I have a 97 Sonoma and the a/c system is acting a little funny. The blower goes on and off at will. The a/c compressor still stays on, and cools. I replaced the blower and that seems to have fixed the problem of the blower going on and off at will. However the air is still being directed to other places than what is selected. Lots of cool air comes out of the defroster but not much out the vents.
Anyone have a similar problem?
Thanks
Doogie
yea my thought too. However I do not see any small vac lines anywhere. Looks to be electrical. Not sure though any one here got experience with this type of problem?
Not necessarily a small vacuum line, could be a vacuum leak anywhere.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
