Speed Limiter
I was on a road trip this weekend, in my 1999 Suburban (2wd, 5.7). I went to pass this a$$hole that was driving at 60 on the left lane, and when I went to pass him, he sped up, so I get behind him and he slows down, after a while, I start getting pissed so I go to pass him again, he speeds up :chevy: I floor the 'burb, but right after 95 mph it bogs down.
Is there any way to get rid of this? I have had this vehicle since new, it now has 142k miles on it, and this is the first time I have ever taken it that fast. I am not a careless driver or a speed freak, but there are situations that warrant you to go fast, and I don't like the fact that this vehicle wont let you.
So I ask again, how the heck do I disable this?
Thanks
Yup. Get a tune.
And make sure your tires are rated for that speed.
Oh, and always have a big booger handy for when you get in front of the douchedriver :chevy:
had that happen to me by some guy in a duramax one time with my tahoe, i had the limiter set to 128, he was a tru **** kept trying to wreck me. hitting his damn brakes he almost made me hit a semi...
