Another Wont Go Into 4wd Thread
ok so this has been a ongoing problem that Ive been ignoring, now that spring is here its a good time for some wheeling I want to get this fixed, so since the first of february my truck in the sig wont go into 4wd. Ill hit the 4hi button (autotrac case) and i can hear the transfer case try and shift but it wont complete( the button blinks from 2wd to 4hi for a couple seconds then back to 2wd) I keep trying and it wont work, eventually the lights turn off and the service 4wd light pops on, But if I only try the button once or twice the service 4wd wont come on. I dont think its the actuator cause I had it out while my dad pushed the 4hi button and the actuator came out but then went right back in, should it do that? Or is something else not working right causing the actuator to go right back in?
In my old body style 99 it was the actuator. There were 2 one in the diff and one in the transfer case. Only one was bad so it still sounded like it was engaging. It was about $100 for the part and 5 minutes to put it in.
A transmission/drive train shop told me today that it was more then likely my encoder motor
    • I had a similar but different response when I talked to the service manager where I bought my truck in that he said GM corporate won't allow them to lower the placard pressure setting as they would get their hand slapped but that of course they have the ability to make that change. His suggestion was simply go to a tire dealer or third party shop that is willing to reset the pressures lower. However I chose to buy a tpms tool and partly based off of this very forum as it had been proven to work on the 2024 model ( Global B system ) and while I could have paid lots for a full two way diag tool, I didn't want to spend that much and bought the recommended Autel TS 508 and it will reprogram the 2025 model and assume it should do the 2026 as well. However the tool is rather proprietary to reprogramming Autel tpms sensors so that is a function I will never use, where as a real two way scanner would have many uses but also have yearly subscriptions etc where this 508 is free updates for as long as they put updates out for the unit. In any event it worked to lower the placard pressures and I often use it to adjust my actual tire pressures although will check with a mechanical gauge as well sometimes just to make sure that tires tpms sensor isn't lying to me.    My suggestion is either buy a tool that you know will work to adjust the system or start out by getting the tire shop you bought your tires from to reset your truck and if after that you still want a unit to do it yourself, get one at that point.
    • Here is an image of a quick Google search about these tires on my truck and it's exactly same psi recommendation the Toyo tires company gave me!    I'm not looking for anyone else recommended psi or anything, I'm just looking to see if anyone knew a way to get rid of the factory low psi warning light, because I'm not running high psi and ruining my tires when I'm not towing!
    • 60psi front and 80psi rear But I am not running the factory tire brand or size! it's load range F Toyo tires
    • Open the driver's door jamb.  What do the cold tire PSI ratings on the tire placard show?   I'm not saying to run it to those numbers, but I would like to know what it says.
    • Well, okay then...
