Low Beams?
I just got on the site and i'm looking for some help. I have an '03 Z-71 and the other day when i got in my truck i could not get the low beams to come on... All other lights work just fine. The fuses are good what do i check next????? Please help i need my lights...
Check that your Ebrake is fully released, though you'd probably get some "Binging" if it was enabled or engaged. Also check your Light Sensor. Perhaps it's gone bad or something. The light Sensor that's tied in with your Automatic Headlights.
What happens when you pull back on the Turn Signal switch? Do the High Beams Flash???
Also, make sure you don't just eyeball the fuses...check'em with a continuity meter or multimeter...I've found them bad before when they "looked" good....
    overspeed
    overspeed
  • Who's Online   5 Members, 0 Anonymous, 1,110 Guests (See full list)
