hey guys
I have a 02 sierra 1500 for 7 months now
its a 4wd / 4.8l / manual trans but i dont know abaut the rear diff !
can anyone help me to know the gearset ratio and if its an open diff ar a limited slip
please!!
Look on the RPO sheet in the glovebox. If you see the code G80, it means you have the locker. Give me a sec to dig up the axle ratio RPO's.
EDIT: Here they are:
GU5 - 3.23:1
GU6 - 3.42:1
GT4 - 3.73
GT5 - 4.10
EDIT 2: I think what the guy above me is trying to say is please resize your sig pic so that it doesn't distort the page. :D
Why are we all yelling?
And I must know, based on the signature picture, is the reason you are wanting to know to rebuild the rear end? :lol:
:D:oops::lol::lol:
From the looks of you picture, I say that you have the g80 rear end, but not for long, if that occurs daily! I had a 1992 gmc z-71, 350 v8, 5 speed manual, with 33x12.5r15 tires, when I was 20 years old, and went through a rear end, and the 2h gear, in the transfer case, covered under warrentee. When stuff breaks, and you got to pay, it's not fun anymore!
Thanks everyone the gear set is 4.10
But i still dont know abaut the diff if its an open or limited slip
I didnt see a g80 on the RPO sheet
Its factory open, could still have an aftermarket locker in it.
I dont tink so becuse i know the first owner and he is not intrested in such tings
Got the VIN?
Got the VIN?
here it is
1gtek14vx2z323949
Got the VIN?
here it is
1gtek14vx2z323949
You do not have "G80" locking differential.
Heres the build sheet and warranty service history on it.....
GM Vehicle Inquiry System
Summary
VIN : 1GTEK14VX2Z323949
VEHICLE INFORMATION
Merchandising Model : TK15703 -2002 SIERRA 1500 4WD REG CAB PICKUP
Warranty Start Date : 09/11/2002
BARS Order Type : 60 - RETAIL - SOLD
Delivering Dealer :
ALJOMAIH AUTOMOTIVE - DAMMAM
P.O. BOX 224
DAMMAM , SA 31411
Selling Source : 72 - NAES
Site Code : 71592
Business Associate Code : 160840
Service Contract : No
Branded Title : No
Warranty Block : No
PDI Status : Ineligible
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
RC 04007 TAILGATE SUPPORT CABLE N/A Closed
RC 05042 PARKING BRAKE SHOE AND DRUM CONTACT N/A Closed
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/60000 IPC BUMPER TO BUMPER 09/11/2002 0 kilometres 09/11/2005 60000 kilometres
36/60000 IPC CORROSION 09/11/2002 0 kilometres 09/11/2005 60000 kilometres
36/60000 IPC EMISSION 09/11/2002 0 kilometres 09/11/2005 60000 kilometres
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
02/05/2006 A03972 # V1241 - 04007 - INSPECT TAILGATE SUPPORT (NO REPLACEMENT) AND INSP 97822 kilometres
02/05/2006 A03972 # V1371 - 05042 - INSPECT PARK BRAKE LINING - 1500 SERIES ONLY 97822 kilometres
10/03/2004 A02758 # K2757 - SYNCHRONIZERS - 5TH-REVERSE - R&R OR REPLACE 47091 kilometres
09/18/2004 A02726 # L1200 - FUEL TANK FUEL PUMP MODULE REPLACEMENT 44477 kilometres
08/14/2004 C02078 # N0110 - BATTERY - ONE - REPLACE 40526 kilometres
07/26/2004 A02538 # K0610 - CYLINDER, CONCENTRIC SLAVE - REPLACE 37964 kilometres
© 1998-2005 General Motors Corporation. All Rights Reserved.
Claim History
CLAIM HISTORY
Repair Order Date : 02/05/2006 Repair Order Number : A03972 Odometer Reading : 97822 kilometres
Serviced By : ALJOMAIH AUTOMOTIVE - DAMMAM
P.O. BOX 224
DAMMAM, SA 31411
Site Code : 71592
Cycle Date Cycle Nbr Case Type Labor Operation Part Auth Code Person Code Line Total Comments
03/03/2006 670 01 # V1241 - 04007 - INSPECT TAILGATE SUPPORT (NO REPLACEMENT) AND INSP N/A N/A N/A $ 10.20 N
03/03/2006 670 02 # V1371 - 05042 - INSPECT PARK BRAKE LINING - 1500 SERIES ONLY N/A N/A N/A $ 20.40 N
Repair Order Date : 10/03/2004 Repair Order Number : A02758 Odometer Reading : 47091 kilometres
P.O. BOX 224
DAMMAM, SA 31411
Site Code : 71592
11/12/2004 534 01 # K2757 - SYNCHRONIZERS - 5TH-REVERSE - R&R OR REPLACE 88934824 N/A N/A $ 1448.18 N
Repair Order Date : 09/18/2004 Repair Order Number : A02726 Odometer Reading : 44477 kilometres
P.O. BOX 224
DAMMAM, SA 31411
Site Code : 71592
09/24/2004 520 01 # L1200 - FUEL TANK FUEL PUMP MODULE REPLACEMENT N/A N/A N/A $ 51.43 N
Repair Order Date : 08/14/2004 Repair Order Number : C02078 Odometer Reading : 40526 kilometres
P.O. BOX 224
DAMMAM, SA 31411
Site Code : 71592
09/17/2004 518 01 # N0110 - BATTERY - ONE - REPLACE 78A72 N/A N/A $ 71.50 N
Repair Order Date : 07/26/2004 Repair Order Number : A02538 Odometer Reading : 37964 kilometres
P.O. BOX 224
DAMMAM, SA 31411
Site Code : 71592
08/13/2004 508 01 # K0610 - CYLINDER, CONCENTRIC SLAVE - REPLACE 12574147 N/A N/A $ 174.09 N
CHECK HISTORY
Vehicle Has No Associated Check History.
Vehicle Build
VIN 1GTEK14VX2Z323949
VEHICLE BUILD
Gross Vehicle Weight Rating : 2769 kg (6106 lb)
Order Number : 813193
Build Date : 05/15/2002
Build Plant : 12Z03
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AE7 - SPLIT BENCH RECLINING FRNT SEAT
AU3 - ELECTRIC SIDE DOOR LOCK CONTROL
A04 - TINTED WINDSHIELD
BAG - EXPORT PARTS PACKAGE
B30 - WHEELHOUSING & FLOOR CARPETING
B32 - FRONT FLOOR MATS
CU8 - COUNTRY - SAUDI ARABIA
C5M - GVWR: 2767 KGS (6100 LBS)
C60 - AIR CONDITIONING SYST, MAN CONT
DE2 - OSRV DIRECT CNTRL BLACK MIRRORS
EXP - EXPORT PROCESSING OPTION
E2C - ORDER TO DELIVERY - EXPEDITE
E63 - FLEETSIDE BODY EQUIPMENT, PUBX
FK2 - TORSION BAR SPRING ADJ
FK3 - TORSION BAR SPRING ADJ
FWI - ASSEMBLY PLANT FORT WAYNE IND.
GT5 - 4.10 REAR AXLE RATIO
JC5 - 4 WHEEL POWER DISC BRAKES
K47 - HIGH CAPACITY AIR CLEANER
K53 - ROBUST FUEL SYST SENDER ASSY
K68 - 105 AMP GENERATOR
LR4 - VORTEC 4800 V8 SFI GAS ENGINE
MG5 - 5 SPD MANUAL TRANSMISSION O/D GETRAG 84MM 4.00 1ST
NF2 - FEDERAL EMISSION SYSTEM TIER 1
NN8 - EMISSIONS OVERRIDE UNLEADED
NP2 - TRANSFER CASE - MANUAL SHIFT
PF4 - 16 X 7 ALUMINUM WHEELS
QHS - P265/75R16-BW TIRES-ALL TERRAIN
R6A - POMS TRACKING CODE
R6K - PROCESSING CODE - MID EAST
R7X - PROCESSING CODE
R9I - SPA DEAL CODE
R9Q - PROCESSING CODE FLEET & GOVT
R9Z - PROCESSING CODE
SLL - SOLD ORDERS PROCESSING OPTION
T62 - DELETE DAYTIME RUNNING LAMP
T78 - HEADLAMP CONTROL DELETE
UC2 - KILO SPEEDOMETER & ODOMETER POSITIVE BIAS
UD4 - ALARM VEHICLE SPEED, 120 K/H
UQ5 - DOOR MTD. DUAL FRT SPKR SYSTEM
UY7 - WIRING HARNESS TRUCK TRAILER
VBX - ARABIC LANGUAGE LABEL
VC5 - EXPORT SHIPPING LABEL
VG3 - FRONT BUMPER IMPACT STRIP
VPH - VEHICLE PREP - EXPORT
VR6 - TIE DOWN HOOK
VXS - COMPLETE VEHICLE
VZ2 - SPEEDOMETER CALIBRATION A
V43 - PAINTED REAR STEP BUMPER
V87 - GSO VEHICLE STATEMENT
XHS - P265/75R16-114S ALT BW TIRES
YD3 - AXLE BASE EQUIP PROCESSING OPT
YD6 - BASE RR SPRING PROCESSING OPT
YHS - P265/75R16-114S ALT BW TIRES
YK6 - IDENTIFICATION SEO (POMS ONLY)
ZE5 - BASE TRIM IDENT PROCESSING OPT
ZHS - P265/75R16-114S ALT BW TIRES
ZY1 - SOLID PAINT
Z5X - ARABIC LANGUAGE ON OSRV MIRROR
Z85 - HEAVY DUTY SUSPENSION PACKAGE
Z88 - GMC NAMEPLATE
1SA - PREFERRED EQUIPMENT GROUP 1SA
5B5 - POWER WINDOWS
50U - OLYMPIC WHITE PRIMARY
52C - NEUTRAL CLOTH INTERIOR TRIM
52I - LT NEUTRAL INTERIOR TRIM
6YH - COMPONENT FRT LH COMPUTER SUSP
7YH - COMPONENT FRT RH COMPUTER SEL
9R3 - RADIO - DELETE (SEO)
Vehicle Component
Vehicle Component
Component Code : 10 - ENGINE ASSEMBLY
Source Plant : W - CPC/DDA ROMULUS, MICHIGAN
Part/Num Broadcast : XBB Traceability : 021305405
Date Scanned : 05/14/2002 Time Scanned : 21.13.00 Scan Station : 02
Component Code : 35 - STEERING COLUMN - SIR SYSTEM
Source Plant : S - SAGINAW DIVISION SAGINAW,MI
Part/Num Broadcast : XFY Traceability : 760701262
Date Scanned : 05/14/2002 Time Scanned : 20.52.00 Scan Station : 16
Component Code : 50 - INSTRUMENT CLUSTER
Source Plant : 3
Part/Num Broadcast : DHRJ Traceability : DHR225467
Date Scanned : 05/14/2002 Time Scanned : 20.52.00 Scan Station : 99
Component Code : 60 - TRANSFER CASE (4 WHEEL DRIVE)
Source Plant : N
Part/Num Broadcast : WB Traceability : 0AO314817
Date Scanned : 05/14/2002 Time Scanned : 21.25.00 Scan Station : 05
Component Code : 61 - TRANSMISSION
Source Plant : M - HYDRAMATIC MUNCIE, INDIANA
Part/Num Broadcast : GBLZ Traceability : 006433
Component Code : 63 - FRONT AXLE/FRONT CRADLE WITH FRONT HUB ASSEMBLIES
Source Plant : G
Part/Num Broadcast : UL5 Traceability : C011927
Date Scanned : 05/14/2002 Time Scanned : 22.36.00 Scan Station : 04
Component Code : 65 - REAR AXLE ASSEMBLY
Source Plant : G - SAGINAW DETROIT, MICHIGAN
Part/Num Broadcast : MH8 Traceability : 002014
Date Scanned : 05/14/2002 Time Scanned : 21.32.00 Scan Station : 03
Component Code : 86 - ELECTRONIC CONTROL MODULE (ECM)
Source Plant : 9
Part/Num Broadcast : DMNP Traceability : 221314QGU
Date Scanned : 05/15/2002 Time Scanned : 01.41.00 Scan Station : DV
Component Code : 92 - BRAKE PRESSURE MODULATOR VALVE ASSEMBLY
Source Plant : K - KELSEY-HAYES JASPER, INDIANA
Part/Num Broadcast : 7200 Traceability : 00371549
Date Scanned : 05/14/2002 Time Scanned : 22.36.00 Scan Station : 14
Component Code : AB - IR-MODULE ASM-INFLATOR
Source Plant : I - INLAND
Part/Num Broadcast : 1133 Traceability : 7WP1H7G
Date Scanned : 05/14/2002 Time Scanned : 23.13.00 Scan Station : 12
Component Code : AD - IR-SENSOR-FORWARD
Source Plant : H - HAMLIN INC, LAKE MILLS WISCONSIN
Part/Num Broadcast : 6305 Traceability : 03Q0QZ
Date Scanned : 05/14/2002 Time Scanned : 22.41.00 Scan Station : 18
Component Code : AL - IR-MODULE ASM-I/P
Source Plant : Q - RIMIR MATAMORS MEXICO
Part/Num Broadcast : 1340 Traceability : 5W9V7R4
Date Scanned : 05/14/2002 Time Scanned : 20.43.00 Scan Station : 21
Component Code : AS - SENSING DIAGNOSTIC MODULE
Source Plant : K - DELCO ELECTRONICS KOKOMO,IN
Part/Num Broadcast : 1392 Traceability : 22131M9WH
Component Code : CB - SEQ NUM (FLEX) BODY ASM
Source Plant : N/A
Part/Num Broadcast : 1ZS Traceability : 2240618
Date Scanned : 05/04/2002 Time Scanned : 04.14.00 Scan Station : N/A
Component Code : CK - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 1PA Traceability : 3275787
Date Scanned : 05/14/2002 Time Scanned : 06.34.00 Scan Station : N/A
Component Code : CM - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 1KA Traceability : 3284052
Date Scanned : 05/14/2002 Time Scanned : 16.56.00 Scan Station : N/A
Component Code : CP - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 1FA Traceability : 4224845
Date Scanned : 05/14/2002 Time Scanned : 19.50.00 Scan Station : N/A
Delivery Information
IN-SERVICE INFORMATION
In-Service Information Not On file
DELIVERY INFORMATION
Delivery Date : 09/11/2002
Delivery Type : 020 - FLEET/DAILY RENTAL
Delivered Odometer : 0 kilometres
Delivering Dealer :
P.O. BOX 224
DAMMAM , SA 31411
Delivery Selling Source : 72 - NAES
Delivery Site Code : 71592
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,155 Guests (See full list)
