Dic Message
boss rosco
I have a 2005 chevy silverado Z71 crew cab. I had a dtc P0455, and a DIC message
"tighten fuel cap". I replaced the fuel cap, and had the sytem smoke tested. We found
the cannister was bad, so we replaced it,and reset the ecm. Now, I'm NOT getting a
dtc code or "check engine" light anymore, but the DIC still says "tighten fuel cap" quite
frequently. My local mechanic said the BCM(Body Control Module) probably needed to be reset. He checked it and said it wasn't showing any codes or faults. So now I'm clueless
of what to do next. Any help would be greatly appreciated. By the way the engine is a 5.3, auto trans.
gm with a po455 if i had i nickel everytime i see that,
your need to check the vent valve operation is it holding pressure ??
or just replace it
bcm has nothing to do with it
    • Real Truck handles the warranty via GM.  We don't submit a warranty claim with GM, we have to submit it with Real Truck with a specific email/phone number.  Real Truck determines if the issue is covered or not based on the issue and pictures submitted.
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
