Steering Wheel Vibration 2006 Silverado 2500 Hd
mark97213
For about a year, I've been feeling a slight /clunkingvibration in the steering wheel at low speeds when slightly cranked to the left. It isn't really a worn ball joint type vibration, it is just felt at low speeds and actually, you can hear it.
Dealer, Tire shop, noboby could find anything wrong with the suspension. But it finally occurred to me to pop the hood and wiggle the Steering rod, up around the knuckle before it goes into the firewall, and sure enough, there is play in it. There shouldn't be any play in it should there?
I'm taking it to the dealer on Tuesday and I'm wondering if they will just blow me off, or if a replacement is even available.
Has anyone else had any issues with this type of clunking/vibration in the steering wheel?
How much play is there? The steering shafts will flex a little. Is the bolt for the intermediate steering shaft loose?
Well, there isn't a lot of play, not much at all, but what makes me thing there is some excessive play is that I can actually hear the movement, similar to slight clunk clunk clunk, which in turn seems to be amplified in the steering wheel when I drive it, I definitely feel it.
On the intermediate shaft, is the bolt undeath the boot where it couples the the rest?
I had the shaft replaced on my 2005 HD and it took care of the problem, for a while. Is doing the same thing again which makes me wonder if i got another bad shaft or it was only greased instead of replaced (there was a TSB on this shaft problem, i believe) I hear it is a common occurance and GM specifies a replacement shaft.
    contrabombarde
    contrabombarde
  • Who's Online   4 Members, 0 Anonymous, 1,395 Guests (See full list)
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
