Fold-a-cover / Peragon Questions
so i was dead set on ordering a peragon bed cover but then started doing some research.....i love the way the peragon looks, but am wondering maybe fold a cover would be better overall....
i like how fold a cover opens at the back, but your losing about 12"s or so of bed space being that it doesnt fold completely up like peragon....i cant seem to find a whole lot of info about fold a cover, not even on theire website which is pretty sad....what material is it made out of?? peragon says it's not completely water proof, im sure fold a cover isnt either, but for you guys that have them out there, how much water leaks in?
recommendations from people that own them would be appreciated, ill be buying soon!
thanks
i did noitce the fold a cover is made of steel/aluminum.......how easy are they to take off also if anyone out there knows
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
