Can Someone Run This Vin Please
Here you go:
By the way, this vehicle is salvaged from the govt in the state of texas:
VIN : 2GCEC13J171654351
VEHICLE INFORMATION
Merchandising Model : CC10543 -2007 SILVERADO 1500 2WD CREW CAB LT1 Warranty Start Date : 07/27/2007
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : PETERS CHEVROLET, INC.
PO BOX 5550
LONGVIEW , TX 75608-5550
(903) 757-3720
Selling Source : 13 - CHEVROLET
Site Code : 07042
Business Associate Code : 114265
Service Contract : No Branded Title : Yes Warranty Block : Yes PDI Status : Paid
REQUIRED FIELD ACTIONS
Vehicle Has No Current Record Of Outstanding Campaigns
SERVICE INFORMATIONAL ITEMS
Type Number Description Posted Date Status
EI 07082 POWER STEERING FLUID LEAK AT GEAR/RACK, REF-TSB 07-02-32-002C 08/14/2007 See Bulletin
EI 07199 RADIO SPEAKER BUZZ NOISE - TSB. 07-08-44-013 07/31/2007 See Bulletin
EI 07266 TIRE VIBRATION - REF. TSB 07-03-10-013A 11/06/2007 See Bulletin
EI 07321 INNER DOOR PANEL RATTLE NOISE / LOOSE - REF. TSB 07-08-110-010. 12/13/2007 See Bulletin
ON STAR AND XM SATELLITE RADIO INFORMATION
OnStar Equipped Yes OnStar Status Active Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
XM Equipped No XM Radio ID N/A XM Status N/A Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 07/27/2007 26 miles 07/27/2010 36026 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 07/27/2007 26 miles 07/27/2013 100026 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 07/27/2007 26 miles 07/27/2015 80026 miles
60/100000 POWERTRAIN COVERAGE LIMITED WARRANTY 07/27/2007 26 miles 07/27/2012 100026 miles
36/36000 FEDERAL EMISSION 07/27/2007 26 miles 07/27/2010 36026 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
09/19/2007 212388 # D0362 - CONTROL, HEATER AND AIR CONDITIONING - REPLACE 6164 miles
09/13/2007 211904 # D1812 - ACTUATOR AND/OR MOTOR, ELECTRIC - TEMPERATURE DOOR - LEFT 5593 miles
09/13/2007 211904 F Z7200 - CORPORATE PARTS RETURN REIMBURSEMENT 5593 miles
08/22/2007 210396 # D1812 - ACTUATOR AND/OR MOTOR, ELECTRIC - TEMPERATURE DOOR - LEFT 3405 miles
08/22/2007 210396 F Z7200 - CORPORATE PARTS RETURN REIMBURSEMENT 3405 miles
08/22/2007 210396 G D1812 - ACTUATOR AND/OR MOTOR, ELECTRIC - TEMPERATURE DOOR - LEFT 3400 miles
08/22/2007 210396 # F1280 - PROPELLER SHAFT ASSEMBLY (BETWEEN TRANS AND REAR DIFFERENT 3405 miles
08/22/2007 210396 # Z7902 - 2-DAY COURTESY TRANSPORTATION 3405 miles
03/28/2007 A54351 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
© 1998-2005 General Motors Corporation. All Rights Reserved.
CLAIM HISTORY
Repair Order Date : 09/19/2007 Repair Order Number : 212388 Odometer Reading : 6164 miles
Serviced By : PETERS CHEVROLET, INC.
PO BOX 5550
LONGVIEW, TX 75608-5550
(903) 757-3720 Selling Source : 13 - CHEVROLET
Site Code : 07042
Cycle Date Cycle Nbr Case Type Labor Operation Part Comments
11/06/2007 845 01 # D0362 - CONTROL, HEATER AND AIR CONDITIONING - REPLACE 15238552 - CONTROL Y
Repair Order Date : 09/13/2007 Repair Order Number : 211904 Odometer Reading : 5593 miles
PO BOX 5550
Site Code : 07042
10/30/2007 843 01 F Z7200 - CORPORATE PARTS RETURN REIMBURSEMENT N/A Y
10/05/2007 836 01 # D1812 - ACTUATOR AND/OR MOTOR, ELECTRIC - TEMPERATURE DOOR - LEFT 15887320 - ACTUATOR Y
Repair Order Date : 08/22/2007 Repair Order Number : 210396 Odometer Reading : 3405 miles
PO BOX 5550
Site Code : 07042
11/09/2007 846 01 G D1812 - ACTUATOR AND/OR MOTOR, ELECTRIC - TEMPERATURE DOOR - LEFT N/A N
10/26/2007 842 01 F Z7200 - CORPORATE PARTS RETURN REIMBURSEMENT N/A Y
09/14/2007 830 01 # D1812 - ACTUATOR AND/OR MOTOR, ELECTRIC - TEMPERATURE DOOR - LEFT 15887320 - ACTUATOR N
09/14/2007 830 02 # F1280 - PROPELLER SHAFT ASSEMBLY (BETWEEN TRANS AND REAR DIFFERENT N/A N
09/14/2007 830 03 # Z7902 - 2-DAY COURTESY TRANSPORTATION N/A Y
Repair Order Date : 03/28/2007 Repair Order Number : A54351 Odometer Reading : 0 miles
PO BOX 5550
Site Code : 07042
04/03/2007 783 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME N/A N
GM Vehicle Inquiry System
Line Comments
Home - Back - Help
LINE COMMENTS
PO BOX 5550
LONGVIEW, TX 75608-5550 Selling Source : 13 - CHEVROLET
Site Code : 07042
Comments PART FAILURE... TEMP DOOR ACTUATOR WOULD NOT MAINTAIN SETTING... FLUCTUATING OPEN AND CLOSE CAUSING INTERMITTENT HEAT AND COOL... REPLACE TEMP DOOR ACTUATOR... PLEASE REVIEW AND ADVISE...
Line Comments
Home - Back - Help
LINE COMMENTS
PO BOX 5550
Site Code : 07042
Comments TAN CASE 9882382...HVAC ACTUATOR STUCK...PER TAN, CHECK ACTUATOROPERATION...ACTUATOR CAN BE COMMANDED TO SWITCH POSITIONS..CHECKWIRING FOR CHAFING AND LOOSE TERMINAL CONNECTIONS...PER TAN, REPLACE CONTROL HEAD ASSY...PLEASE REVIEW AND ADVISE...
VIN 2GCEC13J171654351
VEHICLE BUILD
Gross Vehicle Weight Rating : 3087 kg (6807 lb) Order Number : KVTT4K
Build Date : 03/28/2007 Build Plant : 27143
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AJ1 - DEEP TINTED GLASS AL0 - SENSOR INDICATOR INFLATABLE RESTRAINT FRT PASS
AM1 - MANUAL LUMBAR, DRIVER AP8 - REMOTE VEHICLE STARTER PREP PKG
AT8 - RESTRAINT CHILD PROVISIONS AU3 - POWER DOOR LOCK SYSTEM
AZ3 - 40/20/40 SPLIT BENCH SEAT A31 - POWER WINDOWS
A68 - SEAT, 60/40 REAR FOLDING BENCH B30 - CARPETING, COLOR-KEYED
B32 - FRONT COLOR-KEYED FLOOR MATS B33 - REAR COLOR KEYED FLOOR MATS
B85 - BODY SIDE MOLDING C49 - ELECTRIC REAR WINDOW DEFOGGER
C5U - GVW RATING - 6,800 LBS C67 - AIR CONDITIONING, MANUAL
DF5 - ISRV MIRROR W/COMPASS & TEMP DH6 - LIGHTED VISOR/VANITY MIRRORS
DK8 - DELUXE OVERHEAD CONSOLE DL8 - DUAL PWR HEATED OSRV MIRRORS
E63 - FLEETSIDE BODY FE9 - FEDERAL EMISSIONS
GU6 - REAR AXLE 3.42 RATIO G80 - LOCKING REAR DIFFERENTIAL
JF3 - 17" BRAKES, DISC/DRUM JJG - SUB-ASSEMBLY
JL4 - STABILITRAK KG3 - 145 AMP ALTERNATOR
KNP - HD AUX TRANS. COOLING SYSTEM K34 - CRUISE CONTROL
K47 - HIGH CAPACITY AIR CLEANER LY5 - VORTEC 5.3L V8 GAS ENGINE W/ ACTIVE FUEL MGT TECHNOLOGY
M30 - 4-SPD AUTOMATIC TRANSMISSION NP5 - LEATHER WRAPPED STEERING WHEEL
NT8 - EMISSION SYSTEM FEDERAL, TIER NZ4 - FULL SIZE SPARE WHEEL
OSG - OSHAWA ASSEMBLY PDA - TEXAS EDITION: * VORTEC 5.3L V8 W/ACT FUEL MGT * 20" POLISHED ALUMINUM WHEELS (REPLACES STD/OPT WHEELS) * TRAILERING PACKAGE * LOCKING REAR DIFFERENTIAL * HIGH PERFORMANCE SUSPENSION
P58 - 20" MACHINED ALUMINUM WHEEL (REPLACES STD/OPT WHEEL) QSS - P275/55R20 BW RADIAL TIRES
R6I - TEXAS EDITION PKG DISCOUNT (RESIDENTS OF TX, OK, LA & SELECT COUNTIES OF NM, AR & KS SEE DEALER FOR DETAILS) R6K
R6P - PREMIUM PAINT R7B - GEOGRAPHIC TRACKING CODE
R9L - SPRING WHOLESALE FLOORPLAN PLUS R9N - PROCESSING OPTION ONLY LEATHER SEAT TRIM
R9U - GM ACCESS - AUTOBOOK IDENTIFIER R9Z - POMS EXPEDITE-SOLD ORDERS/TSE
SAB - ACTIVE FUEL MGT PROCESSING OPT SAF - SPARE TIRE LOCK
SLM - STOCK ORDERS SSB - PROCESSING OPTION
TUF - ORNAMENTATION.TEXAS T74 - HEADLAMPS
UE1 - ONSTAR SERVICE: INCLUDES 1 YEAR SAFE & SOUND PLAN UJ6 - TIRE PRESSURE MONITOR
UQ3 - ENHANCED AUDIO SPEAKERS US8 - AM/FM STEREO WITH CD/MP3
VB3 - CHROME REAR BUMPER VG3 - CHROME FRONT BUMPER
VK3 - FRONT LICENSE PLATE MOUNT VR4 - WEIGHT DISTRIB. PLATFORM HITCH
VXS - COMPLETE VEHICLE LABEL V22 - CHROME GRILLE
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA V76 - RECOVERY HOOKS
X88 - CHEVROLET CONVERSION YD3 - BASE AXLE
YD5 - BASE FRONT SPRING YD6 - BASE REAR SPRING
YE9 - SILVERADO ZK3 - PULL AHEAD DESIGN
ZRS - P265/70R17 SPARE TIRE ZY1 - SOLID PAINT
Z60 - SUSPENSION PACKAGE Z82 - HD TRAILERING EQUIPMENT
1LT - SILVERADO LT1 EQUIPMENT GROUP: * POWER LOCKS AND WINDOWS * ISRV MIRROR W/AUTO DIMMING, COMPASS, TEMPERATURE * DUAL PWR HEATED OSRV MIRRORS * LEATHER WRAP STEERING WHEEL * REMOTE KEYLESS ENTRY 1SZ - OPTION PKG DISCOUNT
46U - BLUE GRANITE METALLIC 6TC - SUSPENSION
7TC - SUSPENSION 84D - LIGHT TITANIUM/EBONY
84I - EBONY/LIGHT TITANIUM
Vehicle Component
Component Code : 10 - ENGINE ASSEMBLY
Source Plant : K - GM OF CANADA, LTD. ST. CATHARINES, ONTARIO
Part/Num Broadcast : CHA Traceability : 070860245
Date Scanned : 03/28/2007 Time Scanned : 14.22.00 Scan Station : 04
Component Code : 35 - STEERING COLUMN - SIR SYSTEM
Source Plant : S - SAGINAW DIVISION SAGINAW,MI
Part/Num Broadcast : G4B Traceability : 661690857
Date Scanned : 03/28/2007 Time Scanned : 13.05.00 Scan Station : 10
Component Code : 61 - TRANSMISSION
Source Plant : Y - HYDRAMATIC TOLEDO, OHIO
Part/Num Broadcast : 8CLD Traceability : 45734253
Component Code : 86 - ELECTRONIC CONTROL MODULE (ECM)
Source Plant : K - DELCO ELECTRONICS KOKOMO,IN
Part/Num Broadcast : YPLA Traceability : 17082DPY7
Date Scanned : 03/28/2007 Time Scanned : 18.32.00 Scan Station : 05
Component Code : 87 - BODY CONTROL MODULE
Source Plant : M
Part/Num Broadcast : 3559 Traceability : 70780CKEH
Component Code : 92 - BRAKE PRESSURE MODULATOR VALVE ASSEMBLY
Source Plant : B - BOSCH BAILCHACH, GERMANY
Part/Num Broadcast : 6640 Traceability : 7065E4308
Date Scanned : 03/28/2007 Time Scanned : 15.21.00 Scan Station : 09
Component Code : AB - IR-MODULE ASM-INFLATOR
Source Plant : Q - RIMIR MATAMORS MEXICO
Part/Num Broadcast : 4506 Traceability : 7H3E6AE
Date Scanned : 03/28/2007 Time Scanned : 16.25.00 Scan Station : 11
Component Code : AH - IR-SENSOR ASM-LEFT
Source Plant : X - DELCO ELECTRONICS SINGAPORE
Part/Num Broadcast : 7468 Traceability : 7065JGE36
Component Code : AJ - IR-SENSOR ASM-RIGHT
Part/Num Broadcast : 7468 Traceability : 7065JGD7A
Component Code : AL - IR-MODULE ASM-I/P
Source Plant : N - NIPPONDENSO
Part/Num Broadcast : 3207 Traceability : 000610526
Date Scanned : 03/28/2007 Time Scanned : 13.05.00 Scan Station : 01
Component Code : AS - SENSING DIAGNOSTIC MODULE
Part/Num Broadcast : 3557 Traceability : G7083F9UJ
Component Code : BK
Source Plant : K
Part/Num Broadcast : YNNH Traceability : 070816070
Date Scanned : 03/28/2007 Time Scanned : 18.32.00 Scan Station : 02
Component Code : CC - SEQ NUM (FLEX) BODY ASM
Source Plant : N/A
Part/Num Broadcast : 199 Traceability : 2190800
Date Scanned : 03/21/2007 Time Scanned : 10.58.00 Scan Station : N/A
Component Code : CP - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 133 Traceability : 9153458
Date Scanned : 03/28/2007 Time Scanned : 11.13.00 Scan Station : N/A
IN-SERVICE INFORMATION
In-Service Information Not On file
DELIVERY INFORMATION
Delivery Date : 07/27/2007 Delivery Type : 010 - RETAIL/INDIVIDUAL Delivered Odometer : 26 miles
PO BOX 5550
(903) 757-3720
Delivery Selling Source : 13 - CHEVROLET
Delivery Site Code : 07042
INVOICE INFORMATION
Invoice Date : 03/28/2007
Site Address : PETERS CHEVROLET, INC.
PO BOX 5550
Site Code : 07042
SHIP-TO INFORMATION
Ship-To Date : N/A
PO BOX 5550
Site Code : 07042
WARRANTY BLOCK
Block Code : SV Description : GOVERNMENT REPORTED SALVAGED Effective Date : 12/01/2007
Blocked Labor Operations :
All
Blocked Claim Types :
#, A, D, E, F, I, K, L, M, P, Q, S, T, U, 4, 5, 6, 7, 8, 9
BRANDED TITLE
Brand Description : JUNK
Date Branded : 12/01/2007 Reporting Source Code : 1
Title Number : 29739039424092732 Reporting State/Entity : TX
The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
    250.3k
    Christopher Miller
    Christopher Miller
  • Who's Online   5 Members, 0 Anonymous, 1,544 Guests (See full list)
