Help New Truck Pulling Small Trailer
jerr529
I hope im in the right section for this question> I have a 08 chevy silverado ext cab with tow package. I received it May 1 , my problem im supposed to go on a trip next week the 15thof may.Unfortunately ill only have about 300miles on it by then. They usually want you to ride AT LEAST 500 MILES before you attempt to pull trailer. Now my trailer is a POPup weighs 2400 lbs loaded, my truck is rated at 7800 lbs to pull so im way under my limit ,i have pulled with smaller veh and you hardly know your pulling anything. I guess what im asking is it ok to do im very carefull driving i dont really exceed speed limit i fig maybe at times ill be doing 60mph, driving maybe no longer then 1hour and half stop and drive another 45min that will be the distance ill be driving , Any tech people think that i will be ok , I dont know why that magic number 500 miles is set in stone , i dont drive hard , any input i would appreciate
jerry
I would not worry about it, as long as you aren't trying to hot dog it it'll be fine. I pulled an 8x12 landscape trailer on both of my last full-sizes before the 500 mile "break-in" and neither has or had any transmission or driveline problems.
u will be fine, i think its very precautionary and they might be more worried about the intial 'break in' for the Brakes...
Thanks i also forgot to mention that my trailer has own brakes, i have a prodigy brake controller , brakes on trailer is law in ny
jerry
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 1,376 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
