Swithced Power Source
Does anyone have any idea if there is a fuse that is switched so that it only has power going to it when the ignition is on? Or what wire i could tap into to get this power? This would be on a NBS silverado.
Thanks in advance for the help. I know someone on here will have the info for me.
look in your fuse box for an 12v receptacles on the dash they are switched. I do not have my owners manual but then as long as you are not drawing more than 10A you could get one of those piggy back fuse holders to add whatever you are adding.
