Low Coolant Light
About once a week my low coolant light will randomly come on. I check the level and it's fine. Anybody know what's going on. truck is 00' w/ 5.3. Thanks for any help! --Brad--
If it is full of coolant when you get the light, then you might just have a coolant sensor issue. The 5.3 has had some water pump leakage issues but luckily it does not suffer from the notorious GM intake leak problem.
Make sure it's really full and get the coolant level sensor checked out. You want it to work if it ever actually gets low!
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,105 Guests (See full list)
