98 Tahoe P0452
I am getting stumped here. I have a P0452 and can't seem to locate the fuel tank pressure sensor. Anyone know offhand where it is? I saw a post earlier where someone had this and a jiggly fuel gauge. I have the same thing, but never saw a resolution to it.
Any thoughts? Truck runs ok, mileage is a little bad, and I really just hate to drive with the CEL on. I check it every couple of days to make sure it doesn't have something new, but still the same...Even if I clear it, it is still holding as pending...
Thanks guys
Thanks guys
Document ID# 221879
1998 Chevrolet Tahoe - 2WD
DTC P0452 Fuel Tank Pressure Sensor Circuit Low Voltage
Circuit Description
The Fuel Tank Pressure Sensor responds to changes in the fuel tank pressure or vacuum. This information is used in order to detect vacuum decay or an excessive vacuum during the EVAP diagnostic routing. The fuel tank pressure sensor signal voltage to the VCM varies from a minimum of about 0.1 volts with pressure in the fuel tank to above 4.0 volts with a high vacuum in the fuel tank.
The Fuel Tank Pressure sensor display on the scan tool has an auto zero feature which occurs at each ignition cycle and is corrected according to the barometric pressure. Because of this, the Fuel Tank Pressure sensor display may not accurately reflect the actual output of the sensor or the conditions within the fuel tank.
The Fuel Tank Pressure Sensor diagnosis table is intended to isolate and diagnose the electrical problems with the sensor wiring or the sensor.
Conditions for Running the DTC
The ignition switch is the RUN position.
Conditions for Setting the DTC
The Fuel Tank Pressure Sensor voltage is less than 0.1 volt for more than 5 seconds.
Action Taken When the DTC Sets
The VCM turns ON the MIL after 2 consecutive driving cycles with the fault active.
Conditions for Clearing the MIL or DTC
  • The control module turns OFF the MIL after 3 consecutive drive trips when the test has run and passed.
  • A history DTC will clear if no fault conditions have been detected for 40 warm-up cycles. A warm-up cycle occurs when the coolant temperature has risen 22°C (40°F) from the startup coolant temperature and the engine coolant reaches a temperature that is more than 70°C (158°F) during the same ignition cycle.
  • Use a scan tool in order to clear the DTCs.
Diagnostic Aids
Inspect the Control Module harness connectors for the following conditions:
- Improper mating
- Broken locks
- Improperly formed
- Damaged terminals
Inspect the wiring harness for damage. If the harness appears to be OK, observe the Fuel Tank Pressure sensor display on the scan tool while moving the connectors and the wiring harnesses related to the sensor. A change in the display will indicate the location of the fault. Refer to
Wiring Repairs in Wiring Systems if a problem in the wiring is found.
Test Description
The number(s) below refer to the step number(s) on the diagnostic table.
  1. If the VCM recognizes the high signal voltage, the VCM and the wiring are Okay.
DTC P0452 Fuel Tank Pressure Sensor Low
Step
Action
Value(s)
Yes
No
Important:
Before clearing the DTCs, use the scan tool Capture Info to save the Freeze Frame and Failure Records for reference. The control module's data is deleted once the Clear Info function is used.
Did you perform the Powertrain On-Board Diagnostic (OBD) System Check?
Go to Step 2
Go to Powertrain On Board Diagnostic (OBD) System Check
2
  1. Install the scan tool.
  2. Turn ON the ignition leaving the engine OFF.
  3. Monitor the Fuel Tank Pressure Sensor reading.
Does the scan tool display indicate the Fuel Tank Pressure Sensor above the specified value?
7.2 in. H2O
Go to Step 4
Go to Step 3
3
This DTC is intermittent.
Are any additional DTCs stored?
Go to the applicable DTC table
Go to Diagnostic Aids
4
  1. Turn OFF the ignition.
  2. Disconnect the Fuel Tank Pressure Sensor electrical connector.
  3. Turn ON the ignition leaving the engine OFF.
  4. Measure the voltage between the 5 V reference circuit and the sensor ground circuit at the Fuel Tank Pressure Sensor harness connector using a DMM J 39200 .
Is the voltage near the specified value?
5.0 V
Go to Step 5
Go to Step 6
<a href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=221879&psdid=51&evc=sm#TD05">5
  2. Jumper the sensor signal and 5 V reference circuits together.
Does the EVAP Fuel Tank Pressure sensor display vacuum greater than the specified value.
-16.50 in. H2O
Go to Step 11
Go to Step 9
6
Check for an open in the 5 V reference circuit.
Did you find a problem?
Go to Step 13
Go to Step 7
7
Check for a short to ground in the 5 V Reference circuit.
Go to Step 13
Go to Step 8
8
Check the 5 V reference circuit for a poor terminal connection at the VCM.
Go to Step 13
Go to Step 14
9
Check the Fuel Tank Pressure Sensor signal for an open or a short to ground.
Go to Step 13
Go to Step 10
10
Check the Fuel Tank Pressure Sensor signal terminal connection at the VCM.
Go to Step 13
Go to Step 14
11
Check the connector at the Fuel Tank Pressure Sensor for:
  • Salt or water intrusion
  • Backed out terminals
  • Improper terminal mating
  • Poor terminal to wire connections
Go to Step 13
Go to Step 12
12
Replace the Fuel Tank Pressure Sensor. Refer to Fuel Tank Pressure Sensor Replacement (Pick-up) .
Is the action complete?
Go to Step 15
13
Repair the circuit as necessary. Refer to Wiring Repairs .
Go to Step 15
14
  1. Replace the VCM.
  2. Program the new VCM. Refer to VCM Replacement/Programming .
  3. Perform the VTD Password Learn Procedure. Refer to Password Learn Procedure .
  4. Perform the Crankshaft Variation Learn Procedure. Refer to CKP System Variation Learn Procedure .
Go to Step 15
15
  1. Using the scan tool, clear the DTCs.
  2. Start the engine.
  3. Allow the engine to idle until the engine reaches normal operating temperature.
  4. Select DTC and the Specific DTC function.
  5. Enter the DTC number which was set.
  6. Operate the vehicle, with the conditions for Setting this DTC, until the scan tool indicates the diagnostic Ran.
Does the scan tool indicate the diagnostic Passed?
Go to Step 16
Go to Step 2
16
Does the scan tool display any additional undiagnosed DTCs?
System OK
Document ID# 221879
as for the physical location, not sure but this should help -
Document ID# 203392
Fuel Vapor Pressure Sensor Removal
  1. Relieve the fuel pressure. Refer to Fuel Pressure Relief Procedure .
  2. Lower the fuel tank.
  3. Drain the fuel tank. Refer to Fuel Tank Draining Procedure .
  4. Remove the fuel tank. Refer to the following procedures:
    - Fuel Tank Replacement (Suburban).
    - Fuel Tank Replacement (Tahoe/Yukon).
    - Fuel Tank Replacement (Extended Cab - Side Tank).
    - Fuel Tank Replacement (Pick-up - Side Tank).
    - Fuel Tank Replacement (Cab and Chassis - Side Tank).
    - Fuel Tank Replacement (Cab and Chassis - Rear Tank).
  5. Disconnect the electrical connector.
  6. Remove the Fuel Pressure sensor (1) from the fuel sender assembly (2)
Fuel Pressure Sensor Installation
  2. Install the Fuel Pressure Sensor (1) on the fuel sender assembly (2).
  3. Reconnect the electrical connector
  4. Install the fuel tank. Refer to the following procedures:
Document ID# 203392
I have the same problem on a 03 silvy, on it the sensor is in the tank and the dealer wants 400 bucks to drop the tank and change it. The part was only 60 bucks. The labor seems to be the killer.
Thanks guys. It is in the tank, not on the pump, but same general location. Still had to drop the tank...ugh. Replaced the sensor and all seems good now.
I am in the process of selling the 03' silverado, and the buyer is wanting to just buy it as is and fix it himself. Does the computer automatically reset when the problem is fixed and shut the service engine light off, or will he still have to take into a dealer to clear the code and reset the system after the new sensor is installed?
