Tpms Re-learn/got It To Work
I hit 5000 miles on my 07 nbs so I decided to rotate my tires. I tried the re-learn process and followed the owners manual instructions and some of the tips that I've read here. After about 10 tries I still couldn't get it to work. I would get the horn chirp either after only doing the d/s front and a couple of times I made it to the pass side.
I was about ready to give up when I decided to go for a little ride and heat the tires up a bit. I drove about 2 miles then pulled in to the garage and guess what---I got all 4 to re-learn.
I don't know if this was just a fluke or what. I did notice that the air that came out was quite a bit warmer after driving just 2 miles so I don't know if that helped or not.
I did use my watch and let exactly 5 seconds of air out on each tire on every try. :sick:
Just thought I'd pass this on, maybe it'll work for someone else............
Rotated mine a couple of weeks back. The relearn went smoothly with horn beeps as promised. Got into the truck later and had "Service Tire Monitor System." Tried the relearn again, horns beeped correctly, DIC still shown an error. Had to take to the dealer to get error seen to, no charge. I hate to think I'll have to go to the dealer for tire rotation for the life of this thing. Maybe it'll get smarter as time goes on.
