New Muffler Help
I have read quite a few of the posts for new exhaust systems, but have not found exactly what I am looking for and could use some help.
I have an 07 GMT900 GMC Sierra Crew Cab 4X4 with the 4.8 engine. I would like to get some more sound out of it without going to a cat back system or spending a ton of $$. I was thinking of just buying a new muffler but i have a couple questions:
1. what is the exact dimmension (LXW)? I believe I have single in/out (maybe someone could verify what is stock)
2. will just changing the muffler void any warranty?
3. can I just change the muffler without making any other upgrade (ie air intake) - as I said, just looking to get some more sound out of her. Will this mess anything up with the computer??
Any help or input is appreciated.
By the way, added the Rough Country 2 inch leveling kit and looks awesome!!! Neighbor thought I had the 2500
Brian Paszek
Waunakee, WI
I believe yours is single in & out, length not sure, 24"s long maybe. The only way the muffler will hurt your warranty is muffler back will not be covered. your cats and everything else will be covered so no big deal. Yes you can just swap the muffler and run new tailpipes or fabricate it to the stock pipe. & nope, muffler doesn't affect the computer its just for sound volume.
I suggest a Flowmaster Super 44 those sound awesome
Thanks - exactly what I was looking for!
Brian
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
