Putting New Motor In
Finally putting the new motor back in. Any comments or suggestions before i put it in. Probaly going to do it by my self. Not to mention i am putting the Engine and Tranny in at the same time :P
Just as long as you have dismantled the radiator and radiator core support you should be ok! While you are at it take the fenders and wheel wells off to make it really easy!
Plus dont forget to run it for a couple of minutes just to make sure its running right and than run it for a good solid 20 minutes just to check water, engine temp, fluids, timing, ect!
Allright thanks ya i took the radiator core support off to because for the tranny and motor to go in it was a pain
Assuming this is a 350 you are working on and that the motor is new or a reman, as Brian has said, run it at 2000 RPMs for 20 mins alternating the rpm slightly during this period. Make sure it is not running hot and you may want to have a good shop fan blowing into the radiator. You do not want it at idle during this period.
This 20 mins is critical to the break in of the camsahnft and lifters. I also like to prime the oil pump with a drill before installing the distributor. This way you know all of your oil passages are already full of oil. You can buy a rod that fits into the top of the oil pump and the other end fits in a drill chuck. You can also make your own.
The motor has already 500 miles on it. Is it necessary to prime the oil pump? And yes this is a 350 4 bolt main with a mild cam work done . Also how do i find my TDC ?
    • I can relate. 3 years ago I did that on my Avalanche. I was sore for a week. The only maintenance I do myself now is drop and fill on the transmission on my Honda’s. It’s just too easy. My yard work with my walks in the morning will be enough now I passed 70. The contributing factor is the heat in Texas. You just have to pace yourself.
    • I am sorry if this was misleading. That was a document attached to our most recent work order number (Doc# 7105804) that summarized all the current updates. These programs were ‘redone’ in the past but these versions dated 4/1/2016 were the ones that actually made all of the problems disappear. These programs were relayed to the dealer from the technical services group at GM. Here is the exact wording on the last work order:   “Front view camera reprogramming with SPS. A new version of FCM software was released to the service dept. In addition to providing general robustness and stability enhancements, this update includes all enhancements from previous software version releases. SPS camera and calibrate camera. OLH to perform extended camera relearn procedure after camera calibration. Would not take with first GDS learn. Front camera SPS – BDYZ333157450 GDS2 – camera road calibration performed 2810835 Front view camera reprogramming with SPS LT 0.6 OLH – extended camera relearn procedure OLH LT 1.5”   I got the truck back on 4/8 – since that time it has been great no problems whatsoever. The lane keep assist, active cruise control and AEB all work very well around town and at highway speeds up to 80mph. During this time I had been away for a week and purposely let the battery sit without a batter tender. Even with the battery a bit lower there were no problems exhibited. I really think this one has it fixed after dealing with these issues over a couple of years. These new programs and relearn process when completed seem to make all the parts (and newer replacement parts) ‘talk’ to each other without any glitches. Hope this helps
    • I turned 72 today. My day began with a trip to the pharmacy to pickup meds for me and the dog and then a stop at my chiropractor before heading home. Once home I started the job of replacing the rear brake pads and one rotor on our 2018 Silverado which will probably end up taking me 3 days to finish, gotta pace myself you know. Sometimes I question myself on why I still do most of my own repairs but if I wasn't then it's more than likely I would be sitting in front of the TV all day. It seems like the list of things I need to do gets longer no matter what I accomplish. I'm not complaining but being retired was so much easier when I was 62.   Peace
    • google "bathub failure curve". Basically, any part of the vehicle can fail at any time.  It starts off as being more likely (early failure), then the failure rate goes down (but does not go to zero), then it goes up over time because it wears/ages out.
    • I went from every other day to about once in five since the rain abated. I'm not unhappy about that. Took most of the month for the ditches to dry enough to mow.
