Power Window Problems
Does anyone have any idea how to put the power window cable back on its pulley inside the door panel? My window will not go up or down when i press the button but i can push it up or down by hand. Any ideas anyone? i got the poor panel off, but the one end oy the cable is not on the pulley.
  • 1 month later...
I had the same problem with both of my windows. I ended up taking them to my mechanic and having a new window regulator/motor installed. In order to fix it, you need to remove the glass from the track and then monkey around in the door. I didn't want to go through all of the cuts and stuff like I did when I changed out the door handles. Should be around $200 per door to fix it at a mechanics.
    liddlera
    liddlera
  • Who's Online   5 Members, 1 Anonymous, 552 Guests (See full list)
