Another Odd Buzzing Interior Noise
I have a buzzing noise which sounds like it is coming from the lower dashboard directly in front of the driver's seat. It is definitly a harmonic buzz, and is pretty consistant when the engine is running. Thinking it was the dash itself, I took off and put back on a lot of the plastic pieces looking for something loose.
While doing that, I was in the passenger seat leaning over, and the noise was not there. I realized that the noise only occurs with engine running, when my feet are on the floor, specifically my right heel near the accelerator. When I lift my heel, the noise stops. When I put it back down, it starts again. I am really not making this up.
Thoughts? Thanks.
Thoughts? Thanks.
Take a rubber mallet and whack the crap out of the floor pan where your feet rest. Yeah I know it sounds like a joke but I am serious. If the weight of your foot makes the sound go away, I would imagine distorting the metal just a bit with a mallet would stop it altogether?
I bet you try it.
I am going to try it. I had a muffler heat shield with the same issue and that cured it. Maybe I will look at it from underneath for anything rubbing the floorpan...then whack it.
Jim, you got me thinking about the floorpan, so I crawled underneath (mallet in hand). I had also read that someone had installed a throttle spacer, and his fuel lines were moved up against the firewall. The TBI pulses translated through the lines to the firewall and dash. Sure enough, a fuel line had popped out of its rubber grommet and was touching the floorpan. Pressed it back in, and noise is gone.
Thanks for the vector towards the floorpan. Easy fix...great forum!
    Camyon
    Camyon
  • Who's Online   6 Members, 0 Anonymous, 1,204 Guests (See full list)
