For Sale- Projector Headlights
I have a pair of Projector Headlights for sale, They are the right and left headlights with bulbs included minus the highbeam bulb which is stock and can be taken from stock headlights and put into the high beam part of the new lights, Anyone interested is asked to message me or email me at [email protected], I am looking to get anywhere between $180-$200 + shipping for em. Pictures available upon request, these are clear/chrome.
