Radio Antenna Lead Cable
jlcallaway
A car wash broke my antenna off at the base so obviously needs replaced. I picked up a new base which the cable going into the cab is part of it. I thought it could be difficult however I did believe dropping the trim piece under the heater motor and duct work I could get to the cable connection. It now appears to me the connection is behind or above the heater motor or duct work? Do I have to remove the heater motor and duct work to get to it? Any help will be appreciated.
JoJoJiim
What I do is get some mechanics wire and wrap it tightly around the old cable and fight to get the old one out then fight to get the new one in. There really isn't any easy way that I've found.
Can anyone supply pics of how to get to the end of the antenna cable as it must end right behind the heater motor or duct work. Not nearly long enough to get even half way to the radio. Not possible to get a hand behind where it goes.
Thanks,
Doh I forgot to mention you need to take off the instrument panel cover. It looks like a big deal but it's not. Once you get the cover off it's still more of a pain to pull that cable through. I gave instructions on the panel removal in a drl photocell post here it is.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
