Service History Report?
Ceede
Can someone run me a Service history report with details on anything done to this truck? I'm thinking of buying, but want to know nothings wrong. It's an 07 with only 4100 miles on it. Seems too low. Thanks in advance!
2007 Chevrolet Trailblazer LT VIN# 1GNDT13S372208505
VIN : 1GNDT13S372208505
VEHICLE INFORMATION Merchandising Model : CT15506 -2007 TRAILBLAZER LT 4WD
Warranty Start Date : 07/31/2007
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : RON HULETT AUTOMOTIVE, INC.
PO BOX 410
CAMDENTON , MO 65020-0410
(573) 346-7272
Selling Source : 13 - CHEVROLET Site Code : 03414
Business Associate Code : 111441
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS Vehicle Has No Current Record Of Outstanding Campaigns
SERVICE INFORMATIONAL ITEMS Type Number Description Posted Date Status EI 07279 HORN INOP FROM STEERING WHEEL HORN PAD - REF. TSB 07-08-54-001.
11/21/2007 See Bulletin EI
08023 PAINT PEELING FRONT/REAR FASCIA - REF. TSB # 08-08-62-001 01/18/2008 See Bulletin
ON STAR AND XM SATELLITE RADIO INFORMATION OnStar Equipped Yes OnStar Status Active Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
XM Equipped Yes XM Radio ID MZV7R0W0 XM Status Inactive Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677). APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer 36/36000 BUMPER TO BUMPER LIMITED WARRANTY 07/31/2007 64 miles 07/31/2010 36064 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 07/31/2007 64 miles 07/31/2013 100064 miles 96/80000
FEDERAL EMISSION CATALYTIC CONV. AND PCM 07/31/2007 64 miles 07/31/2015 80064 miles 60/100000
POWERTRAIN COVERAGE LIMITED WARRANTY 07/31/2007 64 miles 07/31/2012 100064 miles 36/36000
FEDERAL EMISSION 07/31/2007 64 miles 07/31/2010 36064 miles
CLAIM HISTORY R.O Date R.O Number Type Labor Operation Odometer Reading 01/03/2007 A08505 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
THANKS gm-master-tech!! That all looks good to me. I guess I'm gonna stray from, dare I say, FORD and buy this one for the wife. :D This will be my first Chevy and I'm 40 years old! Of course, it's for the wife, I still have, shhhh, a Ford. :D Hey, we can't all be perfect!
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
