Illustration Favor?
wondering if anyone has access (if it exists!) to a ext cab gmt 900 illustration showing all parts located in the Rear passenger B pillar including seat belt brakets, and the plastic panel.
my truck has been at the dealer due to a rattling in that area. apparently when un-named outsourced provider serviced my sunroof they broke a 'clip' or some part, and that is causing the rattle. the dealer is replacing this mystery part under warranty. the service person at the dealer, cant tell me the part number cuz she is unsure of it. the parts dept thought they ordered the right part last week but once it came in yesterday it wasnt the right one. it all sounds very strange to me. they have re order this piece on special order and could come in a few days or few weeks! i was hopign they coudl take the part out of the truck on the lot, get me going and when the part comes in they can put it in the donor truck. the service person told me that the clip or part was as big as my arm. they only thing my buddy can think of what it is, is what appears to a metal tube back there? (he looked at his truck and thats all he saw)
so in summation, i wanted an illustartion of this B pillar in hopes to get some insight as to what the part is and why the problems in ordering it. i hope tomorrow will shed more light on the subject.im dissapointed in my service contact as she is clueless in what part it is. it doesnt seem liek she is payign attention to what the techinician is telling her...so she is inadequate in giving me more information.
gmLogoFlat.gif Service Information
2007 Chevrolet Silverado - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 1830402 Headlining Trim Panel Replacement (Extended Cab)
Callout
Component Name
Caution: Do not attempt to repair or alter the head impact energy-absorbing material glued to the headliner or to the garnish trims. If the material is damaged, replace the headliner and/or the garnish trim. Failure to do so could result in personal injury.
Preliminary Procedures
  1. Disable the SIR system. Refer to SIR Disabling and Enabling .
  2. Remove the windshield garnish moldings. Refer to Windshield Pillar Garnish Molding Replacement .
  3. Remove the sunshade assemblies. Refer to Sunshade Replacement .
  4. Remove the roof console assembly. Refer to Roof Console Replacement .
  5. Remove the roof rail assist handles. Refer to Roof Rail Rear Assist Handle Replacement .
  6. Remove the body lock pillar trim panels. Refer to Body Lock Pillar Trim Replacement .
  7. Remove the sunroof finishing lace, if equipped. Refer to Sunroof Opening Trim Finish Lace Replacement .
  8. Remove the dome lamp, if equipped. Refer to Dome Lamp Replacement .
  9. Remove the second seat overhead console, if equipped. Refer to Roof Rear Console Replacement .
  10. Remove either the driver or passenger front seat belt assembly. Refer to Seat Belt Retractor Pretensioner Replacement - Front .
Headliner Trim Panel Retainer (Qty: 2)
2
Sunshade Anchor (Qty: 2)
Refer to Sunshade Anchor Replacement .
3
Headliner Trim Panel Assembly
Procedure
  1. Remove the front seat headrest to aid in removal of headliner from vehicle.
  2. Prior to removal, note the routing of the wire harness to aid in reassembly and to ensure proper installation.
  3. Disconnect the electrical connector.
© 2008 General Motors Corporation. All rights reserved.
2007 Chevrolet Silverado - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 1824299 Sunroof Window Replacement (Extended Cab)
Removal Procedure
tif.gifPosition the sunshade panel fully rearward.
Position the sunroof window panel to the vent position.
Remove the sunroof window panel screws from the sunroof window panel.
Remove the sunroof window panel from the sunroof module.
Installation Procedure
tif.gifPosition the sunroof window panel to the sunroof module.Ensure that the information logo stencil is towards the rear of the sunroof opening.
Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the sunroof window panel screws to the sunroof window panel.Tighten
Tighten the sunroof window panel screws to 4 N·m (35 lb in).
Adjust the sunroof window panel as necessary. Refer to Sunroof Window Height and Opening Fit Adjustment .
Inspect the sunroof window panel for proper operation.
2007 Chevrolet Silverado - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 1824856 Sunroof Air Deflector Replacement (Extended Cab)
Removal Procedure
tif.gifOpen the power sunroof window to the fully rear position.
Remove the actuators screws (1) and actuators (2) from each side of the sunroof module.
Remove the screws (1) attaching the sunroof air deflector (2) to the sunroof module (3).
Slide the air deflector rearward until it releases from the sunroof module.
Remove the sunroof air deflector (2) from the sunroof module (3).
Important: Transfer the air deflector parts to the new air deflector.
Position the sunroof air deflector (2) to the sunroof module (3).Notice: Refer to Fastener Notice in the Preface section.
Install the screws (1) attaching the sunroof air deflector (2) to the sunroof module (3).Tighten
Tighten the screws to 2 N·m (18 lb in).
Install the actuators screws (1) and actuators (2) to each side sunroof module.Tighten
Verify that the spring action of the sunroof air deflector is operating.
Close the sunroof window.
2007 Chevrolet Silverado - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 1824879 Sunroof Motor/Actuator Replacement (Extended Cab)
Removal Procedure
Important: The sunroof motor/actuator drive shaft turns in both directions and contains no limit switches. You may replace the sunroof motor/actuator with the window panel in any position.
It is only necessary to lower the headliner. Only do those step in headliner replacement that will lower the headliner enough to gain access to the part. Refer to Headlining Trim Panel Replacement .
Disconnect the electrical connector (1) from the motor/actuator.
Remove the screws (2) from the sunroof motor/actuator .
Pull straight down to disengage the drive gear from the cables housed within the sunroof cable drive tubes.
Remove the sunroof motor/actuator (3) from the sunroof module.
tif.gifPosition the sunroof motor/actuator (3) to the sunroof module.
Push the sunroof motor/actuator straight upward to engage the drive gear between the cables housed within the sunroof cable drive tubes.Notice: Refer to Fastener Notice in the Preface section.
Install the sunroof motor/actuator screws (2) to the sunroof actuator.Tighten
Tighten the screws to 4 N·m (35 lb in).
Connect the electrical connector (1) to the sunroof motor/actuator .
Install the headliner. Refer to Headlining Trim Panel Replacement .
Initialize/teach the sunroof motor/actuator . Refer to Sunroof Motor/Actuator Initialization/Teach Process .
Inspect the sunroof for proper operation.
Refer to Control Module References for programming and setup information.
2007 Chevrolet Silverado - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 1825255 Sunroof Water Gutter Replacement (Extended Cab)
Removal Procedure
  1. Important: Tape off the perimeter of the sunroof window opening before removing the sunroof module to prevent scratching.
  2. Remove the air deflector. Refer to Sunroof Air Deflector Replacement .
  3. Set the sunroof window to be in the open position of a minimum of 25 mm (1 in).Important: It is only necessary to lower the headlinder. Only do those steps in headlinder replacement that will lower the headlinder enough to grain access.
  4. Remove the sunroof module assembly. Refer Sunroof Module Assembly Replacement .
  5. Remove the screws (1) from the water gutter (2).
  6. Slide the water gutter rearward to release the retaining tabs (1) from the slots (2) in the track.
  7. Remove the water gutter (3) from the track.
tif.gifPosition the sunroof water gutter to the sunroof window track.
Seat the retaining tabs (1) on the water gutter (3) into the slots (2) in the track, and push the water gutter forward until the retaining tabs lock into place.
Ensure that all 6 tabs are secured.Notice: Refer to Fastener Notice in the Preface section.
Install the water gutter screws (1).Tighten
Install the sunroof module. Refer Sunroof Module Assembly Replacement .
Open the sunroof window to the fully open position.
Install the air deflector. Refer to Sunroof Air Deflector Replacement .
Remove the tape from around the perimeter of the sunroof window.
Verify that the sunroof is operating properly.
<script src="http://gsi.xw.gm.com/si/gsiFunctions.js"> <script> gmLogoFlat.gif Service Information
2007 Chevrolet Silverado - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 1824985 Sunroof Module Assembly Replacement
Removal Procedure
  1. Important: Transfer all necessary parts to the new sunroof module assembly.
  2. Remove the sunroof window. Refer to Sunroof Window Replacement .
  3. Remove the sunshade. Refer to Sunroof Sunshade Replacement .
  4. Remove the sunroof finish lace. Refer to Sunroof Opening Trim Finish Lace Replacement .
  5. Remove the air deflector. Refer to Sunroof Air Deflector Replacement .
  6. It is only necessary to lower the headliner. Only do those step in headliner replacement that will lower the headliner enough to gain access to the part. Refer to Headlining Trim Panel Replacement .
  7. Disconnect the front sunroof drain hoses from the drain spigot.
  8. Disconnect the rear sunroof drain hoses from the drain spigot.
  9. Remove the front to bolts located at the motor base first.
  10. With the aid of an assistant, remove the remaining bolts (1) that secure the module (2) to the roof ring.Lower and remove the sunroof module assembly out through the passenger side door.
  11. If you are replacing the sunroof module assembly, remove the sunroof motor/actuator. Refer to Sunroof Motor/Actuator Replacement .
  1. If you are replacing the sunroof module assembly, install the sunroof motor/actuator. Refer to Sunroof Motor/Actuator Replacement .
  2. With the aid of an assistant, position the sunroof module assembly to the roof ring.Notice: Refer to Fastener Notice in the Preface section.
  3. Install the 4 bolts (1) that secure the module (2) to the roof ring.Tighten
    Tighten the bolts to 10 N·m (89 lb in).
  4. Install the remaining bolts at the motor base.Tighten
  5. Connect the front and rear drain hoses to the drain spigots.
  6. Install the sunshade. Refer to Sunroof Sunshade Replacement .
  7. Install the headliner. Refer to Headlining Trim Panel Replacement .Verify that the electrical connector is connected to the sunroof motor/actuator.
  8. Install the sunroof window. Adjust as necessary. Refer to Sunroof Window Height and Opening Fit Adjustment .
  9. Initialize the sunroof motor/actuator. Refer to Sunroof Motor/Actuator Initialization/Teach Process .
  10. Install the air deflector. Refer to Sunroof Air Deflector Replacement .
  11. Install the sunroof finish lace. Refer to Sunroof Opening Trim Finish Lace Replacement .
  12. Inspect the sunroof for proper operation.
2007 Chevrolet Silverado - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 1830307 Body Lock Pillar Trim Replacement (Extended Cab)
Callout
Component Name
  2. Remove rear side door sill plate. Refer to Front Side Door Sill Plate Replacement .
  3. Remove rear window lower molding. Refer to Rear Window Lower Garnish Molding Replacement .
Body Lock Pillar Garnish Molding Retainer
2
Body Lock Pillar Garnish Molding Plug
3
Body Lock Pillar Garnish Molding Screw
Tighten
2 N·m (18 lb in)
4
Seat Belt Assembly Anchor Nut
Tighten
70 N·m (52 lb ft)
5
Front Seat Shoulder Belt Retractor Assembly
6
Body Lock Pillar Garnish Molding Assembly
Tip
Route seat belt through garnish molding.
7
Body Lock Pillar Garnish Molding Retainer (Qty: 3)
8
Body Lock Pillar Garnish Molding Clip
2007 Chevrolet Silverado - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 1830242 Rear Seat Belt Retractor Replacement (Extended Cab)
Callout
Component Name
  1. Disable the SIR. Refer to SIR Disabling and Enabling .
  2. Remove rear bench seat. Refer to Rear Seat Replacement .
  3. Remove the rear window lower molding. Refer to Rear Window Lower Garnish Molding Replacement .
  4. Remove rear door sill plate. Refer to Rear Side Door Sill Plate Replacement .
  5. Remove the body lock pillar trim panel. Refer to Body Lock Pillar Trim Replacement .
Rear Seat Belt Anchor Plate Nut
Tighten
45 N·m (33 lb ft)
2
Rear Seat Belt Upper Guide Bolt
Tighten
45 N·m (33 lb ft)
3
Rear Seat Belt Guide
4
Rear Seat Belt Retractor Bolt
Tighten
45 N·m (33 lb ft)
5
Rear Seat Belt Assembly
Tip
Route seat belt through slot in body lock pillar trim panel.
Not sure if this really helps, but I went ahead and posted most of the diagrams that are associated with the sunroof, also included the rear passenger section. I do not have access to the parts information directly (for part number or usage) but Rich (MS3DALE) does have access to that system
WOW Mike....Props to you not only in this thread but on the many others. It seems like your always ready to help out a fellow forum member either its with TSB's Vin and build sheets and now this kudos (sp) to ya!!! :)
I do it because I know there will be a day when I will have the most retarded question that has a simple answer....and someone will extend me the same courtesy. Thanks to everyone here for their help with my truck projects......it aint easy for a college student though :)
Mike, you def help out a lot and you fast responses, TSB postings, and the effort you put in is greatly appreciated! especially last week when i PM you for a mstery TSB that i thought at the time was the issue. props to rich as well as he has helped me a bunch of times in the past with part numbers and build sheets.
the pics do help, i should have stated it was an aftermarket sunroof. but the B pillar pics give me an idea , in the the second to last diagram that you posted, i wonder when my service ocntact said clip, she meant the whole entire plastic panel that fits over the B pillar (i think its refered to in the diagram as a 'Body Lock Pillar Garnish ...'
perhaps the have to order that entire panel cuz a single clip on it broke..?
thanks again!!
