Sagging Door?
Is there any way of adjusting a 99 obs door? I recently replaced the inside door handle and since then it won't always open with the inside handle. sometimes I need to use the key to open the door even if it hasn't been locked. I still have the door panel off and everthing looks good. I just sprayed lithium grease on the parts and I can sometimes use the inside handle. I noticed that the door lifts up when it is shut. Could this be my problem?
i dont think the sagging door has anything to do with the latch. My guess is something isnt hooked back up the same.
as for the sagging door, its probably time for some new pins and busings.
