This Is Stupid...
#08-08-50-003: Loose Module/Broken Tab Under Passenger Seat (Re-attach Inflatable Restraint Passenter Presence System Module with Two-Way Tape) - (Feb 15, 2008) Subject:Loose Module/ BrokenTab Under Passenger Seat (Re-attach Inflatable Restraint Passenger Presence System (PPS) module with Two-Way Tape)
Models:2006-2008 Chevrolet Colorado
2006-2008 GMC Canyon
2006-2008 HUMMER H3
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2065557&from=nb#ss1-2065557">
Condition
Some customers may comment on something dangling under the passenger seat or finding broken plastic tabs under the passenger seat.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2065557&from=nb#ss2-2065557">
Cause
This may be caused by the inflatable restraint passenger presence System (PPS) module not secure under the passenger seat.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2065557&from=nb#ss3-2065557">
Correction
Technicians are to re-attach the inflatable restraint passenger presence System (PPS) module under the passenger seat with *3M 2-way tape.
Important: DO NOT replace the inflatable restraint passenger presence System (PPS) module.
  1. <LI type=1>Detach the passenger side seat bolts from the floor pan.
<LI type=1>Turn the seat as shown in the figure above. <LI type=1>Disconnect the wire harness assembly from the inflatable restraint passenger presence System (PPS) module connector. <LI type=1>Inspect the inflatable restraint passenger presence System (PPS) module mounting tabs. Important: DO NOT place the inflatable restraint passenger presence System (PPS) module in a vice.
<LI type=1>Using a pair of side cutters, cut off the unbroken tab(s). <LI type=1>Clean the area under the seat pan and the back of the inflatable restraint passenger presence System (PPS) module using glass cleaner. Wipe the area dry with a clean towel.
<LI type=1>Place three pieces of tape on the back and on the edges of the inflatable restraint passenger presence System (PPS) module as shown above. Use 3M Tape, P/N 06377. <LI type=1>Remove the liner from the tape and firmly place the inflatable restraint passenger presence System (PPS) module under the passenger seat floor pan. <LI type=1>Reconnect the wire harness to the inflatable restraint passenger presence System (PPS) module.
Reinstall the seat back into place.
*We believe this source and their products to be reliable. There may be additional manufacturers of such products/material. General Motors does not endorse indicate any preference for or assume any responsibility for the products or material from this firm or for any such items that may be available from other sources.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2065557&from=nb#ss4-2065557">
Parts Information
Purchase the tape locally.
Part Number
Description
Material Allowance
06337
3M Automotive Attachment Tape 1/2" x 20 yds
$0.40 Cents Per Vehicle
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2065557&from=nb#ss5-2065557">
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
C9833*
inflatable restraint passenger presence System (PPS) module, Reattach with 3M Tape
0.3 hr
*This labor operation number is for bulletin use only. This number will not be published in Labor Time Guide.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
999999994.gif WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2008 General Motors Corporation. All rights reserved.
haha, tell me about it. I know it is the smaller trucks, but come on, what kind of 'fix' is this?
Next up:
"Problem: Some customers may complain about their truck not moving when the pedal is depressed.
Solution: Shift in to gear, then depress pedal."
