This Is Cool.
Check this
Plugs into your stock deck has 3 rca pre outs gets rid of the bass control of the stock deck.
Didn't read it all but it looks promising... Cost? Is there one for our trucks?
I've seen this before... but there's still no way it's going to sound as good as a decent aftermarket receiver.
Check this
Yes, and they retail for $200 but I have seen them for $110 online.
May not sound as good as a deck but it will still sound good and maintain your steering wheel controls allowing an external amp with sub control.
