Onstar Brain Location?
Does anyone know where this is? I am trying to find it so I can get a look at the antenna lead. I am about to install an avic-d3 into the truck, and would like to utilize the factory "sharkfin" for the satelittle raio, and the GPS. I have the satellite radio part figured out, just need to find the gps end so I can see what needs to be done to adapt it.
yeah the VCIM (Vehicle Communication Interface Module) is located in the dash, here is some additional information:
(None of the hyperlinks will work)
gmLogoFlat.gif Service Information
2008 Chevrolet Silverado - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 1838160 Communication Interface Module Replacement (with RPO SLT)
Callout
Component Name
Preliminary Procedure
  1. Remove the instrument panel accessory trim plate. Refer to Instrument Panel Accessory Trim Plate Replacement.
  2. Remove the HVAC control module. Refer to HVAC Control Module Replacement or HVAC Control Module Replacement.
  3. Remove the radio. Refer to Radio Replacement.
Tip
• Push outward on the 2 tabs to release the communication interface module from the bracket.
• Disconnect the electrical connectors.
• Reprogram the communication interface module after replacement. Refer to
Control Module References.
• When replacing the communication interface module be sure to transfer Bluetooth Antenna, if equipped.
© 2008 General Motors Corporation. All rights reserved.
And this is how you get to it:
2008 Chevrolet Silverado - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 1833054 Instrument Panel Accessory Trim Plate Replacement (with RPO SLT)
Callout
Component Name
Tip
Use a flat-bladed plastic trim tool in order to release the retainer clips securing the trim plate to the instrument panel.
2
Retainer Clips (Qty: 9)
2008 Chevrolet Silverado - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 1740958 HVAC Control Module Replacement
Callout
Component Name
  1. Remove the instrument panel accessory trim plate. Refer to Instrument Panel Accessory Trim Plate Replacement .
  2. Remove the accessory switch assembly. Refer to Accessory Switch Replacement .
  3. Disconnect the electrical connectors.
Screw, Control Assembly - Heater and Air Conditioning (Qty: 2)
Notice: Refer to Fastener Notice in the Preface section.
Tighten
1.5 N·m (13 lb in)
2
Control Assembly, Heater and Air Conditioning
Tip
HVAC Control Module must be reprogrammed. Refer to Control Module References .
2008 Chevrolet Silverado - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 1838423 Radio Replacement (with RPO SLT)
Callout
Component Name
Preliminary Procedures
  1. Remove the accessory switch assembly. Refer to Accessory Switch Replacement .
  2. Remove the HVAC control module. Refer to HVAC Control Module Replacement or HVAC Control Module Replacement .
Radio Screw (Qty: 4)
Tighten
2 N·m (18 lb in)
2
Radio Assembly
Tip
• Use a scan tool to retrieve the radio part number before removing the radio from the vehicle.
• Disconnect the electrical connector.
• Disconnect the antenna cable.
• Reprogram the radio after replacement. Refer to
as you can see, it sits behind the HVAC and under the radio (For the trucks containing the RRO LTZ, SLT only), problem is, this is a restricted part, and I cannot find any information containing connection views for the VCIM (But I will continue to look)
Thanks for the help, I don't have that dash though. I will see what I can figure out. Hopefullyit is still in the same spot.
Here are the connectors for the VCIM,
Vehicle Communication Interface Module (VCIM) X1 (UE1)
Connector Part Information
  • OEM: 15431362
  • Service: 15306351
  • Description: 16-Way F Micro 100A (WH)
Terminal Part Information
  • Pins: 1-3, 6-7, 10-12, 15
  • Terminal/Tray: 15445905/23
  • Core/Insulation Crimp: J/J
  • Release Tool/Test Probe: 12180559/J-35616-6 (BN)
Pin
Wire
Circuit
Function
0.35 D-GN
5060
Low Speed GMLAN Serial Data
2
0.35 BN/WH
2517
Keypad Red LED Signal
3
0.35 YE/BK
2516
Keypad Green LED Signal
4-5
Not Used
6
0.35 L-GN/BK
2515
Keypad Supply Voltage
7
0.5 BK
2550
Ground
8-9
Not Used
10
0.5 TN/BK
2500
High Speed GMLAN Serial Data Bus+
11
0.35 D-GN/WH
2514
Keypad Signal
12
0.5 TN
2501
High Speed GMLAN Serial Data Bus-
13-14
Not Used
15
0.5 RD/WH
3240
Battery Positive Voltage (except Y91)
0.5 RD/WH
1540
Battery Positive Voltage (Y91)
16
Not Used
Vehicle Communication Interface Module (VCIM) X2 (UE1)
  • OEM: 15431365
  • Service: 88952886
  • Description: 12-Way F Micro 64 (WH)
Pin
Wire
Circuit
Function
0.35 D-BU
658
Cellular Telephone Voice Signal
2
0.35 L-BU/BK
659
Low Reference
3
0.5 TN/BK
2500
4
0.5 TN
2501
5-7
Not Used
8
0.5 BARE
1782
Drain Wire (except Y91)
0.35 BARE
1782
Drain Wire (Y91)
9
0.35 GY
655
10
0.5 BARE
514
0.35 BARE
514
Drain Wire (Y91)
11-12
Not Used
Vehicle Communication Interface Module (VCIM) X3 (UE1 with U3U/UVB)
  • OEM: 15431359
  • Service: See Catalog
  • Description: 16-Way F Micro 100A (GY)
  • Pins: 2, 4-5
Pin
Wire
Circuit
Function
Not Used
2
0.35 PK
5149
Voice Recognition Audio Signal
3
Not Used
4
0.35 PK/BK
5152
Low Reference
5
0.5 BARE
1792
0.35 BARE
1792
Drain Wire (Y91)
6-16
Not Used
Looks like for the "pure pickup" dash, it is in the same vicinity.
2008 Chevrolet Silverado - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 1838157 Communication Interface Module Replacement (without RPO SLT)
Callout
Component Name
Remove the instrument panel lower center panel. Refer to Instrument Panel Lower Center Trim Replacement.
Tip
• Push outward on the tab to release the communication interface module from the bracket.
• If replacing the communication interface module be sure to transfer Bluetooth Antenna, if equipped.
2008 Chevrolet Silverado - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 1828891 Instrument Panel Lower Center Trim Replacement
Callout
Component Name
Remove the knee bolster assembly. Refer to Knee Bolster Replacement .
Instrument Panel Lower Center Trim Panel Screw (Qty: 2)
Tighten
2 N·m (18 lb in)
2
Instrument Panel Lower Center Trim Panel Assembly
3
Retainer Clip (Qty: 6)
2008 Chevrolet Silverado - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 1828882 Knee Bolster Replacement (without RPO SLT)
Callout
Component Name
Remove the park brake release handle assembly from the knee bolster. Refer to Parking Brake Release Handle Assembly Replacement .
Instrument Panel Left Outer Trim Cover
Refer to Instrument Panel Outer Trim Cover Replacement .
2
Knee Bolster Screw (Qty: 2)
Tighten
2 N·m (18 lb in)
3
Knee Bolster Assembly
Tip
  1. Disconnect the electrical connectors.
  2. If replacing the knee bolster assembly, transfer all necessary components.
4
Retainer Clip (Qty: 3)
2008 Chevrolet Silverado - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 1688547 Parking Brake Release Handle Assembly Replacement
Callout
Component Name
Park Brake Release Handle Bolt (Qty: 1)
Tighten
9 N·m (80 lb in)
2
Park Brake Release Handle Cable
Tip
Slide the park brake release cable forward to remove it from the park brake module.
3
That is because the antenna connection is not included, that has to be hunted down in a different section
    2022LtTbZ71
    2022LtTbZ71
  • Who's Online   5 Members, 0 Anonymous, 1,113 Guests (See full list)
