Tranny Help....
ace2fine
step dad has a 96 1500 350 4l60E reg cab reg or short bed. my ? is how vehicle specific are the 4l60E's on this model? wouldn't one from a s-series fit with a little tail shaft swap?
If they are both 2wd, or both 4wd, you shouldn't have to change anything, as long as the S10 was a 4.3 with a 4L60E, you should be able to bolt it up and plug it in.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
