Vin Check Please
VIN : 1GCEK19V02Z337285
VEHICLE INFORMATION
Merchandising Model : CK15753 -2002 SILVERADO LS SHORT BOX 4WD Warranty Start Date : 06/20/2002
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : EDMONTON MOTORS LIMITED
11445 JASPER AVENUE
EDMONTON , AB T5K0M6
(780) 482-5771
Selling Source : 14 - GM OF CANADA
Site Code : 82104
Business Associate Code : 120506
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
RC 04007 TAILGATE SUPPORT CABLE N/A Closed
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/60000 BUMPER TO BUMPER LIMITED WARRANTY 06/20/2002 56 kilometres 06/20/2005 60056 kilometres
72/160000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 06/20/2002 56 kilometres 06/20/2008 160056 kilometres
96/130000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 06/20/2002 56 kilometres 06/20/2010 130056 kilometres
36/60000 FEDERAL EMISSION 06/20/2002 56 kilometres 06/20/2005 60056 kilometres
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
12/29/2004 177932 # V1242 - 04007 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 154980 kilometres
01/10/2003 154668 # F2122 - CARRIER ASSEMBLY - FRONT DIFFERENTIAL - R&R 30712 kilometres
06/03/2002 A37285 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 kilometres
© 1998-2005 General Motors Corporation. All Rights Reserved.
CLAIM HISTORY
Repair Order Date : 12/29/2004 Repair Order Number : 177932 Odometer Reading : 154980 kilometres
Serviced By : PIKE WHEATON CHEVROLET OLDSMOBILE LTD.
POBOX 220
RED DEER, AB T4N5E8
(403) 347-3301 Selling Source : 14 - GM OF CANADA
Site Code : 82235
Business Associate Code : 120573
Cycle Date Cycle Nbr Case Type Labor Operation Part Comments
01/04/2005 549 01 # V1242 - 04007 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 88980509 N
Repair Order Date : 01/10/2003 Repair Order Number : 154668 Odometer Reading : 30712 kilometres
POBOX 220
RED DEER, AB T4N5E8
Site Code : 82235
01/21/2003 345 01 # F2122 - CARRIER ASSEMBLY - FRONT DIFFERENTIAL - R&R 9420095 N
Repair Order Date : 06/03/2002 Repair Order Number : A37285 Odometer Reading : 0 kilometres
Serviced By : EDMONTON MOTORS LIMITED
11445 JASPER AVENUE
EDMONTON, AB T5K0M6
(780) 482-5771 Selling Source : 14 - GM OF CANADA
Site Code : 82104
06/07/2002 280 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME N/A N
VIN 1GCEK19V02Z337285
VEHICLE BUILD
Gross Vehicle Weight Rating : 2906 kg (6408 lb) Order Number : P25253
Build Date : 06/03/2002 Build Plant : 12Z53
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AE7 - 40/20/40 FRONT SPLIT BENCH SEAT AJ1 - DEEP TINTED REAR GLASS
AM7 - FOLDING BACK REAR SEAT AU0 - REMOTE KEYLESS ENTRY SYSTEM
AU3 - POWER DOOR LOCKS A31 - POWER WINDOWS AND DOOR LOCKS
B30 - FLOOR CARPETING B32 - FRONT AND REAR FLOOR MATS
B33 - REAR FLOOR MATS B85 - BODY SIDE MOULDINGS
C60 - AIR CONDITIONING - ALL WEATHER C7H - GVWR: 2903 KG (6400 LB)
DK7 D48 - ELECTRIC REMOTE O/S MIRRORS
EVA E63 - FLEETSIDE BODY OPTION
FE9 - FEDERAL CERTIFICATION EMISSION FK2
FK3 FWI
GT5 - 4.10 REAR AXLE RATIO G80 - AXLE - LOCKING DIFFERENTIAL
JC5 K05 - HEATER - ENGINE BLOCK
K34 - CRUISE CONTROL K47 - HIGH CAPACITY AIR CLEANER
K68 - 105 AMP DELCOTRON GENERATOR LR4 - VORTEC 4800 SFI V8 ENGINE
M30 - 4-SP ELECTRONIC AUTO/OVERDRIVE NF2 - FEDERAL EMISSION SYSTEM
NP5 - LEATHER WRAPPED STEERING WHEEL NP8 - AUTOTRAC - AUTOMATIC 4WD
NZZ - OFF-ROAD SKID PLATE PACKAGE PF9 - 16" ALUMINUM WHEELS (4)
QGC - TIRES - P265/75R-16" AT BW R6A - VINYL FLOOR COVERING - DELETES FLOOR MATS
R7K - EQUIPMENT ADJUSTMENT - REMOTE KEYLESS ENTRY NOT AVAILABLE SLM
UN0 - RADIO- AM/FM ST, CD PLAYER, ATC UQ3 - PERFORMANCE ENHANCED AUDIO 6 SPEAKER SYSTEM
U19 - KILO SPEEDOMETER VB3 - CHROME REAR STEP BUMPER
VG3 - CHROME FRONT BUMPER VXS
V22 - FRONT GRILLE W/ CHROME ACCENTS V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XGC X88
YD3 YD6 - REAR SPRING BASE EQUIPMENT
YE9 - SILVERADO LS MODEL YGC
ZGC ZY1 - SOLID PAINT
Z49 - CANADIAN BASE EQUIPMENT Z71 - OFF-ROAD CHASSIS EQUIPMENT
1SD - PREFERRED EQUIPMENT GROUP 12D - GRAPHITE
12I 50U - SUMMIT WHITE
6YH 7YH
Vehicle Component
Component Code : 10 - ENGINE ASSEMBLY
Source Plant : W - CPC/DDA ROMULUS, MICHIGAN
Part/Num Broadcast : XBA Traceability : 021492043
Date Scanned : 06/03/2002 Time Scanned : 07.10.00 Scan Station : 02
Component Code : 35 - STEERING COLUMN - SIR SYSTEM
Source Plant : S - SAGINAW DIVISION SAGINAW,MI
Part/Num Broadcast : XJT Traceability : 248531482
Date Scanned : 06/03/2002 Time Scanned : 06.40.00 Scan Station : 16
Component Code : 50 - INSTRUMENT CLUSTER
Source Plant : 3
Part/Num Broadcast : DHRL Traceability : DHR239333
Date Scanned : 06/03/2002 Time Scanned : 06.40.00 Scan Station : 99
Component Code : 60 - TRANSFER CASE (4 WHEEL DRIVE)
Source Plant : N
Part/Num Broadcast : UF Traceability : 0AO502988
Date Scanned : 06/03/2002 Time Scanned : 07.23.00 Scan Station : 05
Component Code : 61 - TRANSMISSION
Source Plant : Y - HYDRAMATIC TOLEDO, OHIO
Part/Num Broadcast : 2KBD Traceability : 33614959
Component Code : 63 - FRONT AXLE/FRONT CRADLE WITH FRONT HUB ASSEMBLIES
Source Plant : G
Part/Num Broadcast : UL5 Traceability : C013405
Date Scanned : 06/03/2002 Time Scanned : 08.04.00 Scan Station : 04
Component Code : 65 - REAR AXLE ASSEMBLY
Source Plant : G - SAGINAW DETROIT, MICHIGAN
Part/Num Broadcast : MY6 Traceability : 001231
Date Scanned : 06/03/2002 Time Scanned : 07.22.00 Scan Station : 03
Component Code : 86 - ELECTRONIC CONTROL MODULE (ECM)
Source Plant : 9
Part/Num Broadcast : DMNP Traceability : 221516ZNM
Date Scanned : 06/03/2002 Time Scanned : 11.17.00 Scan Station : DV
Component Code : 92 - BRAKE PRESSURE MODULATOR VALVE ASSEMBLY
Source Plant : K - KELSEY-HAYES JASPER, INDIANA
Part/Num Broadcast : 7200 Traceability : 00403069
Date Scanned : 06/03/2002 Time Scanned : 08.04.00 Scan Station : 14
Component Code : AB - IR-MODULE ASM-INFLATOR
Source Plant : I - INLAND
Part/Num Broadcast : 1134 Traceability : 7WP5YQN
Date Scanned : 06/03/2002 Time Scanned : 08.25.00 Scan Station : 12
Component Code : AD - IR-SENSOR-FORWARD
Source Plant : H - HAMLIN INC, LAKE MILLS WISCONSIN
Part/Num Broadcast : 6305 Traceability : 03S8QV
Date Scanned : 06/03/2002 Time Scanned : 08.06.00 Scan Station : 18
Component Code : AL - IR-MODULE ASM-I/P
Source Plant : Q - RIMIR MATAMORS MEXICO
Part/Num Broadcast : 2834 Traceability : 2WALK47
Date Scanned : 06/03/2002 Time Scanned : 06.31.00 Scan Station : 21
Component Code : AS - SENSING DIAGNOSTIC MODULE
Source Plant : K - DELCO ELECTRONICS KOKOMO,IN
Part/Num Broadcast : 1392 Traceability : 12149LMXZ
Component Code : CB - SEQ NUM (FLEX) BODY ASM
Source Plant : N/A
Part/Num Broadcast : 1ZS Traceability : 2480087
Date Scanned : 05/20/2002 Time Scanned : 22.46.00 Scan Station : N/A
Component Code : CK - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 1PA Traceability : 3289674
Date Scanned : 05/31/2002 Time Scanned : 17.23.00 Scan Station : N/A
Component Code : CM - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 1KA Traceability : 3297806
Date Scanned : 05/31/2002 Time Scanned : 22.42.00 Scan Station : N/A
Component Code : CP - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 1FA Traceability : 4238405
Date Scanned : 06/01/2002 Time Scanned : 00.39.00 Scan Station : N/A
IN-SERVICE INFORMATION
In-Service Information Not On file
DELIVERY INFORMATION
Delivery Date : 06/20/2002 Delivery Type : 020 - FLEET/DAILY RENTAL Delivered Odometer : 56 kilometres
11445 JASPER AVENUE
(780) 482-5771
Delivery Selling Source : 14 - GM OF CANADA
Delivery Site Code : 82104
INVOICE INFORMATION
Invoice Date : 06/03/2002
Site Address : EDMONTON MOTORS LIMITED
11445 JASPER AVENUE
Site Code : 82104
SHIP-TO INFORMATION
Ship-To Date : N/A
11445 JASPER AVENUE
Site Code : 82104
I just found this site, and I think it is great. Two weeks ago I purchased a 2004 GMC 1500 Sierra. Already having bad feelings. Would someone run my vin--1GTEK14T84Z346003.
Much appreciated.
VIN : 1GTEK14T84Z346003
VEHICLE INFORMATION
Merchandising Model : TK15903 -2004 SIERRA 1500 4WD REG CAB PICKUP Warranty Start Date : 08/21/2004
Delivering Dealer : SIMMONS ROCKWELL CHEVROLET BUICK PONTIAC GMC
7327 HAMMONDSPORT RD
BATH , NY 14810-8312
(607) 776-7600
Selling Source : 48 - GMC TRUCK
Site Code : 07108
Business Associate Code : 162467
Vehicle Has No Current Record Of Outstanding Campaigns
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 08/21/2004 55 miles 08/21/2007 36055 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 08/21/2004 55 miles 08/21/2010 100055 miles
3/3000 GM CERTIFIED USED LIMITED WARRANTY 07/02/2008 38432 miles 10/02/2008 41432 miles
60/100000 GM CERTIFIED USED POWERTRAIN LIMITED WARRANTY 08/21/2004 55 miles 08/21/2009 100055 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 08/21/2004 55 miles 08/21/2012 80055 miles
36/50000 CALIFORNIA EMISSIONS 08/21/2004 55 miles 08/21/2007 50055 miles
84/70000 CALIFORNIA SELECT COMPONENT 08/21/2004 55 miles 08/21/2011 70055 miles
CLAIM HISTORY
03/24/2006 096845 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 24931 miles
03/24/2006 096845 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 24900 miles
03/24/2006 096845 # R0762 - RECEIVER, RADIO - ORDER OR REMOVE 24931 miles
03/24/2006 096845 # R0763 - RECEIVER, RADIO - INSTALL 24931 miles
01/19/2006 094295 # F2142 - DIFFERENTIAL CARRIER ASSEMBLY REPLACEMENT 21822 miles
06/28/2004 352588 I Z6999 - PDI RELATED FLUID ADDS 3 miles
06/16/2004 A46003 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
CLAIM HISTORY
Repair Order Date : 03/24/2006 Repair Order Number : 096845 Odometer Reading : 24931 miles
Serviced By : SIMMONS ROCKWELL BUICK PONTIAC GMC
784 CO RT 64
ELMIRA, NY 14903
(607) 796-5555 Selling Source : 48 - GMC TRUCK
Site Code : 10175
Business Associate Code : 205155
04/14/2006 682 01 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 26098419 - LUBE KIT N
04/14/2006 682 02 # R0762 - RECEIVER, RADIO - ORDER OR REMOVE N/A N
04/14/2006 682 03 # R0763 - RECEIVER, RADIO - INSTALL N/A N
Repair Order Date : 03/24/2006 Repair Order Number : 096845 Odometer Reading : 24900 miles
Serviced By : MODEL ELECTRONICS
615 EAST CRESCENT AVE.
RAMSEY, NJ 07446
Selling Source : 45 - A/C DELCO
Site Code : 19050
Business Associate Code : 192106
04/11/2006 681 01 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 88988530 Y
Repair Order Date : 01/19/2006 Repair Order Number : 094295 Odometer Reading : 21822 miles
784 CO RT 64
ELMIRA, NY 14903
Site Code : 10175
02/10/2006 664 01 # F2142 - DIFFERENTIAL CARRIER ASSEMBLY REPLACEMENT 15839875 - AXLE N
Repair Order Date : 06/28/2004 Repair Order Number : 352588 Odometer Reading : 3 miles
Serviced By : SIMMONS ROCKWELL CHEVROLET BUICK PONTIAC GMC
BATH, NY 14810-8312
(607) 776-7600 Selling Source : 48 - GMC TRUCK
Site Code : 07108
07/20/2004 501 01 I Z6999 - PDI RELATED FLUID ADDS N/A N
Repair Order Date : 06/16/2004 Repair Order Number : A46003 Odometer Reading : 0 miles
BATH, NY 14810-8312
Site Code : 07108
06/22/2004 493 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME N/A N
VIN 1GTEK14T84Z346003
VEHICLE BUILD
Gross Vehicle Weight Rating : 2906 kg (6408 lb) Order Number : HGMRZ9
Build Date : 06/16/2004 Build Plant : 14Z03
OPTION CODES
AE7 - BENCH SEAT-UPLEVEL CUSTOM CLOTH AJ1 - DEEP TINTED GLASS
AL0 - SENSOR INDICATOR, INFLATABLE RESTRAINT AU0 - REMOTE KEYLESS ENTRY SYSTEM
B30 - FULL COLOR KEYED CARPET W/MATS B32 - FRONT COLOR-KEYED FLOOR MATS
B85 - BRIGHT BODY SIDE MOLDINGS CJ3 - AIR COND., DUAL ZONE MANUAL
C49 - ELECTRIC REAR WINDOW DEFOGGER C7H - GVW RATING - 6,400 LBS
DF5 - ISRV MIRROR W/COMPASS & TEMP DK7 - CUSTOM INTERIOR ROOF CONSOLE
DL8 - HEATED POWER ADJ EXTERIOR MIRRORS EVA - EVAP EMISSION REQUIREMENT
E63 - WIDESIDE BODY FK2 - TORSION BAR SPRING ADJ - LH
FK3 - TORSION BAR SPRING ADJ - RH FWI - ASSEMBLY PLANT, FORT WAYNE, IN
GT4 - REAR AXLE - 3.73 RATIO G80 - LOCKING REAR DIFFERENTIAL
JC3 - 4 WHEEL ANTI-LOCK DISC BRAKES KNP - H.D. TRANSMISSION OIL COOLER
KUP - THROTTLE CONTROL ELECTRONIC K34 - ELECTRONIC SPEED CONTROL
K47 - HIGH CAPACITY AIR CLEANER K68 - ALTERNATOR 105 AMP
LM7 - VORTEC 5300 V8 SFI GAS ENGINE M30 - 4-SPD AUTO TRANS W/ OVERDRIVE AND ELECTRONIC CONTROL
NE1 - 50-STATE EMISSIONS NP5 - LEATHER WRAPPED STEERING WHL
NP8 - ELECTRONIC SHIFT AUTOTRAC TRANSFER CASE NU4 - CALIF EMISSION SYSTEM LEV 2PLUS
PDU - LIGHT DUTY POWER PACKAGE INCL: *5.3L V8 GAS ENGINE *LOCKING DIFFERENTIAL *HD TRAILERING EQUIPMENT PF4 - 4 16" X 7 BRIGHT MACHINED CAST ALUMINUM WHEELS
QGD - P265/75R16 ALT WOL TIRES R9U - GM ACCESS-AUTOBOOK IDENTIFIER
SLM - STOCK ORDERS TFE - SALES INCENTIVE-COMMITMENT PLUS
T96 - FRONT FOG LAMPS UB0 - AM/FM STEREO W/CD
UQ3 - ENHANCED PERFORMANCE SPEAKERS VB3 - CHROME REAR BUMPER
VG3 - CHROME FRONT BUMPER VK3 - FRONT LICENSE PLATE MOUNT
VR4 - WEIGHT DIST HITCH PLATFORM VXS - COMPLETE VEHICLE LABEL
V22 - CHROME GRILLE SURROUND V73 - STATEMENT OF CERT. U.S.
XGD - P265/75R16 ALT WOL TIRES YD3 - BASE EQUIP FOR SCH GVW PLATE
YD6 - REAR SPRING - BASE EQUIPMENT YE9 - SLE/SLT DECOR
YGD - P265/75R16 ALT WOL TIRES-REAR ZGC - P265/75R16 BW SPARE TIRE
ZY1 - SOLID PAINT Z82 - HEAVY DUTY TRAILERING EQUIP.
Z85 - HANDLING/TRAILERING SUSPENSION PACKAGE Z88 - GMC TRUCK NAMEPLATE
1SC - SLE DECOR INCLUDES: *AIR COND., DUAL ZONE MANUAL *DUAL PWR HEATED OSRV MIRRORS *REAR WINDOW DEFOGGER *DEEP TINT GLASS *AM/FM STEREO W/CD PLAYER *CHROME STYLED STEEL WHEELS *ELECTRONIC SPEED CONTROL *POWER LOCKS & WINDOWS *REMOTE KEYLESS ENTRY WITH CONTENT THEFT ALARM *ISRV MORROR W/COMPASS & TEMP *LEATHER WRAPPED STEERING WHEEL *BODY SIDE MOLDINGS *FRONT FOG LAMPS 1SZ - OPTION PACKAGE DISCOUNT
6YH - COMPONENT FRT LH COMPUTER SEL 69D - DARK PEWTER CUSTOM CLOTH
69I - DARK PEWTER INTERIOR TRIM 7YH - COMPONENT FRT RH COMPUTER SEL
74U - FIRE RED
Vehicle Component
Part/Num Broadcast : SHC Traceability : 041665025
Date Scanned : 06/16/2004 Time Scanned : 00.17.00 Scan Station : 02
Part/Num Broadcast : T9Y Traceability : 240571634
Date Scanned : 06/15/2004 Time Scanned : 23.50.00 Scan Station : 16
Source Plant : 3
Part/Num Broadcast : DWFY Traceability : DWF247023
Date Scanned : 06/15/2004 Time Scanned : 23.50.00 Scan Station : 99
Source Plant : N
Part/Num Broadcast : ZB Traceability : 0BA309014
Date Scanned : 06/16/2004 Time Scanned : 00.28.00 Scan Station : 05
Part/Num Broadcast : 4KCD Traceability : 39622875
Date Scanned : 06/16/2004 Time Scanned : 00.22.00 Scan Station : 15
Source Plant : G
Part/Num Broadcast : XS4 Traceability : N231920
Date Scanned : 06/16/2004 Time Scanned : 06.11.00 Scan Station : 04
Part/Num Broadcast : JB5 Traceability : 343339
Date Scanned : 06/16/2004 Time Scanned : 00.33.00 Scan Station : 03
Source Plant : 9
Part/Num Broadcast : YFXL Traceability : 2415924DG
Date Scanned : 06/16/2004 Time Scanned : 09.30.00 Scan Station : DV
Part/Num Broadcast : 7350 Traceability : 00216464
Date Scanned : 06/16/2004 Time Scanned : 06.10.00 Scan Station : 14
Part/Num Broadcast : 5378 Traceability : 9EXLD89
Date Scanned : 06/16/2004 Time Scanned : 06.30.00 Scan Station : 12
Component Code : AH - IR-SENSOR ASM-LEFT
Source Plant : X - DELCO ELECTRONICS SINGAPORE
Part/Num Broadcast : 7506 Traceability : 4140JTTK1
Component Code : AJ - IR-SENSOR ASM-RIGHT
Part/Num Broadcast : 7506 Traceability : 4140JTTLW
Source Plant : M - MORTON-THIOKOL
Part/Num Broadcast : 2351 Traceability : 8YIIL22
Date Scanned : 06/15/2004 Time Scanned : 23.25.00 Scan Station : 21
Part/Num Broadcast : 0608 Traceability : 24162YFAP
Source Plant : N/A
Part/Num Broadcast : 1ZS Traceability : 2220070
Date Scanned : 06/04/2004 Time Scanned : 04.06.00 Scan Station : N/A
Source Plant : N/A
Part/Num Broadcast : 1PA Traceability : 3812561
Date Scanned : 06/15/2004 Time Scanned : 14.31.00 Scan Station : N/A
Source Plant : N/A
Part/Num Broadcast : 1KA Traceability : 3824706
Date Scanned : 06/15/2004 Time Scanned : 20.29.00 Scan Station : N/A
Source Plant : N/A
Part/Num Broadcast : 1FA Traceability : 6246936
Date Scanned : 06/15/2004 Time Scanned : 22.28.00 Scan Station : N/A
Delivery Date : 08/21/2004 Delivery Type : 010 - RETAIL/INDIVIDUAL Delivered Odometer : 55 miles
(607) 776-7600
Delivery Selling Source : 48 - GMC TRUCK
Delivery Site Code : 07108
INVOICE INFORMATION
Invoice Date : 06/16/2004
Site Address : SIMMONS ROCKWELL CHEVROLET BUICK PONTIAC GMC
Site Code : 07108
SHIP-TO INFORMATION
Ship-To Date : N/A
Site Code : 07108
Much appreciated.
And by the way, welcome to GM-Trucks.com
Thanks. I believe I see what my problem is. I will be visiting my local dealership (where I purchased the truck) first thing in the morning.
Hi there. I am considering purchasing an 05 GMC sierra, was wondering if you wouldnt mind running the vin on it just so I know what I may be getting into. Thanks in advance. Will
VIN: 1GTEK14T75Z136896
When my truck was purchased, no one noticed the repair on the rear left fender. Now that it is a little older, it has become apparent that a cheap bondo repair was made. If anyone could try to find out any repair history, I'd appreciate it. Thanks. 2GCEC19T311249592
VIN : 2GCEC19T311249592
VEHICLE INFORMATION
Merchandising Model : CC15753 -2001 SILVERADO LS 1500 2WD EXT CAB Warranty Start Date : 05/29/2001
Delivering Dealer : PIERSON CHEVROLET-BUICK-JEEP
PO BOX 589
GADSDEN , AL 35902-0589
(256) 546-3391
Selling Source : 13 - CHEVROLET
Site Code : 08399
Business Associate Code : 112675
RC 01021 CERTIFICATION & TIRE PRESSURE LABEL INFORMATION INCORRECT N/A Closed
RC 04007 TAILGATE SUPPORT CABLE 09/28/2004 Open
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 05/29/2001 235 miles 05/29/2004 36235 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 05/29/2001 235 miles 05/29/2007 100235 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 05/29/2001 235 miles 05/29/2009 80235 miles
36/36000 FEDERAL EMISSION 05/29/2001 235 miles 05/29/2004 36235 miles
CLAIM HISTORY
12/14/2000 A49592 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
CLAIM HISTORY
Repair Order Date : 12/14/2000 Repair Order Number : A49592 Odometer Reading : 0 miles
Serviced By : COLBERT AUTO WORLD, INC.
PO BOX 649
HOUSTON, MS 38851-0649
(662) 456-3756 Selling Source : 13 - CHEVROLET
Site Code : 17160
Business Associate Code : 114210
12/19/2000 127 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME N/A N
VIN 2GCEC19T311249592
VEHICLE BUILD
Gross Vehicle Weight Rating : 2815 kg (6207 lb) Order Number : CVNVWX
Build Date : 12/14/2000 Build Plant : 21153
OPTION CODES
AE7 - 40/20/20 SPLIT BENCH SEAT WITH 6-WAY POWER AND FRONT LEATHER SEATING SURFACES AJ1 - DEEP TINTED GLASS
AM7 - FOLDING REAR SEAT AU0 - KEYLESS REMOTE DOOR LOCK AND TRUNK OPENER
AU3 - POWER DOOR LOCK SYSTEM A31 - POWER WINDOWS
B30 - WHEELHOUSING & FLOOR CARPETING B32 - FRONT COLOR-KEYED FLOOR MATS
B33 - REAR COLOR KEYED FLOOR MATS B85 - BRIGHT BODY SIDE MOLDINGS
C60 - AIR CONDITIONING WITH AIR FILTRATION SYSTEM DK7 - INTERIOR CUSTOM ROOF CONSOLE
D48 - ELECTRIC EXTERIOR MIRRORS EVA - EVAP EMISSION REQUIREMENT
E63 - FLEETSIDE BODY FE9 - FEDERAL/NY/MA/ME/VT EMISSIONS
GU6 - REAR AXLE 3.42 RATIO JC5 - 4 WHEEL POWER DISC BRAKES
KNP - HD AUX TRANSMISSION COOLING SYS K34 - ELECTRONIC SPEED CONTROL
K68 - 105 AMP DELCOTRON GENERATOR LM7 - VORTEC 5300 V8 SFI GAS ENGINE
M30 - 4-SPD AUTOMATIC TRANSMISSION WITH TOW HAUL MODE NF2 - FEDERAL EMISSION SYSTEM
NP5 - LEATHER WRAPPED STEERING WHEEL OSG - OSHAWA ASSEMBLY
PF9 - CAST ALUMINUM WHEELS QCJ - P255/70R16 ALS WOL TIRES
Q4B - 6,200 LB GVW RATING SLM - STOCK ORDERS
UN0 - AM/FM STEREO W/CD PLAYER & ATC UQ3 - ENHANCED AUDIO SPEAKERS
UY7 - HD 7-LEAD TRAIL. WIRING HARNESS VB3 - CHROME REAR STEP BUMPER
VG3 - FRONT DELUXE CHROMED BUMPER VR4 - WEIGHT DISTRIB. PLATFORM HITCH
VXS - COMPLETE VEHICLE LABEL V22 - DELUXE FRONT APPEARANCE PKG.
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XCJ - P255/70R16 ALS WOL TIRES
X88 - CHEVROLET CONVERSION YCJ - P255/70R16 ALS WOL TIRES
YD3 - BASE EQUIP FOR SCH GVW PL-FT AX YD6 - BASE REAR SPRING
YE9 - SILVERADO ZCJ - P255/70R16 ALS WOL TIRES
ZY1 - SOLID PAINT Z82 - TRAILERING SPECIAL EQUIPMENT INCLUDES: * TRAILER HITCH PLATFORM * 8-WIRE TRAILER HARNESS * TRANSMISSION OIL COOLER
Z85 - HEAVY DUTY SUSPENSION 1SB - LS DECOR INCLUDES: * AIR CONDITIONING W/AIR FILTRATION SYSTEM * DUAL POWER MIRRORS * AM/FM STEREO W/CD PLAYER * CHROME GRILLE & CHROME STEEL WHEELS * ELECTRONIC SPEED CONTROL * POWER LOCKS & WINDOWS * REMOTE KEYLESS ENTRY WITH CONTENT THEFT ALARM * LEATHER WRAPPED STEERING WHL * BODY SIDE MOLDINGS * 40/20/40 SEATING W/RECLINE AND ARMREST STORAGE
1SZ - EQUIPMENT SAVINGS *MANUAL TRANSMISSION DISCOUNT *V6 ENGINE DISCOUNT 41U - ONYX BLACK
52D - TAN - CUSTOM CLOTH 52I - TAN INTERIOR TRIM
6MT - COMPONENT FRT LH COMP. SEL SUSP 7MT - COMPONENT FRT RH COMP. SEL SUSP
Vehicle Component
Part/Num Broadcast : PHA Traceability : 003455077
Date Scanned : 12/14/2000 Time Scanned : 03.23.00 Scan Station : 04
Part/Num Broadcast : UTH Traceability : NI2653460
Date Scanned : 12/13/2000 Time Scanned : 23.50.00 Scan Station : 10
Source Plant : 3
Part/Num Broadcast : DHR Traceability : DHR
Date Scanned : N/A Time Scanned : N/A Scan Station : N/A
Source Plant : N/A
Part/Num Broadcast : N/A Traceability : N/A
Date Scanned : N/A Time Scanned : N/A Scan Station : 04
Part/Num Broadcast : 1CJD Traceability : 29940734
Source Plant : N/A
Date Scanned : N/A Time Scanned : N/A Scan Station : 05
Part/Num Broadcast : FB6 Traceability : 075536
Date Scanned : 12/14/2000 Time Scanned : 03.43.00 Scan Station : 07
Source Plant : 9
Part/Num Broadcast : DLAC Traceability : 10346R5YY
Date Scanned : 12/14/2000 Time Scanned : 07.55.00 Scan Station : 04
Component Code : 87 - BODY CONTROL MODULE
Source Plant : M
Part/Num Broadcast : 5899 Traceability : 10344ANDM
Part/Num Broadcast : 8562 Traceability : 00088851
Date Scanned : 12/14/2000 Time Scanned : 03.37.00 Scan Station : 09
Part/Num Broadcast : 7245 Traceability : 6UK3AVP
Date Scanned : 12/14/2000 Time Scanned : 04.37.00 Scan Station : 11
Part/Num Broadcast : 6305 Traceability : 023JC3
Date Scanned : 12/13/2000 Time Scanned : 23.58.00 Scan Station : 12
Part/Num Broadcast : 1340 Traceability : 5UW227C
Date Scanned : 12/13/2000 Time Scanned : 23.50.00 Scan Station : 01
Part/Num Broadcast : 3180 Traceability : 30346BHC8
Source Plant : N/A
Part/Num Broadcast : 199 Traceability : 1350133
Date Scanned : 12/06/2000 Time Scanned : 23.03.00 Scan Station : N/A
Source Plant : N/A
Part/Num Broadcast : 133 Traceability : 2148450
Date Scanned : 12/14/2000 Time Scanned : 00.11.00 Scan Station : N/A
Delivery Date : 05/29/2001 Delivery Type : 010 - RETAIL/INDIVIDUAL Delivered Odometer : 235 miles
PO BOX 589
(256) 546-3391
Delivery Selling Source : 13 - CHEVROLET
Delivery Site Code : 08399
INVOICE INFORMATION
Invoice Date : 12/14/2000
Site Address : COLBERT AUTO WORLD, INC.
PO BOX 649
HOUSTON , MS 38851-0649
Site Code : 17160
SHIP-TO INFORMATION
Ship-To Date : N/A
PO BOX 649
Site Code : 17160
In regards to your concern, that information does not appear in GMVIS unless it was a warranty repair that GM paid out on...in addition you have an open recall on the vehicle that needs to be taken care of:
<script src="http://gsi.xw.gm.com/si/gsiFunctions.js"> <script> gmLogoFlat.gif Service Information
Document ID: 1732301 #04007B: Product Safety - Tailgate Support Cable - (Nov 21, 2005)
Subject:04007B -- Tailgate Support Cable
Models:2002-2004 Cadillac Escalade EXT
2000 Chevrolet CK
2000-2004 Chevrolet Silverado
2002-2004 Chevrolet Avalanche
2003-2004 Chevrolet Kodiak
2000-2004 GMC Sierra
2003-2004 GMC TopKick
THIS BULLETIN IS BEING REVISED TO INCLUDE SOME 2003 AND 2004 MODEL YEAR MEDIUM DUTY VEHICLES THAT WERE MODIFIED TO INCLUDE A TAILGATE. PLEASE DISCARD ALL COPIES OF BULLETIN 04007A, ISSUED OCTOBER 2004.
Condition
General Motors has decided that a defect which relates to motor vehicle safety exists in certain 2000 model year Chevrolet CK, 2000-2004 model year Chevrolet Silverado and GMC Sierra trucks, and 2002-2004 model year Cadillac Escalade EXT and Chevrolet Avalanche trucks, and 2003-2004 Chevrolet Kodiak and GMC TopKick trucks. On some of these vehicles, the galvanized steel tailgate support cables that retain the tailgate in the full open (horizontal) position may corrode, weaken, and eventually fracture. If one cable fractures, the remaining cable may retain the tailgate in a horizontal position. However, if the remaining cable is sufficiently weakened by corrosion, it could fracture within moments of the first cable fracturing, especially if there is a load on the tailgate. If both cables fracture, the tailgate would suddenly drop and strike the top surface of the rear bumper. Anyone sitting or standing on the tailgate when both cable fracture could be injured by falling from the tailgate. On vehicles that have had the bumper removed, the tailgate may drop even lower. Additionally, if there is cargo on the tailgate, the cargo may become unstable and fall if the support cables fracture.
Correction
Dealers are to replace the galvanized support cables with stainless steel support cables. In addition, dealers are to inspect the tailgate hinge and replace it, if necessary.
Vehicles Involved
Involved are certain 2000 Chevrolet CK, 2000-2004 model year Chevrolet Silverado and GMC Sierra trucks, and 2002-2004 model year Cadillac Escalade EXT and Chevrolet Avalanche trucks, and 2003-2004 Chevrolet Kodiak and GMC TopKick trucks built within these VIN breakpoints:
Year
Division
Model
From
Through
2002
Cadillac
Escalade EXT
2G109185
2G363848
2003
Cadillac
Escalade EXT
3G100002
3G343890
2004
Cadillac
Escalade EXT
4G100005
4G175911
2002
Chevrolet
Avalanche
2G100011
2G363853
2003
Chevrolet
Avalanche
3G100001
3G347428
2004
Chevrolet
Avalanche
4G100011
4G175906
2000
Chevrolet
CK (Classic)
YF416524
YF521040
YR143527
YR230631
2003
Chevrolet
Kodiak
3F507651
3F521614
2004
Chevrolet
Kodiak
4F100150
4F508975
2000
Chevrolet
Silverado
Y1160008
Y1409284
YE195370
YE433962
YZ157610
YZ371943
2001
Chevrolet
Silverado
11100001
11408136
1E100004
1E346660
1F100001
1F213873
1Z100001
1Z335201
2002
Chevrolet
Silverado
21100001
21430587
2E100002
2E306441
2F100002
2F250465
2Z100001
2Z348508
2003
Chevrolet
Silverado
31100001
31412794
3E100001
3E381150
3F100001
3F259060
3Z100001
3Z361857
2004
Chevrolet
Silverado
41100005
41197171
4E100005
4E178445
4F100001
4F145985
4Z100002
4Z178157
2000
GMC
Sierra (Classic)
YF141495
YF521003
YR143530
YR231139
2000
GMC
Sierra
Y1150033
Y1409272
YE194333
YE901599
YZ175180
YZ371915
2001
GMC
Sierra
11100005
11408122
1E100001
1E901535
1F100002
1F213892
1Z100003
1Z335203
2002
GMC
Sierra
21100002
21430585
2E100005
2E306440
2F100001
2F250482
2Z100004
2Z900955
2003
GMC
Sierra
31100002
31412793
3E100009
3E381153
3F100018
3F259040
3Z100004
3Z900320
2004
GMC
Sierra
41100001
41197158
4E100002
4E178436
4F100005
4F145865
4Z100001
4Z178148
2003
GMC
TopKick
3F504306
3F522021
2004
GMC
TopKick
4F500107
4F509433
Important: Dealers should confirm vehicle eligibility through GMVIS (GM Vehicle Inquiry System) before beginning recall repairs. [Not all vehicles within the above breakpoints may be involved.]
For US
For dealers with involved vehicles, a Campaign Initiation Detail Report containing the complete Vehicle Identification Number, customer name and address data has been prepared and will be loaded to the GM DealerWorld, Recall Information website. Dealers that have no involved vehicles currently assigned will not have a report available in GM DealerWorld.
For Canada
For dealers with involved vehicles, a Campaign Initiation Detail Report containing the complete Vehicle Identification Number, customer name and address data has been prepared and is being furnished to involved dealers. Dealers that have no involved vehicles currently assigned will not receive a report with the recall bulletin.
For IPC
The Campaign Initiation Detail Report may contain customer names and addresses obtained from Motor Vehicle Registration Records. The use of such motor vehicle registration data for any other purpose other than follow-up necessary to complete this recall is a violation of law in several states/provinces/countries. Accordingly, you are urged to limit the use of this report to the follow-up necessary to complete this program.
Parts Information
Parts required to complete this recall are to be obtained from General Motors Service Parts Operations (GMSPO). Please refer to your "involved vehicles listing" before ordering parts. Normal orders should be placed on a DRO=Daily Replenishment Order. In an emergency situation, parts should be ordered on a CSO=Customer Special Order.
Part Number
Description
Qty
88980509
Cable, E/Gate (Right)
(New Style Silverado, Sierra Avalanche, Escalade EXT, Kodiak, TopKick)
1 (If Req'd)
88980510
Cable, E/Gate (Left)
(New Style Silverado, Sierra, Avalanche, Escalade EXT, Kodiak, TopKick)
1 (If Req'd)
89045648
Cable, E/Gate (Classic CK, Sierra)
2
15224331
Washer
1-2 (If Req'd)
15074252*
Hinge, Pubx E/Gate
(New Style Silverado, Sierra, Kodiak, TopKick)
1 (If Req'd)
15080226*
Hinge, E/Gate
(Avalanche, Escalade EXT)
1 (If Req'd)
15691088
Hinge, Pubx E/Gate (Classic CK, Sierra)
1 (If Req'd)
* It is estimated that less than 3% of the vehicles worldwide will require hinge replacement. Please order parts accordingly.
Service Procedure
Classic Silverado and Sierra (GMT400)
The following procedure provides instructions for inspecting, and if necessary, replacing the rear endgate (tailgate) support cables and inspecting the right side tailgate hinge for damage, and replacing if necessary.
Notice: It is recommended that a support be placed under the open tailgate in the next step to prevent the tailgate from being damaged in the event that it drops when disconnecting, inspecting, and replacing the support cables.
Hinge Inspection - Classic CK and Sierra
  2. Release (unhook) the RIGHT side tailgate support cable from the pickup box.
  3. With the tailgate (1) completely open as shown in the upper part of the illustration, pull the RIGHT SIDE of the tailgate rearward as shown in the lower illustration. Do not pull on the left side of the tailgate.
    If the tailgate hinge (2) will NOT disengage from the pickup box on the right side, no repair is needed to the hinge. Proceed to the section titled, "Support Cable Replacement" and replace both support cables.
    If the tailgate hinge (3) WILL disengage from the pickup box on the right side, proceed to the next step.
  4. With the right side of the tailgate disengaged from the pickup box, inspect the hinge on the right side of the tailgate for damage. The illustration above shows an undamaged hinge (1) and a damaged or bent hinge (2).
    If the hinge is NOT damaged, no repair is needed to the hinge. Proceed to the section titled, "Support Cable Replacement" and replace both support cables.
    If the hinge IS damaged or bent, the hinge needs to be replaced. Proceed to the section titled, "Hinge Replacement" before proceeding with the replacement of the support cables.
Hinge Replacement - Classic CK and Sierra
The following procedure should only be performed if the right side of the tailgate could be disengaged for the pickup truck and the hinge was damaged or bent.
  1. Release (unhook) the left side tailgate support cable from the pickup box.
  2. Remove the tailgate from the vehicle.
  3. Remove the bolt (1) attaching the right side hinge (2) to the side of the tailgate.
  4. Locate and drill out the large weld (2) attaching the hinge (1) to the backside of the tailgate bracket (3). Remove the hinge.Important: Because the new hinge must be welded to the bracket on the tailgate in the next steps, do not pain the hinge until after installation. After welding is complete, the new hinge must be primed and painted in the body color.
  5. Install a new hinge to the tailgate and install the bolt.Tighten
    Tighten the bolt to 27 N·m (20 lb ft).
  6. Weld the backside of the new hinge to the original bracket on the tailgate.
  7. Tape off the area around the hinge and prime and paint the hinge as required.
  8. Reinstall the tailgate on the vehicle and proceed to the section titled, "Support Cable Replacement."
Support Cable Replacement - Classic CK and Sierra
The following procedure provides instruction for replacing the rear endgate (tailgate) support cables.
  1. Open the rear tailgate and support it as necessary.
  2. Release (unhook) the right side tailgate support cable from the pickup box.
    Important: If the support cable (2) has NOT been replaced previously, there will be a toothed nut or plastic nut (1) located between the latch (4) and the tailgate that MAY prevent the bolt (3) from being removed in the next step. The nut is an assembly aid used in teh assembly plant. Do not reinstall or replace the toothed or plastic nut when installing the new support cable.
  3. Loosen the bolt (3) that attaches the opposite end of the support cable to the latch assembly (2).
    If the toothed or plastic nut IS present, you will only be able to loosen the bolt partially from the latch. If this condition is encountered, proceed to the next step.
    If the toothed or plastic nut is NOT present, proceed to Step 8.
    Important: DO NOT loosen the other bolt completely in the next step. Leave two or three threads of the bolt engaged in the tailgate. Removing this bolt completely may allow the linkage inside the tailgate to separate from the latch.
  4. If the toothed or plastic nut is present, loosen the other two bolts (1) attaching the latch (2) to the tailgate. DO NOT remove these bolts.
  5. Finish loosening the bolt that attaches the support cable. The bolt will NOT be removable even though the threads are completely out.
  6. Place an interior trim removal type tool (2) between the support cable end (3) and the latch (1), and pry the two apart. As the two spread apart, the toothed or plastic nut on the other side of the latch will begin to move towards the end of the bolt.
  7. Once the toothed or plastic nut has moved away from the backside of the latch, use long nose pliers to grasp and twist it off of the bolt. Discard the toothed nut.
  8. Remove the bolt and support cable.Important: Do not reinstall the toothed or plastic nut when installing the new support cable. Also, the support cables used on these vehicles are interchangeable from side to side, and no washers are to be isntalled like those used on the new style trucks (GMT800).
  9. Install the new support cable to the latch and reinstall the original bolt.Tighten
    Tighten the bolt to 30 N·m (22 lb ft).
  10. If the other bolts were loosened earlier,Tighten
    Tighten the other loose bolts to 30 N·m (22 lb ft).
  11. Attach the opposite end of the support cable to the pickup box.
  12. Repeat this procedure on the other support cable.Important: Depending on the condition of the tailgate and related parts, one of the two new support cables (either left or right) may NOT be tight (taut) when the tailgate is fully open. This condition may be caused by several factors including a damaged hinge, pickup box, or the tailgate itself may be slightly bent due to overloading at some previous time. Replacing either or both support cables a second time will NOT correct this condition. Replacement of any additional parts to correct this condition will NOT be covered under this recall.
  13. Remove the tailgate support, close, open and re-close the tailgate. Verify that the support cables fold properly.
Escalade EXT, Avalanche, New Style Silverado and Sierra (GMT800), Kodiak, TopKick
The following procedures provides instructions for inspecting, and if necessary, replacing the rear endgate (tailgate) support cables and inspecting the right side tailgate hinge for damage, and replacing if necessary.
Support Cable Inspection -- Escalade EXT, Avalanche, New Style Silverado and Sierra, Kodiak, TopKick
    Important: In the above illustration, the clear sealant (1) is shown as black in color. This was done for illustration purposes only. If sealant is present on the support cables it will be clear or hazy (cloudy) in appearance.
  3. Inspect the end (eyelet) of the support cable that attaches to the tailgate for sealant covering the end of the cable strands.
    If there IS a clear type sealant (1) over the end of the cable strands, the support cable needs to be replaced. Reconnect the support cable to the pickup box and perform this same inspection on the left support cable. After inspecting both cables, proceed to the section titled "Hinge Inspection."
    If there IS NOT a clear type sealant (2) over the end of the cable strands, that support cable does NOT need to be replaced. Reconnect the support cable to the pickup box and perform this same inspection on the left support cable. After inspecting both cables, proceed to the section titled "Hinge Inspection."
Hinge Inspection - Escalade EXT, Avalanche, New Style Silverado and Sierra, Kodiak, TopKick
  2. Release (unhook) the RIGHT side tailgate support cable from the pickup box again.
    If the tailgate hinge (2) will NOT disengage from the pickup box on the right side, no repair is needed to the hinge. Proceed to the section titled "Support Cable Replacement" and replace any support cable that HAD sealant in the earlier inspection. If neither of the support cables requires replacement, no further action is required.
    If the tailgate hinge (3) will disengage from the pickup box on the right side, proceed to the next step.
    If the hinge is NOT damaged, no repair is needed to the hinge. Proceed to the section titled, "Support Cable Replacement" and replace any support cables that HAD sealant in the earlier inspection. If neither of the support cables require replacement, no further action is required.
    If the hinge IS damaged or bent, the hinge needs to be replaced. Proceed to the section titled, "Hinge Replacement."
Hinge Replacement - Escalade EXT, Avalanche, New Style Silverado and Sierra, Kodiak, TopKick
The following procedure should only be performed if the right side of the tailgate could be disengaged from the pickup box.
  3. Remove the two bolts attaching the right side hinge to the tailgate.Important: On Chevrolet Silverado and GMC Sierra models, the NEW hinge being installed must be primed and painted in the body color prior to installation. New hinges for the Chevrolet Avalanche and Cadillac Escalade EXT come pre-painted in a glossy black primer, these hinges must still be painted black.
  4. Install a NEW hinge to the tailgate and install the two bolts.Tighten
    Tighten the bolts to 25 N·m (18 lb ft).
  5. Reinstall the tailgate on the vehicle. If one or both tailgate support cables require replacement, proceed to the section titled "Support Cable Replacement". If neither support cables require replacement, no further action is required.
Support Cable Replacement - Escalade EXT, Avalanche, New Style Silverado and Sierra, Kodiak, TopKick
The following procedure should only be performed if sealant was found in one or both support cables in the earlier inspection.
Important: If the support cable (2) has NOT been replaced previously, there will be a toothed nut (1) located between the latch (4) and the tailgate that will prevent the bolt (3) from being removed in the next step. The nut is an assembly aid used in the assembly plant. The nut does NOT need to be reinstalled or replaced when installing a new support cable in this recall.
  2. Loosen the bolt (1) that attaches the opposite end of the support cable to the latch assembly (2).
    If the toothed nut is present, you will only be able to loosen the bolt partially from the latch. If this condition is encountered, proceed to the next step.
    If the toothed nut is not present, proceed to Step 6.
  3. If the toothed nut is present, loosen the other bolt (3) attaching the latch to the tailgate. DO NOT remove this bolt.
  4. Finish loosening the bolt that attaches the support cable. The bolt will NOT be removable even though the threads are completely out.
  5. Place an interior trim removal type tool (2), or equivalent, between the support cable end (3) and the latch (1), and pry the two apart. As the two spread apart, the toothed nut on the other side of the latch will begin to move towards the end of the bolt.
  6. Once the toothed nut has moved away from the backside of the latch, use long nose pliers to grasp and twist it off of the bolt. Discard the toothed nut.
  7. Remove the bolt and support cable.Notice: Due to manufacturing variation in the thickness of the latch, support cable end, and the shoulder on the bolt, a spacer (flat washer) must be used when installing the new cable. The washer will act as an extension to the shoulder on the bolt, and the outside diameter of the washer will allow it to fit inside of the opening in the cable end. This will allow the cable end to rotate freely on the bolt/latch when the tailgate is closed and prevent the support cable from getting pinched between the tailgate and the pickup box. The washer does part number listed in this bulletin MUST BE used when installing the new support cables. Its dimensions are critical for correct cable positioning when closing the tailgate and it has the corrosion protection specified by GM. DO NOT use any other washer in place of the one listed in this recall.
    Important: The washer does NOT replace the toothed nut removed earlier and is NOT to be installed between the latch and the tailgate.
    Notice: When installing the new support cable, make sure that the left side (LS) is installed on the left (driver's) side of the vehicle, and the right side (RS) is installed on the right (passenger) side. The support cables are marked with an LS or RS on the end of the cable that attaches to the tailgate. Installing a support cable on the incorrect side of the vehicle may result in the cable getting damaged when the tailgate is closed.
  8. Install one new flat washer on the bolt followed by a new support cable. The end of the support cable should go over the washer and onto the shoulder of the bolt.
  9. Install the bolt, flat washer, and cable assembly into the latch and tailgate.Tighten
    Tighten the bolt to 25 N·m (18 lb ft).
  10. If the other bolt was loosened earlier,Tighten
  11. Verify that the support cable end rotates freely on the bolt.
  12. Attach the opposite end of the support cable to the pickup box.
  13. Repeat the procedure on the other support cable.Important: Depending on the condition of the tailgate and related parts, one of the two new support cables (either left or right) may NOT be tight (taut) when the tailgate is fully open. This condition may be caused by several factors including a damaged hinge, pickup box, or the tailgate itself may be slightly bent due to overloading at some previous time. Replacing either or both support cables a second time will NOT correct this condition. Replacement of any additional parts to correct this condition will NOT be covered under this recall.
  14. Remove the tailgate support, close, open and re-close the tailgate. Verify that the support cables fold properly.
Customer Reimbursement - For US
All customer requests for reimbursement for previous repairs for the recall condition will be handled by the Customer Assistance Center, not by dealers.
A General Motors Product Recall Customer Reimbursement Procedure Form is included with the customer letter.
Important: Refer to the GM Service Policies and Procedures Manual, section 6.1.12 for specific procedures regarding customer reimbursement and the form.
Customer Reimbursement - For Canada
Customer requests for reimbursement of previously paid repairs to correct the condition addressed in this bulletin are to be submitted by January 31, 2006..
All reasonable customer paid receipts should be considered for reimbursement. The amount to be reimbursed will be limited to the amount the repair would have cost if completed by an authorized General Motors dealer.
When a customer requests reimbursement, they must provide the following:
• Proof of ownership at time of repair.
• Original paid receipt confirming the amount of repair expense(s) that were not reimbursed, a description of the repair, and the person or entity performing the repair.
Claims for customer reimbursement on previously paid repairs are to be submitted as required by WINS.
Important: Refer to the GM Service Policies and Procedures Manual, section 1.6.2, for specific procedures regarding customer reimbursement verification.
Courtesy Transportation
The General Motors Courtesy Transportation program is intended to minimize customer inconvenience when a vehicle requires a repair that is covered by the New Vehicle Limited Warranty. The availability of courtesy transportation to customers whose vehicles are within the warranty coverage period and involved in a product recall is very important in maintaining customer satisfaction. Dealers are to ensure that these customers understand that shuttle service or some other form of courtesy transportation is available and will be provided at no charge. Dealers should refer to the General Motors Service Policies and Procedures Manual for Courtesy Transportation guidelines.
Claim Information
Submit a Product Recall Claim with the information indicated below:
Repair Performed
Part Count
Part No.
Parts Allow
CC-FC
Labor Op
Labor Hours
Net Item
Inspect Tailgate Support Cables (No Replacement Req'd) AND Inspect Hinge (Inc. Hinge Replacement, If Req'd) - New Style Silverado, Sierra, Avalanche, Escalade EXT, Kodiak, TopKick
0-1
MA-96
V1241
0.2
N/A
Add: Paint Time
0.2
$4.50 USD
$12.12 CAD
Inspect & Replace Tailgate Support Cables (Inc. Hinge Replacement If Req'd) - New Style Silverado, Sierra, Avalanche, Escalade EXT, Kodiak, TopKick
2-5
MA-96
V1242
0.3
N/A
Add: Paint Time
0.2
$4.50 USD
$12.12 CAD
Inspect Hinge and Replace Tailgate Support Cables - Classic CK, Sierra
2
MA-96
V1239
0.3
N/A
Add: Replace, Prime and Paint Hinge
$4.50 USD
$12.12 (CAD)
N/A
N/A
N/A
MA-96
N/A
Customer Reimbursement (Canadian and Export Dealers/US CAC)
N/A
N/A
N/A
MA-96
V1243
0.2
* -- The "Parts Allowance" should be the sum total of the current GMSPO Dealer net price plus applicable Mark-Up or Landed Cost Mark-Up (for IPC) for the hinge (if required) needed to complete the repair.
** -- The "Parts Allowance" should be the sum total of the current GMSPO Dealer net price plus applicable Mark-Up or Landed Cost Mark-Up (for IPC) for the tailgate support cable(s), and if required, the hinge needed to complete the repair.
*** -- The amount identified in the "Net Item" column represents the material allowance for the aerosol spray paint used on the hinge, if replaced.
**** -- Submit courtesy transportation using normal labor operations for courtesy transportation as indicated in the GM Service Policies and Procedures Manual.
***** -- The amount identified in the "Net Item" column should represent the actual dollar amount for courtesy transportation.
****** -- The amount identified in the "Net Item" column should represent the dollar amount reimbursed to the customer.
Note: Canadian dealers should refer to the Canadian distribution of the bulletin for detailed claim information.
Refer to the General Motors WINS Claims Processing Manual for details on Product Recall Claim Submission.
Customer Notification -- For US and Canada
General Motors will notify customers of this recall on their vehicle (see copy of customer letter included with this bulletin).
Customer Notification -- For IPC
Letters will be sent to known owners of record located within areas covered by the US National Traffic and Motor Vehicle Safety Act. For owners outside these areas, dealers should notify customers using the attached sample letter.
Dealer Recall Responsibility -- For US and IPC (US States, Territories, and Possessions)
The US National Traffic and Motor Vehicle Safety Act provides that each vehicle which is subject to a recall of this type must be adequately repaired within a reasonable time after the customer has tendered it for repair. A failure to repair within sixty days after tender of a vehicle is prima facie evidence of failure to repair within a reasonable time. If the condition is not adequately repaired within a reasonable time, the customer may be entitled to an identical or reasonably equivalent vehicle at no charge or to a refund of the purchase price less a reasonable allowance for depreciation. To avoid having to provide these burdensome remedies, every effort must be made to promptly schedule an appointment with each customer and to repair their vehicle as soon as possible. In the recall notification letters, customers are told how to contact the US National Highway Traffic Safety Administration if the recall is not completed within a reasonable time.
Dealer Recall Responsibility -- All
All unsold new vehicles in dealers' possession and subject to this recall MUST be held and inspected/repaired per the service procedure of this recall bulletin BEFORE customers take possession of these vehicles.
Dealers are to service all vehicles subject to this recall at no charge to customers, regardless of mileage, age of vehicle, or ownership, from this time forward.
Customers who have recently purchased vehicles sold from your vehicle inventory, and for which there is no customer information indicated on the dealer listing, are to be contacted by the dealer. Arrangements are to be made to make the required correction according to the instructions contained in this bulletin. A copy of the customer letter is provided in this bulletin for your use in contacting customers. Recall follow-up cards should not be used for this purpose, since the customer may not as yet have received the notification letter.
In summary, whenever a vehicle subject to this recall enters your vehicle inventory, or is in your dealership for service in the future, please take the steps necessary to be sure the recall correction has been made before selling or releasing the vehicle.
GENERAL MOTORS PRODUCT PROGRAM CUSTOMER REIMBURSEMENT PROCEDURE
If you have paid to have this recall condition corrected prior to receiving this notification, you may be eligible to receive reimbursement.
Requests for reimbursement may include parts, labor, fees and taxes. Reimbursement may be limited to the amount the repair would have cost if completed by an authorized General Motors dealer.
Your claim will be acted upon within 60 days of receipt.
If your claim is:
• Approved, you will receive a check from General Motors.
• Denied, you will receive a letter from General Motors with the reason(s) for the denial, or
• Incomplete, you will receive a letter from General Motors identifying the documentation that is needed to complete the claim and offered the opportunity to resubmit the claim when the missing documentation is available.
Please follow the instructions on the Claim Form provided on the reverse side to file a claim for reimbursement. If you have questions about this reimbursement procedure, please call the toll-free telephone number provided at the bottom of the form. If you need assistance with any other concern, please contact the appropriate Customer Assistance Center at the number listed below. The Customer Assistance Center hours of operation are from 8:00 AM - 11:00 PM eastern standard time Monday through Friday
Division
Number
Text Telephones (TTY)
Cadillac
1-866-982-2339
1-800-833-2622
Chevrolet
1-800-630-2438
1-800-833-2622
GMC
1-866-996-9463
1-800-462-8583
Puerto Rico - English
1-800-496-9992
Puerto Rico - Español
1-800-496-9993
Virgin Islands
1-800-496-9994
GENERAL MOTORS PRODUCT PROGRAM CUSTOMER REIMBURSEMENT CLAIM FORM
THIS SECTION TO BE COMPLETED BY CLAIMANT
Date Claim Submitted:
Vehicle Identification Number (VIN):
Mileage at Time of Repair:
Date of Repair:
Claimant Name (please print):
Street Address or PO Box Number:
City, State, ZIP Code:
Daytime Telephone Number (include Area Code):
Evening Telephone Number (include Area Code):
Amount of Reimbursement Requested: $
THE FOLLOWING DOCUMENTATION MUST ACCOMPANY THIS CLAIM FORM
Original or clear copy of all receipts, invoices and/or repair orders that show:
• The name and address of the person who paid for the repair.
• The Vehicle Identification Number (VIN) of the vehicle that was repaired.
• What problem occurred, what repair was done, when it was done and who did it.
• The total cost of the repair expense that is being claimed.
• Payment for the repair in question and the date of payment.
(copy of front and back of cancelled check, or copy or credit card receipt.)
My signature to this document attests that all attached documents are genuine and I request reimbursement for the expense I incurred for the repair covered by this special policy.
Claimant's Signature:
Please mail this claim form and the required documents to:
P.O. Box 33170
Detroit, MI 48232-5170
All recall reimbursement questions should be directed to the following number: 1-800-204-0261.
September 2004Dear General Motors Customer:
This notice is sent to you in accordance with the requirements of the National Traffic and Motor Vehicle Safety Act.
You may have already been contacted regarding this recall, but this letter is to inform you that parts are available to service your vehicle.
Reason For This Recall
What Will Be Done
Your GM dealer will replace the galvanized support cables with stainless steel support cables. In addition, the tailgate hinge will be inspected and replaced, if necessary. This service will be performed for you at no charge .
Until stainless steel support cables can be installed on your vehicle, do not stand, sit, or apply loads directly onto the tailgate when it's in the full open (horizontal) position. This will reduce the potential of personal injury and damage to the outer panel of your tailgate. Additionally, when loading or unloading cargo from the pickup box, the tailgate should be removed. Please see your Owner's Manual for tailgate removal instructions.
How Long Will The Repair Take?
This service correction will take approximately 20 to 30 minutes. However, due to service scheduling requirements, your dealer may need your vehicle for a longer period of time.
Contacting Your Dealer
To limit any possible inconvenience, we recommend that you contact your GM dealer as soon as possible to schedule an appointment for this repair. By scheduling an appointment, your dealer can ensure that the necessary parts will be available on your scheduled appointment date.
Should your dealer be unable to schedule a service date within a reasonable time, you should contact the appropriate Customer Assistance Center at the number listed below. The Customer Assistance Center hours of operation are from 8:00 AM - 11:00 PM eastern standard time Monday through Friday.
Division
Number
Cadillac
1-866-982-2339
1-800-833-2622
Chevrolet
1-800-630-2438
1-800-833-2622
GMC
1-866-996-9463
1-800-462-8583
1-800-496-9992
1-800-496-9993
Virgin Islands
1-800-496-9994
GMICT
1-800-862-4389
If, after contacting the appropriate customer assistance center, you are still not satisfied that we have done our best to remedy this condition without charge and within a reasonable time, you may wish to write the Administrator, National Highway Traffic Safety Administration, 400 Seventh Street SW, Washington, DC 20590 or call 1-888-327-4236.
Customer Reply Card
The enclosed customer reply form identifies your vehicle. Presentation of this form to your dealer will assist in making the necessary correction in the shortest possible time. If you no longer own this vehicle, please let us know by completing the form and mailing it back to us.
The enclosed form explains what reimbursement is available and how to request reimbursement if you have paid for repairs for the recall condition.
If your vehicle is within the New Vehicle Limited Warranty your dealer may provide you with shuttle service or some other form of courtesy transportation while your vehicle is at the dealership for this repair. Please refer to your Owner's Manual and your dealer for details on Courtesy Transportation.
Recall Information Online
More information about this recall (including frequently asked questions) is available online at the Owner Center at My GMLink. This free online service offers vehicle and ownership-related information and tools tailored to your specific vehicle. To join, visit www.mygmlink.com and enter your Vehicle Identification Number (VIN) shown on the enclosed form, to get the most personalized information for your vehicle.
Federal regulation requires that any vehicle lessor receiving this recall notice must forward a copy of this notice to the lessee within ten days.
We are sorry to cause you this inconvenience; however, we have taken this action in the interest of your safety and continued satisfaction with our products.
Enclosure
04007
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
999999994.gif WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2008 General Motors Corporation. All rights reserved.
VIN : 1GCEK19Z07Z202267
VEHICLE INFORMATION
Merchandising Model : CK15753 -2007 SILVERADO LT1 1500 4WD EXT CAB Warranty Start Date : 05/01/2007
Delivering Dealer : SPITZER CHEVROLET, INC.
PO BOX 487
NORTHFIELD , OH 44067-0487
(330) 467-4141
Site Code : 28570
Business Associate Code : 113611
YT 06162 SERVICE UPDATE-INVENT/CUST VEHS E85 VFFS UPDATE REPGM ECM *EXPIRES 8YR/80K MI* 06/26/2007 Open
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 05/01/2007 62 miles 05/01/2010 36062 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 05/01/2007 62 miles 05/01/2013 100062 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 05/01/2007 62 miles 05/01/2015 80062 miles
60/100000 POWERTRAIN COVERAGE LIMITED WARRANTY 05/01/2007 62 miles 05/01/2012 100062 miles
36/36000 FEDERAL EMISSION 05/01/2007 62 miles 05/01/2010 36062 miles
CLAIM HISTORY
06/12/2007 120138 # B7540 - MOLDING, WINDSHIELD REVEAL - R&R OR REPLACE 5380 miles
06/12/2007 120138 # B4161 - OUTSIDE REARVIEW MIRROR MOTOR REPLACEMENT - LEFT SIDE 5380 miles
06/12/2007 120138 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 5380 miles
02/28/2007 028405 I Z6998 - PDI ADDS 10 miles
10/27/2006 A02267 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
CLAIM HISTORY
Repair Order Date : 06/12/2007 Repair Order Number : 120138 Odometer Reading : 5380 miles
Serviced By : SPITZER CHEVROLET, INC.
PO BOX 487
NORTHFIELD, OH 44067-0487
(330) 467-4141 Selling Source : 13 - CHEVROLET
Site Code : 28570
06/15/2007 804 01 # B7540 - MOLDING, WINDSHIELD REVEAL - R&R OR REPLACE N/A N
06/15/2007 804 02 # B4161 - OUTSIDE REARVIEW MIRROR MOTOR REPLACEMENT - LEFT SIDE 15226944 - MIRROR N
06/15/2007 804 03 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 15226944 - MIRROR N
Repair Order Date : 02/28/2007 Repair Order Number : 028405 Odometer Reading : 10 miles
Serviced By : SPITZER AUTO WORLD AMHERST, INC.
200 N LEAVITT RD
AMHERST, OH 44001-1125
(440) 988-4444 Selling Source : 13 - CHEVROLET
Site Code : 28419
Business Associate Code : 152090
03/16/2007 778 01 I Z6998 - PDI ADDS N/A N
Repair Order Date : 10/27/2006 Repair Order Number : A02267 Odometer Reading : 0 miles
200 N LEAVITT RD
Site Code : 28419
10/31/2006 739 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME N/A N
VIN 1GCEK19Z07Z202267
VEHICLE BUILD
Gross Vehicle Weight Rating : 2906 kg (6408 lb) Order Number : KJFVRM
Build Date : 10/27/2006 Build Plant : 17Z53
OPTION CODES
AE7 - CUSTOM CLOTH BENCH SEATING AG1 - SIX-WAY POWER DRIVER SEAT
AJ1 - TINTED GLASS AL0 - SENSOR INDICATOR INFLATABLE RESTRAINT FRT PASS
BVE - ASSIST STEPS B30 - CARPETING, COLOR-KEYED
B32 - FRONT COLOR-KEYED FLOOR MATS B33 - REAR COLOR KEYED FLOOR MATS
B71 - WHEEL FLARES B85 - BODY SIDE MOLDING
CJ3 - AIR COND., DUAL ZONE MANUAL C49 - ELECTRIC REAR WINDOW DEFOGGER
C7H - GVW RATING - 6,400 LB DF5 - ISRV MIRROR W/COMPASS & TEMP
DK7 - INTERIOR CUSTOM ROOF CONSOLE W/ MAP LIGHTS DL8 - DUAL PWR HEATED OSRV MIRRORS
DNR - DEALER INSTALLED EQUIPMENT EVA - EVAP EMISSION REQUIREMENT
FK2 - TORSION BAR SPRING ADJUSTMENT FK3 - TORSION BAR SPRING ADJUSTMENT
FWI - FORT WAYNE PLANT GU6 - REAR AXLE 3.42 RATIO
G80 - LOCKING REAR DIFFERENTIAL JF7 - BRAKES, 17" DISC/DRUM
KG3 - 145 AMP ALTERNATOR KNP - HD AUX TRANS. COOLING SYS
KUP - THROTTLE CONTROL ELECTRONIC K34 - CRUISE CONTROL
K47 - HIGH CAPACITY AIR CLEANER L59 - VORTEC 5.3L V8 FLEX FUEL ENGINE
M30 - 4-SPD AUTOMATIC TRANSMISSION NP5 - LEATHER WRAPPED STEERING WHEEL
NP8 - AUTOTRAC ACTIVE TRANSFER CASE NT8 - EMISSION SYSTEM FEDERAL, TIER
NZZ - OFF ROAD - SKID PLATES PDX - EXTENDED CAB VALUE PACKAGE: * VORTEC 5.3L FLEX FUEL ENGINE * LOCKING REAR DIFFERENTIAL * HD TRAILERING EQUIPMENT * ALUMINUM WHEELS * CHROME TUBULAR ASSIST STEPS *** DEALER INSTALLED ***
P25 - 17" ALUMINUM WHEELS QJM - P265/70R17 OOR WOL TIRES
R5C - TIRE BRAND ALL BRIDGESTONE R6K
R6P - PREMIUM PAINT R8C - ******************************* *** 2007 CLASSIC SILVERADO **** *******************************
R9N - LEATHER SEAT TRIM SLM - STOCK ORDERS
TR3 - CHROME GRILLE TSM - PROCESSING CODE - SUSPENSION
UB0 - AM/FM STEREO W/CD PLAYER (REPLACES STD/OPT RADIO) UQ3 - ENHANCED AUDIO SPEAKERS
VB3 - CHROME REAR BUMPER VG3 - CHROME FRONT BUMPER
VR4 - WEIGHT DISTRIB. PLATFORM HITCH VXS - COMPLETE VEHICLE LABEL
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XJM - TIRE FRONT P265/70R17-113S WOL R/PE ST TL OOR
X88 - CHEVROLET CONVERSION YD3 - BASE AXLE
YD5 - BASE FRONT SPRING YD6 - BASE REAR SPRING
YE9 - SILVERADO YJM - P265/70R17-113S WOL R/PE ST TL OOR
ZJP - SPARE TIRE P265/70R17 ZY1 - SOLID PAINT
Z71 - OFF-ROAD PACKAGE: * OFF-ROAD SUSPENSION * SKID PLATES * WHEEL FLARES Z82 - HD TRAILERING EQUIPMENT
1LT - LT1 DECOR INCLUDES: * DUAL PWR HEATED OSRV MIRRORS * TINTED GLASS * POWER LOCKS & WINDOWS * REMOTE KEYLESS ENTRY WITH CONTENT THEFT ALARM * ISRV MIRROR W/ COMPASS & TEMP * LEATHER WRAPPED STEERING WHL * GRILLE-CHROME STYLED SURROUND 1SZ - TOTAL VALUE PAC SAVINGS
59U - SILVER BIRCH METALLIC 6YH - COMPONENT FRT LH COMPUTER SEL
69D - DARK CHARCOAL 69I - DK PEWTER INTERIOR TRIM
© 1998-2005 General Motors Corporation. All Rights Reserved.
Vehicle Component
Source Plant : K - GM OF CANADA, LTD. ST. CATHARINES, ONTARIO
Part/Num Broadcast : CTH Traceability : 062981864
Date Scanned : 10/26/2006 Time Scanned : 21.15.00 Scan Station : 02
Part/Num Broadcast : Y4K Traceability : 243642976
Date Scanned : 10/26/2006 Time Scanned : 20.52.00 Scan Station : 16
Source Plant : 7
Part/Num Broadcast : 1528 Traceability : 370102765
Date Scanned : 10/26/2006 Time Scanned : 20.52.00 Scan Station : 99
Source Plant : N
Part/Num Broadcast : GY Traceability : 0BM133141
Date Scanned : 10/26/2006 Time Scanned : 21.30.00 Scan Station : 05
Part/Num Broadcast : 7KCD Traceability : 44922082
Date Scanned : 10/26/2006 Time Scanned : 21.22.00 Scan Station : 15
Source Plant : G
Part/Num Broadcast : ZH6 Traceability : N664459
Date Scanned : 10/26/2006 Time Scanned : 23.04.00 Scan Station : 04
Part/Num Broadcast : SC4 Traceability : 048403
Date Scanned : 10/26/2006 Time Scanned : 22.07.00 Scan Station : 03
Source Plant : 9
Part/Num Broadcast : YKYY Traceability : 26297NGNR
Date Scanned : 10/27/2006 Time Scanned : 07.16.00 Scan Station : DV
Part/Num Broadcast : 5012 Traceability : 00325834
Date Scanned : 10/26/2006 Time Scanned : 23.07.00 Scan Station : 14
Part/Num Broadcast : 8212 Traceability : 1GZ32Y2
Date Scanned : 10/26/2006 Time Scanned : 23.27.00 Scan Station : 12
Part/Num Broadcast : 0149 Traceability : 62370XN9D
Part/Num Broadcast : 0149 Traceability : 62370XN9C
Part/Num Broadcast : 9602 Traceability : 9AGGN78
Date Scanned : 10/26/2006 Time Scanned : 20.39.00 Scan Station : 21
Part/Num Broadcast : 5883 Traceability : 362922TFC
Component Code : CC - SEQ NUM (FLEX) BODY ASM
Source Plant : N/A
Part/Num Broadcast : 1ZS Traceability : 0860041
Date Scanned : 10/17/2006 Time Scanned : 04.02.00 Scan Station : N/A
Source Plant : N/A
Part/Num Broadcast : 1PA Traceability : 4389700
Date Scanned : 10/26/2006 Time Scanned : 09.41.00 Scan Station : N/A
Source Plant : N/A
Part/Num Broadcast : 1KA Traceability : 4383635
Date Scanned : 10/26/2006 Time Scanned : 16.57.00 Scan Station : N/A
Source Plant : N/A
Part/Num Broadcast : 1FA Traceability : 9102577
Date Scanned : 10/26/2006 Time Scanned : 18.27.00 Scan Station : N/A
Delivery Date : 05/01/2007 Delivery Type : 016 - GM SUPPLIER Delivered Odometer : 62 miles
PO BOX 487
(330) 467-4141
Delivery Site Code : 28570
INVOICE INFORMATION
Invoice Date : 10/27/2006
Site Address : SPITZER AUTO WORLD AMHERST, INC.
200 N LEAVITT RD
AMHERST , OH 44001-1125
Site Code : 28419
SHIP-TO INFORMATION
Ship-To Date : N/A
200 N LEAVITT RD
Site Code : 28419
There is an open TSB on this vehicle:
Document ID: 2010138 #06162C: Service Update for Inventory and Customer Vehicles-E85 Virtual Flex Fuel Sensor (VFFS) Update-Reprogram ECM - (Sep 12, 2007)
Subject:06162C - Service Update for Inventory and Customer Vehicles - E85 Virtual Flex Fuel Sensor (VFFS) Update - Reprogram ECM
Models:2006 Chevrolet Impala, Monte Carlo, Silverado, Avalanche, Tahoe, Suburban
2006 GMC Sierra, Yukon, Yukon XL
2007 Buick Terraza
2007 Chevrolet Impala, Monte Carlo, Uplander, Silverado Classic, Tahoe, Suburban, Avalanche, Silverado, Express
2007 GMC Sierra Classic, Yukon, Yukon XL, Sierra, Savana
2007 Pontiac Montana SV6
Equipped with E85 compatible 5.3L V8 (RPO L59 - VIN Z, LC9 - VIN 3 or RPO LMG - VIN 0); 3.5L V6 (RPO LZE - VIN K); or 3.9L V6 (RPO LGD - VIN W) engines
THIS BULLETIN HAS BEEN REVISED TO ADD 2007 CHEVROLET EXPRESS AND GMC SAVANA VANS TO THE LIST OF INVOLVED VEHICLES.
PLEASE DISCARD ALL COPIES OF BULLETIN 06162B, ISSUED JUNE 2007.
THIS SERVICE UPDATE INCLUDES VEHICLES IN DEALER INVENTORY AND CUSTOMER VEHICLES THAT RETURN TO THE DEALERSHIP FOR ANY REASON, AND WILL EXPIRE AT THE END OF THE INVOLVED VEHICLE'S 8 YEAR/80,000 MILES (130,000 KM) EMISSION CONTROLLER WARRANTY PERIOD.
Purpose
This bulletin provides a service procedure to reprogram the Engine Control Module (ECM) on certain 2006 Chevrolet Impala, Monte Carlo, Silverado, Avalanche, Tahoe, Suburban; GMC Sierra, Yukon, Yukon XL; 2007 Buick Terraza; Chevrolet Impala, Monte Carlo, Uplander, Silverado Classic, Tahoe, Suburban, Avalanche, Silverado, Express; GMC Sierra Classic Yukon, Yukon XL, Sierra, Savana; and Pontiac Montana SV6 vehicles, equipped with E85 compatible 5.3L V8 (RPO L59 - VIN Z, RPO LC9 - VIN 3 or RPO LMG - VIN 0); 3.5L V6 (RPO LZE - VIN K); or 3.9L V6 (RPO LGD - VIN W) engines. This reprogramming will update the Virtual Flex Fuel Sensor (VFFS) software algorithm installed in these E85 compatible vehicles to better adapt to the wide variety of ethanol concentrations and refueling processes they may encounter.
This service procedure should be completed as soon as possible on involved vehicles currently in dealer inventory and customer vehicles that return to the dealer for any type of service during the 8 year / 80,000 mile (130,000 km) Emission Controller Warranty.
Vehicles Involved
A ist of involved vehicles currently in dealer inventory is available on the "Service Update Bulletin Information" link under the "Service" tab in DealerWorld (US), or attached to the Dealer Communication (Canada), used to release this bulletin. Customer vehicles that return for service, for any reason, and are still covered under the vehicle's emission warranty, and are within the VIN breakpoints provided beleow, should be checked for vehicle eligibility in the appropriate system listed below:
Year
Division
Model
From
Through
2006
Chevrolet
Impala
69100007
69438808
2006
Chevrolet
Monte Carlo
69102942
69438734
2006
Chevrolet
Silverado
61100279
61358755
6E110023
6E291940
6G125877
6G274468
6Z100011
6Z303186
2006
Chevrolet
Avalanche
6G100016
6G245882
2006
Chevrolet
Tahoe
6J100048
6J165033
6R100042
6R169855
2006
Chevrolet
Suburban
6G100009
6G245845
6J100003
6J178562
2006
GMC
Sierra
61101985
61358725
6E110412
6E291706
6G129269
6G273549
6Z100025
6Z303187
2006
GMC
Yukon
6J101543
6J164404
6R100058
6R164730
2006
GMC
Yukon XL
6G100057
6G241289
6J100001
6J178563
2007
Buick
Terraza
7D148216
7D177357
2007
Chevrolet
Impala
79100023
79316285
2007
Chevrolet
Monte Carlo
79100017
79316270
2007
Chevrolet
Uplander
7D100001
7D177490
2007
Chevrolet
Silverado Classic
71100003
71183494
7E100023
7E194746
7G145196
7G257459
7Z100061
7Z207434
2007
Chevrolet
Tahoe
7J100004
7J275832
7R100001
7R302606
2007
Chevrolet
Suburban
7G100004
7G222398
7J100041
7G275819
7R136280
7R291687
2007
Chevrolet
Avalanche
7G100002
7G222473
2007
Chevrolet
Silverado
71500146
71512674
7Z500005
7Z500136
2007
Chevrolet
Express
71100016
71254855
2007
GMC
Sierra Classic
71100001
71183492
7E100017
7E198860
7G100012
7G254277
7Z100004
7Z205308
2007
GMC
Yukon
7J100001
7J275790
7R100040
7R302573
2007
GMC
Yukon XL
7J108392
7J275793
7R137718
7R291680
2007
GMC
Sierra
71500145
71507238
7Z500003
7Z500144
2007
GMC
Savana
71100034
71254756
2007
Pontiac
Montana SV6
7D161179
7D177329
Important: Dealers are to confirm vehicle eligibility prior to beginning repairs by using the GM Vehicle Inquiry System (GMVIS). Not all vehicles within the above breakpoints may be involved.
Parts Information
Do not attempt to order the calibration number from GMSPO. The calibration numbers required for this service procedure are programmed into control modules via a Techline Tech 2® scan tool and TIS2Web website with the following calibration updates..
2007 Pick Up and SUV Trucks: Use data version 11.5 for 2006 for later, available on TIS2Web 11/13/06; and on TIS DVD version 12.0/2006 or later, mailed to dealers beginning 12/13/06.
2006/07 Chevrolet Impala, Monte Carlo: Use data versioni 12.5 for 2006 or later, available on TIS2Web 12/18/06; and on TIS DVD version 1.0/2007 or later, mailed to dealers beginning 01/31/07.
2007 Buick Terraza, Chevrolet Uplander, Pontiac Montana SV6: Use data version 2.0 for 2007 or later, available on TIS2Web 2/05/07; and on TIS DVD version 2.0/2007 or later, mailed to dealers beginning 02/22/07.
2006 Pickup and SUV Trucks: Use data version 6.5 for 2007 or later, available on TIS2Web 6/11/07.
2007 Classic Pickup Trucks and Full Size Vans: Use data version 7.0 for 2007 or later, available on TIS2Web 6/24/07; and on TIS DVD version 7.0/2007 or later, mailed to dealers beginning 7/05/07.
If you cannot access the calibration, call the Techline Customer Support Center and it will be provided.
Service Procedure
The "Required Field Actions" section of the GM Vehicle Inquiry System (GMVIS) must be checked to determine if a specific vehicle requires this action. If GMVIS indicates that Service Update Bulletin 06162C remains ‘open’ and ECM reprogramming has not taken place, reprogram the ECM using a Tech 2 scan tool with the calibration update from TIS2Web.
Refer to the latest version of Technical Service Bulletin 06-06-04-010 and Service Information to perform the ECM Reprogramming procedure and, if needed, the Fuel Composition Reset Procedure. The Fuel Composition Reset Procedure is only needed if the measured ethanol content is more than 15% different than the ECM estimated value.
Important: If it is assured that only non-blended (containing 10% or less ethanol) gasoline is in the vehicle fuel tank, proceed directly to ECM programming.
Claim Information
For vehicles repaired under this product enhancement, use:
Labor Operation
Description
Labor Time
Y0124
Engine Control Module Reprogram with SPS. (Step #7)
0.4 hr
Add A
Includes: Checking ECM Ethanol Learn Status and Ethanol Content. (Steps #1, 3)
0.3 hr
Add B
Includes: Checking ECM Ethanol Learn Status, Driving Vehicle Once to Change Learn Status and Checking Ethanol Content. (Steps #1, 2, 3)
0.7 hr
Add C
Includes: Checking ECM Ethanol Learn Status, Checking Ethanol Content, Performing Fuel Composition Reset, Driving Vehicle Once to Change Learn Status after Reset. (Steps # 1, 3, 4, 6)
0.7 hr
Add D
Includes: Checking ECM Ethanol Learn Status, Driving Vehicle Once to Change Learn Status, Checking Ethanol Content, Performing Fuel Composition Reset. (Steps # 1, 2, 3, 4, 6)
1.1 hrs
Add E
Includes: Checking ECM Ethanol Learn Status, Checking Ethanol Content, Drain and Fill Fuel Tank, Performing Fuel Composition Reset and Driving Vehicle Once to Change Learn Status after Reset. (Steps # 1, 3, 4, 5, 6)
1.2 hrs (Impala/Monte Carlo)
1.4 hrs (Mid-Size Vans)
1.5 hrs (2006-2007 Full-Size Trucks/Vans)
Add F
Includes: Checking ECM Ethanol Learn Status, Driving Vehicle Once to Change Learn Status, Checking Ethanol Content, Drain and Fill Fuel Tank, Performing Fuel Composition Reset. (Steps # 1, 2, 3, 4, 5, 6)
1.6 hrs (Impala/Monte Carlo)
1.8 hrs (Mid-Size Vans)
1.9 hrs (2006-2007 Full-Size Trucks/Vans)
    Brendan C
    Brendan C
  • Who's Online   5 Members, 1 Anonymous, 1,163 Guests (See full list)
