07' Plastic Vibrating
The piece of plastic that is in the corner of the windows seems to be makeing a vibrating noise , has anybody else had this problem ? at first i thought it was the speakers but seems if i push on it a little it stops , both sides are doing this and its starting to drive me nuts ! but before i take it back to the dealer i was wondering if others have had the same problem.
yes i have this problem on both side... its driving me **** nuts. I was at the dealer twice for this problem. They cant seem to fix it. Wedge a credit card in the corner to fix the problem.
IF you are talking about the triangle piece on the inside where the mirror mounts, it comes right off. Roll up a ball of plumbers putty or something similar, put it on the backside where the piece connects and snap it back on. It'll never rattle again and it is removable if you ever need back in there. I noticed something similar on mine after I had the door panels off to install the new handles.
Sorry I read the post to fast.. My plastic pieces that are vibrating are where the from A pillar meet the dash.. In the corners... ill take pics later tomorrow and show you guys what I mean.
Yes thats it ! i'm glad i'm not the only one (sorry) , does that back piece just pop off ? i haven't tryed it as i fig. i would break something , what about some foam tape or double stick tape would that work ? i don't really think i would take much . but it does drive you nuts ! also noticed that when its cold i don't hear it but as soon as it warms up good inside thats when it starts.
If I remember right I just popped one end loose and the rest was easy to unsnap. A little foam, putty, anything that will fill the gap should work.
My 07 NBS does this too!!!!!!!!!!
It seems like if I press on the A Piller it stops. I don't know for sure if it's the trangle plactic cover.. or the a piller cover... or maybe the tweeter cover that says BOSE. It drives me nuts too. Mine only happens when the truck is cold....both sides. HELP!
One of the "benefits" of GM making these new truck so nice and quiet is now we hear everything. Not sure if it is an improvement...
I worked on squeaks & rattles on the NBS pilot vehicles. We had a few vehicles squeaking in the area you guys are talking about. Mostly in cold temps. The biggest percentage of noise was from the rubber windshield trim squeaking against the windshield on the outside of the vehicle on the A-pillar. Not all vehicles did it. We would use a small amount of lubricant between the rubber trim and the windshield to stop the noise.
