285/75/r16 Or Not
This is the only time I'm going to post this topic if I can get some honest answers.
Truck: 2001 2500HD 8.1/allison crew cab long box with 265/75/R16 with Firestone air bags in rear and 4:10 gears.
The stock tire as you know was 245/75/R16 (9.64"x 30.5" tall) The 265/75/R16's (10.3"x 31.6") were on there when I got the truck. The Front sits about 2" lower than the rear and there are no rub issues. I put a set of 8" wheels on it with new 265/75/R16's and I had rub issues that were mostly fixed with some zip ties and trimming. There was still a little rubbing turning in reverse and step driveway curbs. I don't know what the offset was and I think that was the issue.
I really want to go to a winter 255/85/R16 (10"x 33.1) on the stock wheel and depending on the wheel something around 32.5"-33" tall and 11.25" wide.
I plan on putting in the Cognito leveling kit and cranking the stock keys all the way or to level. which ever comes first. Already installed the Pittman/Idler arm support kit.
I'm worried about the tall wide tire fitting without rubbing. Also about power loss (8.1, I know, plenty of power). Also I rarely tow anything over 8k lbs. And I don't tow often.
So finally, here is my question to you guys:
After you got over the coolness of the appearance of having 285/75/R16's (11.25"x 31.8") do you have any regrets on this decision?
Do you feel that your truck is searching for a gear with small inclines that were not an issue before? Is the only thing stopping you from going back to a smaller tire the looks?
Does your Truck handle poorly or at least not as good as it used too?
Do you get irritating rubbing driving into gas stations and backing in and out of a parking spot?
Can you get your bigger tires to balance?
Would you do it over again?
With the length of my truck I would like to gain some ground clearance.
I do want the looks of the bigger tire but I saw a Duramax with 8"wheels and 265/75/R16's not leveled and it looked pretty bad ass.
I know it's hard (invested money and looks great and don't want to admit wrong doing) but can you give me some honest answers/opinions on how it turned out for you.
Last tire size post from this guy........Promise.
Paulie G
Love mine. I will be replacing them hopefully over the summer with another set of 285/75-16. Fit great, no trimming, only tightened the torsion bars.
Do a search on green keys, cost is cheap and you get them right from GM. They replace the stock purple keys and you can really crank torsion bars after install. I went fron 245's to 285's on a 06 2500hd for about 50.00. JOHN
I am running 255/85/16's on my stock rims and have not had any problems with it. I have a 2002 8.1 extended cab long bed with 4.10's and have not had any problem searching for the right gear going up hills and mountain passes. I went with the larger size tires because with the stock tires I was playing road grader with the bottom of my truck where I hunt in the fall. The first time I went out, I shaved about 1/2 off the road. I upgraded to the larger tires, because I know onces it snowed and turned muddy I would probably get stuck with the stock tires and ground clearance :banghead:
well - as far as hunting for gears, seems to me the 8.1 makes so d**n much tq at highway engine speeds that it takes quite a serious hill to cause any downshift - although that experience is based on the 4spd 4LE85 in the 2500 Suburban. But still - that motor makes a mountain of tq at 2Krpm, so changing the gearing by a few % one way or the other shouldn't make a hill of beans difference.
No need to change the keys if you can get enough lift out of the stock keys. The Cognito kit is to fix other problems related to cranking the keys.
No regrets
No searching for gear (and I only have a 6.0)
The only thing stopping me from going to smaller tire is: 1. traction then 2. looks
Handles fine-no noticeable difference other than harder braking until I got used to them
Some minor rubbing at full lock (on 8 in wide wheels-don't think it happens on stockers)
they don't balance as good, but not bad either-not a problem for me
I would do it over again
I have the same truck as you with the 6.0 instead of the 8.1-CCLB, so you and I are aware of the steering with them. Being at full lock more than other trucks, they do still rub some. I guess I could fix it if I wanted to cut some more (because I am too cheap to do anything else), but they don't even rub every time-just when the front wheel and opposite back wheel are not level-if that makes any sense.
I absolutely LOVE my 285/75/16's.... I had no problem with getting them balanced at all. I DID need to do just a small amount of cutting the front plastic, not bad though, since it is already ripped apart from the plow mount... :banghead: I actually had 295's on the truck for a little while and it would very very lightly rub when at full turn. If I were you, I'd do it..
How do you like this tire size? Seems to me like this would be a good size for winter traction, still using the stock wheel. Has the extra height made a noticeable difference for you clearance wise?
No regrets
Like you said, I (we) need full turn capability. Not just in a level parking lot but pulling into the parking lots or gas stations. Whatever it might be.
I absolutely LOVE my 285/75/16's.... I had no problem with getting them balanced at all. I DID need to do just a small amount of cutting the front plastic, not bad though, since it is already ripped apart from the plow mount... :cheers: I actually had 295's on the truck for a little while and it would very very lightly rub when at full turn. If I were you, I'd do it..
I really like the 255/85/16 tires, the height increase I got was enough so that I have not had the bottom of the truck hit anything since upgrading the tires. They are also great in the snow. Went on a late bow hunt this year and was driving thorugh 12+ inches of snow with drifts without any problems. They are also good in the mud as long as you can find a bottom to it :rolleyes:
I would never go back to the stock 245's.
Gary
    CaptainDad
    CaptainDad
  • Who's Online   3 Members, 0 Anonymous, 522 Guests (See full list)
