Incandesant Wattage
Guest Riggs
Guest Riggs
Alright..... does anybody know how much watt a regular 194 bulb takes?
Ive read it takes 4 watts for that little bulb....
4 - Cargo / 3rd Brake Light
2 - Front Signals
6 - Dash
2 - Floor
2 - Door
3 - Almost same thing behind Heater controls
So a Extra 76 Watts / 6.3 Amps but most of the time driving in traffic i would have a extra 52 Watts / 4.3 Amps that my alternator wouldnt have to produce....
Not only that but they would look awesome!!!! btw i based this all on a 4 Watt Draw but how would i find out how much these take or does anybody know?
Guest Riggs
idk there are so many benifts of LED's
Truck Charges Faster...
Alternator Is Used Less - Gaining More MPG's....
Alternator Lasts Longer....
Bulbs Last Longer....
Bulbs Are Brighter....
Dont Get As Hot, So they Dont Leave "Burn" Marks Inside Bulbs...
Look Nicer...
My Alternator Makes 105 Amps / 1360 Watts
If i replaced Every Bulb in my Truck to LED i would use 300 Watts less which is quite alot... thats like buying a high output alternator...(25 Amps Extra)
and can be done for about 100 bucks and they last almost a life time
Guest Riggs
just a little update...
I replaced:
2 - License Plate Lamps - WLED x 4 - White
2 - Door Lights - WLED x 4 - Red
2 - Floor Lights - WLED x 5 - Red
1 - Dome Light - Festoon (44x10mm) x 9 - Red
And i have ordered 6 - WLED x 5 For dash and 4 - T1.5's in Red for Heater Controls.....
After that i am going to the the corner lens in front and put in a electronic flasher so i dont have speedy blinkers :)
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
