If its one thing we all have in common it is that we all want what is best for our beloved rides. That being said I pose this question. A lot of debate is made about whats the best oils, fuel, etc... But aren't the filters just as, if not more important then the lubricants and fuel? I have always used K&N or ACDelco filters but, in doing research, I have found a lot of evidence that Wix filters might be the way to go. So my question is, what filters do you use on your truck(s)? and why?
ACDelco :) Wix may be better, I just like ACDELCO!!!
I have always used a Wix filter, and the main reason is that I have always used them and never had a problem. When I ran marine diesel engines, the first oil change I contacted the engine manufacturer and asked what oil filter he recommended, and his answer was Wix. I compared the spec's on various oil filters, and I liked what I saw with the Wix. So Wix it is.
I appreciate the responses guys. Do you guys use ACDelco for your fuel filters, transmission filters, oil filters, and air filters? Or just for one specific place? What about other brands? And what about the reasoning? Is it because thats what came from the factory? or its cheap? Thanks again for all the responses.
Napa Gold...AKA WIX!! :)
Yup, me too. Wanna know why? Because Napa is about 5 miles closer to my house than any other auto parts store. :sigh:
Yup, me too. Wanna know why? Because Napa is about 5 miles closer to my house than any other auto parts store. :lol:
Nice one DV :sigh:
In the name of science I ran a search through summitracing.com and jegs.com to find every oil filter (I figure thats is the most important) available for my Silverado (6.6L Duramax). I then e-mail the manufacturers of each of the filters for information. Below is there responses. I also did the same research for my Suburban (5.7L) and the results (except for the flow rate) where the same. I hope this helps.
WIX;
By-Pass Valve Setting-PSI:
15
Anti-Drain Back Valve:
Yes
Max Flow Rate:
9-11 GPM
Nominal Micron Rating:
8
Fram Extra Guard;
Filter Bypass Relief Valve:
Yes
Relief Valve Open (psi):
9-12 psi
Anti-Drainback Valve:
Yes
Smallest Particle Filtered:
18 microns
ACDelco;
No
Relief Valve Open (psi): 9-12 psi
No
Smallest Particle Filtered: 25
K&N:
Yes
15 psi
Yes
10 microns
AFE Pro Guard D2;
Smallest particle Filtered: No Answer Given.
9-12 psi
No
Yes
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
