Gmpp Intake
just installed the gmpp cold air intake and it sounds great, it ever looks great too. its definetly worth the price. when accelerating it sounds like i have an exhaust. it has that low rumble sound to it that is freakin awesome. ill eventually take a pic of it
  • 3 weeks later...
the one I ordered just arrived at the dealer on a stock order, can't wait to get it installed
Your gonna love it
Yep, love mine. Sure does make the engine bay look a whole lot nicer. I wouldn't expect any drastic HP/TQ increases from any intake though, but perhaps just a bit. :lol: Also get improved throttle response and a nice growl from the engine.
Oh no, I have no expectations. Pure aesthetic reasons for me, that and the exhaust. I have been down this road many times, wish I had all my money back on the upgrades I have purchased for this reason :lol:
I just picked it up at the dealer, I will take pics of it out of the box for those that were asking questions about the element, etc
