New guy here, just bought an 08 Cadillac EXT. Traded in a 2003 SS Silverado. Also have an H2 and a C6. Also into motorcycles. Looking forward to learning from you guys.
Welcome to the site! :ughdance:
Sounds like you've got lots of toys. Pictures please? :lol:
OK. Truck as well as some toys:
Wow, this is an active board. Very cool. Talk about being made to feel at home. Thanks.
nice Slade, Vette and bikes, I would take the H2...by the way, welcome to GM-Trucks.com
Nice wheels all around, Ted! What is the make/model of that silver bike? Welcome to the jungle! :ughdance:
That is a 2008 Kawasaki Concours 1400.
Ah yes, the supersport touring bike from Kawasaki. Don't see many of those! Sweet!
