TH350 shift problem
My 74 1/2 ton chevy hit another problem, it won't shift properly. It will wind up to 4,500 RPM+ before shifting into second. If you let off the gas or quite accelerating it will stay in first.
What could be causing this problem? Vaccum module?
Joel
  • 3 weeks later...
I have 87 k10 does the same thing holds first gear up 3500-4000 rpm it was rebuilt 5 months ago don't know why any thoughts have not had the time to fix it.
I called a trusty trans shop that has been around since the 70's about the affects of a bad modulator. He said my problems could be from that part and also said what 01badgmc did. If there is no vacuum, it will have the same problem :)
So after work I check out the vacuum line and sure enough it was pinched :).
I fixed the line and went for a drive. Problem solved! GOD that made my day, didn't spend a dime and fixed a huge problem.
Joel
