Wtb: Lowering Shackles And Hangers
ok i bought a 2"fornt 4" rear lowering kit for my 04 silverado well the guy i bought it from only sent me the front coils and the shocks now i cant get a hold the the guy :D and my truck looks funny with the ass in the air all i need is the shackles and hanger for the rear
