New 20 Inch Rims
racdlo2002
I just bought new 20 inch rims for my 2007 Silverado that originally had 18 rims on it. How do i reset the computer so my speedometer and odometer are accurate and depict my acutal speed?
I'm not a tech...but as long as the overall diameter of the tire/rim assembly doesn't change, you don't need a reprogram...
The rims i bought have a larger outside diameter.....how do i reprogram the computer?
The diameter of the rims has nothing at all to do with the need to reprogram the computer. The overall diameter of the tire (see BigDogg's post) does. If you don't have a hand-held tuner, you'll have to go to the dealer and have them make the change.
Check and compare the OD of the two different size tires first. You may be lucky and not need to reprogram.
I am selling the rims and tires with the TPS. They have 11,000 miles on them. Make me an offer. I live in northern New Jersey.
You'd probably get more bites on this if you posted pics of your tires & wheels.
