Vin Check Please, 2003 Tahoe Lt
Hi I did check my VIN at autocheck.com and they want me to pay for the results. The VIN has 8 or 9 records...Can you help me out with that? Many thanks!
VIN: 1GNEK13T23R204785
GM Vehicle Inquiry System
Summary
VIN : 1GNEK13T23R204785
VEHICLE INFORMATION
Merchandising Model : CK15706 -2003 TAHOE 4WD
Warranty Start Date : 06/21/2003
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : HURD CHEVROLET, INC.
1705 HARTFORD AVE
JOHNSTON , RI 02919-3203
(401) 751-6000
Selling Source : 13 - CHEVROLET
Site Code : 32304
Business Associate Code : 117960
Service Contract : Yes
Branded Title : No
Warranty Block : No
PDI Status : Paid
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
RC 03011 REMOTE KEYLESS ENTRY (RKE) SYSTEM INOPERATIVE N/A Closed
SERVICE INFORMATIONAL ITEMS
SB 06047 ONSTAR HARDWARE CAN BE UPGRADED TO DIGITAL. SEE TSB 05-08-46-006. 02/21/2007 See Bulletin
ON STAR AND XM SATELLITE RADIO INFORMATION
OnStar Equipped Yes
OnStar Status Inactive
Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
XM Equipped Yes
XM Radio ID KH2E100T
XM Status Inactive
Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 06/21/2003 5 miles 06/21/2006 36005 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 06/21/2003 5 miles 06/21/2009 100005 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 06/21/2003 5 miles 06/21/2011 80005 miles
36/50000 CALIFORNIA EMISSIONS 06/21/2003 5 miles 06/21/2006 50005 miles
84/70000 CALIFORNIA SELECT COMPONENT 06/21/2003 5 miles 06/21/2010 70005 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
04/26/2007 220793 0 F0093 - UNIVERSAL JOINT, FRONT PROPELLER SHAFT - REAR - REPLACE 66224 miles
12/29/2006 211934 0 K7231 - HOUSING AND DRUM ASSEMBLY, REVERSE INPUT - R&R OR REPLACE 60294 miles
12/29/2006 211934 0 F1447 - SEALS, FRONT DIFFERENTIAL OUTPUT SHAFT - FRONT - BOTH - RE 60294 miles
08/17/2005 174192 # D4440 - COMPRESSOR ASSEMBLY - REPLACE 34748 miles
07/28/2005 172732 # J6354 - POWERTRAIN CONTROL MODULE ENGINE REPROGRAMMING WITH SPS 33602 miles
07/28/2005 172732 # N4199 - INSTRUMENT CLUSTER REPROGRAMMING WITH SPS 33602 miles
11/04/2004 150899 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 20283 miles
11/04/2004 150899 # V0987 - 03011 - REPROGRAM PDM - INC REFRESH IF NECESSARY 20283 miles
12/04/2003 860782 # T2020 - TOWING 8017 miles
12/02/2003 124530 # L1228 - FUEL TANK FUEL PUMP MODULE REPLACEMENT - REAR 8588 miles
12/02/2003 124530 # Z7902 - 2-DAY COURTESY TRANSPORTATION 8588 miles
01/07/2003 A04785 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
© 1998-2005 General Motors Corporation. All Rights Reserved.
Claim History
CLAIM HISTORY
Repair Order Date : 04/26/2007 Repair Order Number : 220793 Odometer Reading : 66224 miles
Serviced By : HURD CHEVROLET, INC.
1705 HARTFORD AVE
JOHNSTON, RI 02919-3203
(401) 751-6000 Selling Source : 13 - CHEVROLET
Site Code : 32304
Cycle Date Cycle Nbr Case Type Labor Operation Part Comments
05/04/2007 792 01 0 F0093 - UNIVERSAL JOINT, FRONT PROPELLER SHAFT - REAR - REPLACE 12479126 - JOINT KIT N
Repair Order Date : 12/29/2006 Repair Order Number : 211934 Odometer Reading : 60294 miles
1705 HARTFORD AVE
Site Code : 32304
01/09/2007 759 01 0 K7231 - HOUSING AND DRUM ASSEMBLY, REVERSE INPUT - R&R OR REPLACE 08681295 - HOUSING N
01/09/2007 759 02 0 F1447 - SEALS, FRONT DIFFERENTIAL OUTPUT SHAFT - FRONT - BOTH - RE 15801507 - SEAL N
Repair Order Date : 08/17/2005 Repair Order Number : 174192 Odometer Reading : 34748 miles
1705 HARTFORD AVE
Site Code : 32304
08/23/2005 615 01 # D4440 - COMPRESSOR ASSEMBLY - REPLACE 89023461 - COMPRESSO Y
Repair Order Date : 07/28/2005 Repair Order Number : 172732 Odometer Reading : 33602 miles
1705 HARTFORD AVE
Site Code : 32304
09/16/2005 622 01 # N4199 - INSTRUMENT CLUSTER REPROGRAMMING WITH SPS N/A N
08/05/2005 610 01 # J6354 - POWERTRAIN CONTROL MODULE ENGINE REPROGRAMMING WITH SPS N/A N
Repair Order Date : 11/04/2004 Repair Order Number : 150899 Odometer Reading : 20283 miles
Serviced By : HURD BUICK CHEVROLET, INC.
1705 HARTFORD AVE
(401) 751-6000 Selling Source : 11 - BUICK
Site Code : 33405
11/09/2004 533 01 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 26098419 - LUBE KIT N
11/09/2004 533 02 # V0987 - 03011 - REPROGRAM PDM - INC REFRESH IF NECESSARY N/A N
Repair Order Date : 12/04/2003 Repair Order Number : 860782 Odometer Reading : 8017 miles
Serviced By : GM ROADSIDE ASSISTANCE
PO BOX 50098
PHOENIX, AZ 85076-0098
Site Code : 00690
Business Associate Code : 160087
12/09/2003 437 01 # T2020 - TOWING N/A N
Repair Order Date : 12/02/2003 Repair Order Number : 124530 Odometer Reading : 8588 miles
1705 HARTFORD AVE
Site Code : 33405
12/23/2003 441 01 # L1228 - FUEL TANK FUEL PUMP MODULE REPLACEMENT - REAR 25169302 - MODULE N
12/23/2003 441 02 # Z7902 - 2-DAY COURTESY TRANSPORTATION N/A N
Repair Order Date : 01/07/2003 Repair Order Number : A04785 Odometer Reading : 0 miles
1705 HARTFORD AVE
Site Code : 32304
01/10/2003 342 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME N/A N
Vehicle Build
VIN 1GNEK13T23R204785
VEHICLE BUILD
Gross Vehicle Weight Rating : 3133 kg (6908 lb)
Order Number : FVFQCC
Build Date : 01/07/2003
Build Plant : 13R06
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AG1 - SIX-WAY POWER DRIVER SEAT
AG2 - 6-WAY POWER DRIVER & PASS SEATS
AJ1 - DEEP TINTED GLASS
AL0 - SENSOR INDICATOR INFLATABLE RESTRAINT FRT PASS
AL4 - 2ND ROW BUCKET SEATS
AN3 - FRONT BUCKETS WITH POWER ADJ.
ARL - PLANT CODE-ARLINGTON, TX
AS3 - THIRD ROW BENCH SEAT
AU0 - KEYLESS REMOTE DOOR LOCK
AXP - MPV VIN IDENT POSITION
A31 - POWER WINDOWS
BVE - ASSIST STEPS
B30 - WHEELHOUSING & FLOOR CARPETING
B58 - COLOR-KEYED FLOOR MATS, CARPETED
B71 - WHEEL OPENING FLARES
B85 - BRIGHT BODY SIDE MOLDINGS
CJ2 - AIR CONDITIONING AUTOMATIC DUAL ZONE
C25 - REAR WINDOW WIPER & WASHER
C36 - REAR HEATER
C49 - ELECTRIC REAR WINDOW DEFOGGER
C5H - 6900 LBS GVW RATING
C69 - AIR CONDITIONING-FRONT & REAR
DF5 - ISRV MIRROR W/COMPASS & TEMP
DH2 - LIGHTED LH & RH VISOR MIRRORS
DK7 - INTERIOR CUSTOM ROOF CONSOLE
DL3 - OSRV MIRROR W/DRIVER SIDE AUTO DIMMING, PWR FOLD & ADJ, HEAT, TURN SIGNAL
DT4 - ASHTRAY MUFFIN
D07 - CUSTOM FRONT FLOOR CONSOLE
EVA - EVAP EMISSION REQUIREMENT
E52 - LIFTGATE/LIFTGLASS
FK2 - TORSION BAR SPRING ADJUSTMENT
FK3 - TORSION BAR SPRING ADJUSTMENT
GT4 - REAR AXLE - 3.73 RATIO
G69 - LEVEL CONTROL AUTO, AIR, HD
JC4 - 4 WHEEL POWER DISC BRAKES
JF4 - POWER ADJUSTABLE PEDALS
JL4 - VEHICLE STABILITY SYSTEM
KG3 - 145 AMP ALTERNATOR
KNP - HD AUX TRANSMISSION COOLING SYS
KUP - THROTTLE CONTROL ELECTRONIC
K34 - CRUISE CONTROL
LM7 - VORTEC 5300 V8 SFI GAS ENGINE
M30 - 4-SPD AUTOMATIC TRANSMISSION
NC7 - FEDERAL EMISSIONS OVERRIDE
NC8 - CALIFORNIA EMISSIONS ULEV
NE1 - MA / ME EMISSIONS
NP5 - LEATHER WRAPPED STEERING WHEEL
NR4 - TRANSFER CASE 4 WHEEL DRIVE
NZZ - OFF ROAD - SKID PLATES
PDH - DRIVER CONVENIENCE PACK INCL: * HOMELINK UNIVERSAL TRANSMIT.
PDM - WHEEL FLARES & SKID PLATES
PDP - 3RD ROW SEAT PACKAGE INCLUDES: * 3RD ROW SEAT * LIFTGATE/LIFTGLASS
PDZ - TRAILERING PACKAGE INCLUDES: * TRAILERING EQUIPMENT * TRANSMISSION OIL COOLER
PF4 - CAST ALUMINUM WHEELS
QMK - P265/70R16 WOL TIRES
R7D - OCTOBER RE-PACKAGE
SAF - SPARE TIRE LOCK
SLM - STOCK ORDERS
SLT - EQUIP CHEV 'LT' SALES PKG
T96 - FRONT FOG LAMPS
UC6 - AM/FM RADIO,RDS,6 DISC CHANGER, AUTO TONE CONTROL, AND ETR (REPLACES STD/OPT PKG RADIO)
UE1 - ONSTAR COMMUNICATIONS SYSTEM INCL 1 YR SAFE & SOUND PLAN AND STEERING WHEEL CONTROLS
UG1 - HOMELINK
UK3 - REDUNDANT RADIO CONTROLS
UK6 - REAR SEAT AUDIO CONTROLS
UQ7 - BOSE SPEAKER SYSTEM
U2K - XM SATELLITE RADIO-100 CHANNELS OF COAST TO COAST DIGITAL SOUND (SUBSCRIPTION CHARGES EXTRA)
VB3 - CHROME REAR STEP BUMPER
VG3 - FRONT DELUXE CHROMED BUMPER
VR4 - WEIGHT DISTRIB. PLATFORM HITCH
VXS - COMPLETE VEHICLE LABEL
V22 - DELUXE FRONT APPEARANCE PKG.
V54 - BLACK ROOF LUGGAGE CARRIER
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
V76 - RECOVERY HOOKS
XMK - TIRE FRONT P265/70R16-111S WOL
X88 - CHEVROLET CONVERSION
YD3 - BASE EQUIP FOR SCH GVW PL-FT AX
YD6 - BASE REAR SPRING
YE9 - SILVERADO
YMK - TIRE REAR P265/70R16-111S WOL
ZMK - SPARE TIRE P265/70R16-111S WOL
ZM9 - CONVENIENCE PACKAGE
ZY1 - SOLID PAINT
Z55 - AUTORIDE
Z82 - HEAVY DUTY TRAILERING EQUIPMENT
1SM - TAHOE LT PREFERRED EQUIPMENT GROUP: * VORTEC 5.3L V8 SFI GAS ENG * AM/FM STEREO CD WITH RDS * PREMIUM BOSE SPEAKER SYSTEM * REAR SEAT AUDIO CONTROLS * IN DASH 6 CD PLAYER * 1ST AND 2ND ROW LEATHER SEATING SURFACES * PWR FOLD AND ADJUST HEATED OUTSIDE MIRROR WITH TURN SIG AND DRIVER SIDE AUTO DIMMING * 6 WAY POWER HEATED BUCKET SEATS WITH DRIVER MEMORY * POWER ADJUSTABLE PEDALS * ELECTRONIC CLIMATE CONTROL * STEERING WHL MOUNTED CONTROLS * ONSTAR COMMUNICATIONS SYSTEM INCL 1 YR SAFE & SOUND PLAN
1SZ - PREFERRED EQUIPMENT SAVINGS
41U - BLACK
52I - TAN INTERIOR TRIM
522 - TAN LEATHER
6XK - COMP FRT LH COMPUTER SEL SUSP
7XK - COMPONENT FRT RH COMP. SEL SUSP
Delivery Information
IN-SERVICE INFORMATION
In-Service Information Not On file
DELIVERY INFORMATION
Delivery Date : 06/21/2003
Delivery Type : 021 - GMO EMPLOYEE OUT-OF-STOCK/OPTION 2
Delivered Odometer : 5 miles
Delivering Dealer :
1705 HARTFORD AVE
(401) 751-6000
Delivery Selling Source : 13 - CHEVROLET
Delivery Site Code : 32304
