Truck Rattles
I have a 04 silverado 1500 4x4 crew cab. When driving down the road the truck rattles when I go over bumps, if I touch the brakes it seems to go away. Is this a common problem and is there a fix for it. Thanks
Can you tell about where the rattle is coming from? I had this problem with my 07 and still do somewhat.
I thought that my rattle sounded like it was coming from inside air vent. When I had my door repaired I told the dealer about it and they said theyd take a look at it. They fixed it and said it was just a bolt coming loose inside the dash part under the steering wheel. That was a few months ago and now I am starting to hear it again.
I found that when I'm driving down the road and I can hear the rattle, if I push upward on the piece under the steering wheel the rattle goes away. So I know it's gotta be that bolt coming loose again. Try this with your '04 next time you hear your rattle and see if she shuts up. :lol:
My friends 01 silverado had a squeek, under the dash, that would go away, when you put pressure, on the steering column. I looked at it and found the bolt, to the dash support, just right of the gas petal, next to the carpet, was half way out. Dealer quoted him $400.+ to fix "steering column part". If your noise is outside, check the o2 sensor on the driver's side, before the cat. The washer rattles at 800-1000 rpms sometimes. Get under the truck and tap around, when it is cold, and listen for the noise. Also, my sway bar bushings make a noise, when I roll over speed bumps.
I found an old thread from 04 that sounds like the same thing my truck is doing. I tried to open it and it won't open for me. It is called "Lube intermidiate shaft guide". Maybee someone can refresh it.
I have a 2004 sierra and when I go over bumps sometimes I have a rattle that sounds like it comes from underneath my truck. I wonder if mine is the intermediate shaft?
I checked the brake pads and the seem tight. I drove it again and it seems to be the pads, like I said before when going over the bumps the noise goes away if I slightly touch the brake pedal.
