Is There Any Way A 2004 Ecss Sierra Z71 Can Have A Hidden Wheel Lift?
I got a killer deal on my 04 ECSS because it had previous minor flood damage (no long term effects so far, it's been 2 years). I really wanted a 3/4 ton truck to convert over to a repo truck. There's a few companies that sell hidden wheel lifts like the one in this picture:
I do a lot of mechanical work on the side and it would be great if I could convert my truck into a tow truck. Now, I don't plan on towing anything bigger than a S10 Blazer, and because I'm a Honda/Acura specialist, I'll be towing cars 90% of the time. Is there a huge difference in the frame between the 1/2 ton and 3/4 ton trucks? If not, can I perform suspension upgrades to help my truck handle the extra tongue weight? I may perform reposessions for a friend's "buy here pay here" lot as well, so I have to keep that in mind as well.
I'm 100% serious about this subject and have the ability to get it done, I would appreciate sincere answers. Most likely, I will not consider buying a 3/4 ton truck.
Can't say for sure but with the proper aids such as air bags and leafs you should fine to haul those little things with a 1500. I've seen 1500's hauling thousands more pounds from the OEM hitch so while not optimal, I'd be surprised if you'd do any damage hauling around those little things if you set up the suspension correctly. I am no expert but that my opinion.
I thought the same thing. I haul a full car trailer (1800 pounds) and I've had my 3200 pound stock car on it and it hauled it just find. Granted, the tongue weight wasn't too bad, but it was still hauling it just fine.
My biggest concern is the frame rail differences in the rear because the hidden wheel lift will need to be mounted up like the 3/4 ton.
I'd like to hear more opinions
With beefed up rear springs and a set of high quality shocks, I'd do it in a heartbeat. I'd make sure you had a good trans cooler installed and 3.73 rear gears would probably be the minimum necessary gear for the job.
I say go for it.
1500 has a hydroformed box frame while the 3/4 is boxed at the front and C thru the center and box at the rear. I would go 3/4 ton as with the 3/4 you have a beffier rear axle and if you find one with an Allison tranny your never going to regret the purchase. While a 1500 is great for small vehicles if you are repoing there may be the day you have to repo a full size vehicle and you want to have all your angles covered just in case.
I don't have any thought of ever towing anything heavier than 4000 pounds.
But if the frame really is different, I guess I'm screwed because these are bolt-ons for the 3/4 ton trucks.
You can beef up the suspension all you want, but I'd still be worried about the wimpy 10 bolt rear end.
This is something that can be upgraded correct? I've replaced rear ends on a lot of cars and trucks.
    daveishi
    daveishi
  • Who's Online   2 Members, 0 Anonymous, 1,232 Guests (See full list)
    • Because that is IDIOTIC, much like this question. They've already been forced to do it by past administrations - why would you roll that back when it's a GOOD thing?  WHO IS ARGUING FOR LOWER MILEAGE???? 😂  NOBODY IS!!   I'm certainly not! What I want is RELIABLE vehicles again that are worth the price paid!    I don't get your logic here ...   In 2003 I paid $2,200 for our '86 Grand Marquis. It's STILL running and I've never been inside the engine, aside for the timing cover since it was leaking, so I threw a new timing set in since that makes sense. Transmission is ORIGINAL. Electric pump in the gas tank is ORIGINAL. Rear end is ORIGINAL. I'd have to hit my head REAL hard to want to pay $60k or more for a car that still can't come close to the comfort, seating and storage space, or reliability of this one. Nothing is even in the ball park! Hundreds of thousands of brands and models have been built and sent to the crusher while this one keeps on going!   https://postimg.cc/Z9XRrCSg   I've got a whole fleet of cars, motorcycles, and a truck close to this age for summer and winter. No one could pay me enough to buy anything built this century. I have zero use for any it.
    • Since I'm the one who has to fix them when they break, I'll take vehicles over 30 years old all day, EVERY day, over ANY modern crap. Have you attempted any repairs on anything built after 2006? It's a friggin nightmare, and gets worse the newer the model year.    If I had the will or desire, I can make any car of any age outside of a Model T (I don't have THAT much will ...) just as powerful, comfortable, and have all the tech the new stuff does, and get pretty close in mileage, too. I prefer SIMPLICITY. The less the vehicle has, the less to fix WHEN it breaks, not IF.   I'm glad you snot-nosed punks don't like them. More for us, plus that keeps the prices from climbing more than they already have.👍
    • Bringing this thread back on topic. I just noticed the incredible lack of bright chrome across the entire new lineup. Even the Denali has tinted the brightwork in the grille and has none elsewhere. None of them have chrome bumpers. As far as I can tell there aren't even chrome mirror caps. I'm curious if this also happens out back? Are there no chrome rear bumpers either? This is quite the departure for GMC.
