Custom Tune
I was just wonder what you paid for a tune and what tune you have. I am still undecided if i should get a hand held programer or a custom tune thanx for your input
I got a tuned PCM from Charlie Wheatly and love it. I kept my PCM so with the tune and a pcm the total was $400. If I would have given my PCM to him it would be about $250. Check his site to see the latest on the pricing. Good luck!
x2 buddy. $400 and im keeping the stock one too
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
