Advice
jdwvw
I have a 2002 Silverado 1500 LS ext cab 4x4 5.3L 182k miles.
I took it in to the local dealer last year to have the knock sensors replaced. They called me a few hours later and said that the sensors were so corroded that they would have to remove the plate to get them out and that it would take a couple of extra days to get the gasket for that plate. No big deal. They finished the repair and I picked it up.
About 8 months later I started having knock sensor errors again but only if it was under a load. I decided to pull the intake off myself and see if the wires were still good and check for corrosion. When I pulled the front dust cover off the knock sensor plug came with it with no effort. So I knew then why that one was having "low signal" issues. The back one was properly secured and wasn't giving any issues. I then decided to pull the knock sensors out and check them over for corrosion. When i got them out I looked into the holes and found the seals broken like the plate had been pulled with the knock sensors still in place. They had indeed pulled the plate and replaced the gasket but not the seals. So after finding this I got to wondering just how much crap had gotten into the motor. It has been over a year since they performed the service and a lot of rainy days. I have been running Mobile 1 Synthetic in it for the last 3 years and maintained it because I wanted it to last a lot longer. The motor now has a lot of blow by and burns oil. It is also knocking really bad (piston slap) while cold.
Should I ask them to replace the engine?
Bring it to a couple of other shops and get their opinions. Depending on what they find should give you the answer to your question. Good luck.
I would have to tow it as it is still apart. The seals won't be here till Tuesday.
Well I had my wife dig up the receipt. The service was performed in March 2006. My Knock sensor issues started again in October of 2007. The knock sensor would work intermittently. The knock sensor issues were just the reason that I had found the grommets broken.
I talked to the service manager and he tried telling me that the grommets had indeed been replaced and that they just dry rotted and broke into 2 pieces with in 2 years. The hole in the grommet just happens to be about the size of the knock sensors housing.
I am concerned that the truck has been running for a little over 2 years with these grommets bad and leaking lord only knows what into my engine. This also explains why I was getting O2 sensor errors a couple of months ago.
Does anyone have a contact number for Chevy?
Called them and opened a complaint. Thanks
Also stopping by the BBB on the way out of town this afternoon.
Good luck. I hope you are able to get the problem resolved.
No offense, but after 182k things sometimes fall apart.
I would imagine that you would have a hard(impossible) time trying to prove that the repair work 2 years earlier had anything to do with the condition of the engine now.
You could always ask for a new engine, but my guess is that you have about a .000000000000000001% chance of them giving you a new one :D
    • Yes. You need to check out that thing, and the hub further.
    • Would this be normal or a worn CV Shaft? 51K miles 3.5" lift? Boots are intact and no visible leaks showing. Attached is a the video I took. Thanks     https://youtu.be/ZnW7PPRmjJY?feature=shared
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
