Replacing Mirrors Need Help
Guest Riggs
Guest Riggs
Alright well i bought some manual newer style mirrors that were on the 95-98 trucks. i just had the big metal mirrors on now. they are really ugly ans stick out like a sore thumb, so i thought it was a good change. (btw i moved a couple things around and moved the cb antenna's off the mirrors.)
well i took the black plastic trim cover off, and the two bolts holding the mirror on and there was nothing. i didnt see any other bolts holding this thing on, i have no idea how to take it off or even put the new one on for that matter. it almost looks like i take the door panel off and there will be bolts coming from the inside out but i only seen one.
the mirrors i bought said they would work on 88-98 trucks so they have to bolt up somehow.
Please help me.
Thanks. :crackup:
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
