Hood Stops...i Think
Pretty sure...no...I know the first owner had a fender bender. And when they replaced the grill, and hood, and driver side fender. They...bodyshop I think...didn't put the hood stops back.
By chance, anybody have any of these lying around the garage :)
If not, how's about a part number! Seem's the locale auto shops don't carry them, and they tell me I'll have to visit
the stealer! :)
GM Part number is 11588868
Also...You mispelled "dealer"...Its with a "d",not "st" :):) Some of us on here work at a dealer :)
Sorry about that :) , ....now I feel bad...you came through for me twice today!
Thanks again MS3DALE. If your ever up in my neck of the woods let me know...I got a nice steak dinner for ya!
