Wind Noise From Driver's Side Door
I washed my truck the other day & now I notice alot of wind noise coming from the top of the door. Are the rubber seals something that normally wear out?
How tough are they to replace?
No wind noise prior to the wash job? Very Strange.....
Be sure to check that one of the weatherseals isn't loose or that the window isn't dislodged from the track when rolling it up. These synthetic rubber seals should last a long time with proper care. Use a silicone lubricant regularly to condition them. Not sure about replacement cost, but I assume you'd have to see a dealer and they can be crooks.
Yea, I never noticed the wind noise before. This past weekend I washed the truck & wiped down all the way around the door jamb & now I am getting the noise. I checked the rubber yesterday & it all looks good & in place. I will double check it though!
