Exhaust Question
So I am thinking about getting the Magnaflow muffler in the link here:
http://www.magnaflow.com/02product/shopexd...main&id=494
I'm thinking I will have a X-pipe installed to the inlet side and then have the Y pipe coming from the cats cut and led into each side of the X-pipe.
This will be my first modded exhaust and my knowledge only comes from what I have read on forums. Just wondering your opinions on what this will do to my Torque and HP. Also what size pipes should I go 2.5 or 3?
Suggestions please!
Lol forgot to specify.... I have a '08 Silverado 6L
there is no need for an X pipe on a di/do muffler, Magnaflow has an internal X pipe made into that muffler already. It will be quiet but loud when you want it though
Darren beat me to it :uhoh: there is a ton of info on 6.0s and exhaust on this site if you search it...there is a lot of concern over the drone for that engine, so the Corsa fans will chime in soon :) good luck with your exhaust decision
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
