
"Yes sir"
LMFAO!
Yes, hello my name is Brad :tumbleweed: how may I help you?
Oh yes, you live on Ook(Oak) Street.
It's gotten to the point where I don't even bother calling their customer service anymore because I can't understand a flippin' thing they say. I go local.
LMFAO!
:D:lol::lol: ''Hello, I name is John :bs: , how I help today?"
I need to go local, I gave up on asking them to unf--k my set up. It took 3 weeks of calling to get a guy to come out, which solved nothing. To make it better it looked like the dish tech guy climbed out of a storm drain and hopped in a van and showed up here. I thought for sure he must have jumped the real dish guy in an alley somewhere and took his van.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
