YIKES!!!!!
Kansas Kid
Down where those Forest fires were in Florida, they found a corpse of a scuba diver in the Burned out woods.
It turns out he was scuba diving 20 miles off the coast and a helicopters with a "Dump Bucket" managed to pick him up and drop him 300' down to the fire awaiting below.
Talk about a big Screw up.
(Edited by General Lee 01 at 1:19 am on June 3, 2001)
General Lee 01
This is a funny story. I heard it years ago and it's still funny. LMASO.qusans.gif
LT
(Edited by LT at 7:26 am on June 3, 2001)
Seems a little out there to me.  Why would the helicopter go 20 miles off the coast to get water?
General Lee 01 you need to change your signature line when you start something out like that.  To me that would be a permanent end!!
(Edited by doverarjim at 12:47 am on June 4, 2001)
I remember hearing that story almost every year when California burns down, but it's still an intersting thought!
Quote: from General Lee 01 on 1:50 am on June 4, 2001
When you say story, do you mena "Fiction"?
Actually, to think about it, Why would a helicopter w/ water bucket go 20 miles out just for a scoop of water?
Actually, I was intending for made-up to go in front of the word story, sorry, I changed it from what I had the first time.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 843 Guests (See full list)
