Upgrade 4x4 To Z71 4x4
Hey guys,
Just wondering if there is a way to upgrade my 4x4 into a Z71 4x4.
I've already got the trailering package, which I think includes the same shocks as the Z71.
Think you just need the Skid Plates, the Larger shocks, the front Jounce bumpers (Goofy little rubber things on the A-arms) and the sticker on the bed.
If your off the pavement alot its not really worth getting all of the components needed. I say just get the rear decals if you want the look, but its only larger shocks & the jounces, & I could be wrong but all Z71s may have the G80
I definately wouldn't get the decals. :lol: Just get some bilstein shocks and call it a day. It'll be just as good if not better (since ya got the bilsteins), than any other 4x4 truck with or without a Z71 sticker.
Geeze, if that's it I'll just stick with the 4x4 and buy some Z71 stickers. My truck has a real nice ride to it (everyone compliments how nice it rides) so I dont think I'd want to ruin that with some new shocks.
I can just buy those funny stickers straight from the dealer, no?
Z71 Off-Road Package
The Z71 Off-Road Package — available on 1500 1LT, 2LT and LTZ models — is specifically designed with increased capability and durability when you want to travel beyond where the pavement ends. In addition, the 46mm high-pressure gas-charged shocks offer increased damping to help make off-road journeys more comfortable. Additional Silverado 1500 Z71 features include:
  • Z71 Off-Road suspension
  • 17-inch on-/off-road tires
  • Skid Plate Package
  • High-capacity air cleaner
  • Off-road jounce bumpers
  • Z71 badging ("Z71" on 2WD models; "Z71 4x4" on 4x4 models)
  • Automatic locking rear differential
  • Available 18-inch aluminum wheels and tires, which are only offered with the Z71 Off-Road Package
Got the Tires, Air Cleaner, Locking Rear Diff, and Gas Charged shocks (I dont know if they are 46mm though)
Missing Skid Plate, Off Road Jounce Bumpers, And the stickers
So whoopee. I'll get the stickers and call it a day.
edit: Phoned the dealer and my truck already has the 46mm gas shocks -- same as the Z71. He also recommended just to get the stickers.
edit edit: Stickers are $20 apiece. I'll pass.
Then what is it you wanted to do?
Are you sure you have the right wheels? I thought those style wheels "only" come on Z71's. Maybe its only the 18's that are exclusive to the Z71 package. Heck i don't know..
Wanted to upgrade my truck to a Z71 - but realised that there isn't much difference.
Yeah, the 18's are exclusive to the Z71 package, but you can always just order them from the dealership anyways. A buddy's truck has them and its not a Z71.
:lol: sticker envy :)
Not for $40 plus taxes.
Maybe I should just get Harley Davidson stickers and say its a new type of motorcycle. :cool:
If ya really want some stickers, I'd try to find some cool "Off-road" or similar decal. Something, "unique." :flag:
Definitely don't add the stickers. If you have 4X4 on there already, peel 'em off. These trucks look much better without some cheap vinyl slapped on the back. Hell, half the time I see them they aren't even on straight.
Ehh...that's just a matter of opinion buddy. I like the Z71 stickers :lol: And the 18" Z71 alloys as well!
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
